RedGhost
DDoS routera :/
Witam.
Od jakiegoś czasu mój bieda 10Mbps Internet zwolnił strasznie. Nie kojarzyłem tego z niczym aż do momentu przejrzenia logów tego dziadostwa z antenką :
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: Whole System SYN Flood Attack
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: Per-source SYN Flood Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: Per-source FIN Flood Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: Per-source ICMP Flood Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: Port Scan Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: IP Land Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: UdpEchoChargen Attack source=0.0.0.0 destination=32.48.32.67
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: UdpBomb Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: PingOfDeath Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: IcmpSmurf Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:12 rlx-linux user.warn kernel: DoS: TearDrop Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:13 rlx-linux user.warn kernel: DoS: Per-source SYN Flood Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:13 rlx-linux user.warn kernel: DoS: Per-source FIN Flood Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:13 rlx-linux user.warn kernel: DoS: Per-source ICMP Flood Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:13 rlx-linux user.warn kernel: DoS: Port Scan Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:13 rlx-linux user.warn kernel: DoS: Tcp SYN With Data Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:13 rlx-linux user.warn kernel: DoS: UdpEchoChargen Attack source=0.0.0.0 destination=32.48.32.67
Sep  3 23:23:13 rlx-linux user.warn kernel: DoS: UdpBomb Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:13 rlx-linux user.warn kernel: DoS: PingOfDeath Attack source=0.0.0.0 destination=0.0.0.0
Sep  3 23:23:13 rlx-linux user.warn kernel: DoS: TearDrop Attack source=0.0.0.0 destination=0.0.0.0
a potem pojawiają się już różne IP zamiast 0.0.0.0.
Router strasznie zwalnia. Czy mogę coś z tym zