kierpce
Win32:Malware gen
Co chwile avast mi krzyczy, że wykrył zagrożenie.
Gdzie wykrył (ścieżka, nazwa pliku)?
1) Użyj >Adw-cleaner
najpierw kliknij na SZUKAJ, a dopiero po zakończeniu skanowania, gdy uaktywni się przycisk USUŃ, to kliknij na niego.
Pokaż raport z niego C:\AdwCleaner\AdwCleaner.txt
2) Otwórz Notatnik i wklej w nim:
Task: {0DBAFDFF-32FA-4C16-B3C5-656A8BA141D6} - System32\Tasks\Installer_sense => C:\Users\Łukasz\AppData\Local\Installer\Installsense_3522\ins_postInst.exe [2015-01-28] () <==== ATTENTION
c:\Users\Łukasz\AppData\Local\Installer\Installsense_3522
Task: {3226398F-86AC-4208-84DD-2EB13606D1DD} - System32\Tasks\{C421D685-DC69-4F72-BF97-8B22EEB7337F} => pcalua.exe -a C:\Users\Łukasz\AppData\Roaming\omiga-plus\UninstallManager.exe -c -ptid=cor <==== ATTENTION
Task: {5C59207E-A2A6-415B-84A3-F406837AE9BF} - System32\Tasks\YTAUpdate => C:\PROGRA~2\YOUTUB~1\Updater.exe <==== ATTENTION
Task: {9922A603-C4D7-4C74-901D-D88AE36F1BB3} - \Installer_iwebar No Task File <==== ATTENTION
Task: {E22DD4A8-84C7-45FC-9C1C-C9ACC009E4F4} - System32\Tasks\{70E89744-481F-4A8F-A1BF-80290BB2744C} => pcalua.exe -a C:\Users\Łukasz\AppData\Roaming\mystartsearch\UninstallManager.exe -c -ptid=smt
HKLM-x32\...\Run: [] => [X]
HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Policy restriction <======= ATTENTION
CHR HomePage: Default -> hxxp://www.mystartsearch.com/?type=hppp&ts=1422458868&from=smt&uid=TOSHIBAXMQ01ABD050_43MFPMPRTXX43MFPMPRT
CHR StartupUrls: Default -> "hxxp://www.mystartsearch.com/?type=hppp&ts=1422458868&from=smt&uid=TOSHIBAXMQ01ABD050_43MFPMPRTXX43MFPMPRT"
CHR DefaultSearchKeyword: Default -> mystartsearch
S2 SPDRIVER_1485.0.0.0; \??\C:\Program Files (x86)\ShopperPro\JSDriver\1485.0.0.0\jsdrv.sys [X]
C:\WINDOWS\System32\Tasks\Installer_sense
C:\WINDOWS\System32\Tasks\YTAUpdate
C:\Users\Public\Documents\YTAHelper
C:\Users\Public\Documents\ShopperPro
C:\Users\Public\Documents\GOOBZO
C:\ProgramData\SetStretch.exe
C:\ProgramData\SetStretch.VBS
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść obok FRST. Uruchom FRST i kliknij przycisk Fix.
Powstanie plik fixlog.txt.
Daj ten log.
3) Zrób nowe logi z FRST.
4) Napisz, czy problem znikł?
F.
    • 40 powinno na górkę styknąć. I to na luzie jako dodatkowe.  Ewentualnie powinieneś pomyśleć nad jakimiś listwami przypodlogowymi z systemem dowolnego dodawania gniazdek.
