jacek619
Duże zużycie procesora.
W tych logach nie widzę niczego podejrzanego.
Kosmetyka:
1. Wklej To Do Opcji Własne Opcje Skanowania/Skrypt i kliknij Wykonaj Skrypt
:OTL
IE - HKU\S-1-5-21-3760709531-3061839732-1520479860-1000\..\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: "URL" = http://www.key-find.com/web/?utm_source=b&utm_medium=cor&utm_campaign=install_ie&utm_content=ds&from=cor&uid=ST3500418AS_9VMV6R31XXXX9VMV6R31&ts=1424564295&type=default&q={searchTerms}
IE - HKU\S-1-5-21-3760709531-3061839732-1520479860-1000\..\SearchScopes\{2023ECEC-E06A-4372-A1C7-0B49F9E0FFF0}: "URL" = http://www.key-find.com/web/?utm_source=b&utm_medium=cor&utm_campaign=install_ie&utm_content=ds&from=cor&uid=ST3500418AS_9VMV6R31XXXX9VMV6R31&ts=1424564295&type=default&q={searchTerms}
IE - HKU\S-1-5-21-3760709531-3061839732-1520479860-1000\..\SearchScopes\{2CADE79D-F5D9-4063-860A-954931E72C22}: "URL" = http://www.key-find.com/web/?utm_source=b&utm_medium=cor&utm_campaign=install_ie&utm_content=ds&from=cor&uid=ST3500418AS_9VMV6R31XXXX9VMV6R31&ts=1424564295&type=default&q={searchTerms}
IE - HKU\S-1-5-21-3760709531-3061839732-1520479860-1000\..\SearchScopes\{9156BBCD-6C74-414B-A7EF-D73320C40AD5}: "URL" = http://www.key-find.com/web/?utm_source=b&utm_medium=cor&utm_campaign=install_ie&utm_content=ds&from=cor&uid=ST3500418AS_9VMV6R31XXXX9VMV6R31&ts=1424564295&type=default&q={searchTerms}
IE - HKU\S-1-5-21-3760709531-3061839732-1520479860-1000\..\SearchScopes\{E733165D-CBCF-4FDA-883E-ADEF965B476C}: "URL" = http://www.key-find.com/web/?utm_source=b&utm_medium=cor&utm_campaign=install_ie&utm_content=ds&from=cor&uid=ST3500418AS_9VMV6R31XXXX9VMV6R31&ts=1424564295&type=default&q={searchTerms}
:Files
C:\Users\xxx\AppData\Roaming\Babylon
:Commands
[EMPTYTEMP]
2. Wstaw Raport ze skryptu i zrób zestaw logów z FRST
FRST: http://forum.pclab.pl/topic/893302-WA%C5%BBNE-Wymagane-logi-systemowe-w-tym-dziale/page__p__11808087entry11808087
(Zazancz też: Addition i ShortCup)
W logach FRST też nie widzę niczego podejrzanego.
Do nałożenia tylko kosmetyka + diry poszczególnych katalogów.
1. Do notatnika wklej i zapisz jako fixlist.txt i kliknij Fix w Interfejsie FRST
Plik fixlist.txt umieść obok programu FRST
CloseProcesses:
CHR HKU\S-1-5-21-3760709531-3061839732-1520479860-1000\SOFTWARE\Policies\Google: Policy restriction <======= ATTENTION
S3 MBAMSwissArmy; \??\C:\Windows\system32\drivers\MBAMSwissArmy.sys [X]
S3 Synth3dVsc; System32\drivers\synth3dvsc.sys [X]
S3 tsusbhub; system32\drivers\tsusbhub.sys [X]
S3 VGPU; System32\drivers\rdvgkmd.sys [X]
2015-03-15 22:48 - 2015-02-22 01:18 - 00000000 ____D () C:\Program Files\XTab
AlternateDataStreams: C:\ProgramData\TEMP:D1B5B4F1
CMD: dir /a C:\ProgramData
CMD: dir /a C:\Users\xxx\AppData\Roaming
CMD: dir /a "C:\Program Files"
EmptyTemp:
DeleteQuarantine:
2. Wstaw Raport ze skryptu (Fixlog).
    • Ale tak bylo od wiekow to na prawde zejdz na ziemie i nie skladaj klockow. Wyplata opodatkowana a podatek od nieruchomopsci to calkowicie odmienne tematy. No masz racje na 2024 co wychodzi na duzy + bo drugi spada na 12% do 85K
    • @kola01Ok, dzięki za ogólne wyjaśnienie jak działają chłodzenia i stwierdzenie czy moje chłodzenie, którego nigdy w życiu na własne uszy nie słyszałeś jest ciche lub głośne😆 Bardzo wiele to zmienia w moim życiu, dobra robota👏  Jak "głośny" jest Fortis 5 dual przy swoim maksymalnym RPM 1400 w porównaniu z różnymi aio możesz przeczytać tutaj:  https://www.purepc.pl/test-silentiumpc-fortis-5-i-fortis-5-dual-fan-coolery-dla-procesorow-z-dobrym-stosunkiem-ceny-do-wydajnosci-i-cichymi-wentylator?page=0,7 Może uwierzysz
    • Nic sobie nie pomyliłem. Z premedytacją nie użyłem nazwy gdyż mowiny o tanich asrocakch, model nie ma znaczenia. Ogólnie beka bo gdy mówię o karcie dźwiękowej narracja zmieniana jest na taką że dobra karta dźwiękowa nie jest potrzebna, można kupić inna, można kupić dac itp (TO SĄ DODATKOWE KOSZTY). Jak mówię o sekcji zasilania to narracja brzmi że pomylelem się z modelem płyty. Cały dowcip polega na tym że to 400zl to nie wiele jak na różnice w tym co dostajemy w tych mobasach. Tzn lepsza dźwiękowka, lepsza sekcja zasilania, lepsze wyposażenie. OGÓŁEM LEPSZA PŁYTA. Jeśli komuś wystarcza biedny kodek audio czy biedna sekcja zasilania to fajnie ale niech nie mówi że ta płyta jest dobra. Jest WYSTARCZAJĄCA dla niego i to wszystko. To tak jak z tymi bułkami z biedronki, dla kogoś są wystarczające, ja wolę kuoic 3x droższe i nie jest odnrazanego barachła. Argumenty że za 900zl płyty też mają kiepskie kodeki audio jest śmieszny bo wystarczy poszukać w specyfikacji technicznej i znaleźć taka która ma normalne audio, wyposażenie czy co tam nas interesuje. Nadal nikt nie odpowiedział, dlaczego nie polecają tanich asrockow na am4? Bo różnica pomiędzy dobrą płyta jest po prostu mniejsza i mówimy o mniejszej skali.  Edit: teraz spojrzałem na morele, nowy tomahawk kosztuje 871zl. Różnica pomiedzy "wystarczającymi" asrockami zaczyna topnieć wiec za niedługo ten post będzie nieaktualny bo i tak wszyscy będą polecali MSI. Obecnie to już 350zl czyli żaden pieniądz.
    • Masz calkowita racje. 1 kwietnia lece na Florida zakupic dzialke i zaczac budowe domu. Nie dosc ze tax ma sprzedaz jest 6% to jak dom bedzie jako glowny nie bede placil stanowego podatku od zarobkow w moim wypadku to 10.75% ze stanu NJ. Tym sposobemdom wybuduje sie z tax z NJ.
    • No nie wiem jakim cudem ale w pit masz ustalone progi procentowe od zarobkow/ Kosz pracodawcy pracownika nic nie obchodzi bo to dwie oddzielne dzialalnosci. No to najprostrza droga. Z tego co sie orientuje to jak dobrze sie uczysz to studia nadal w Polsce sa bezplatne?.
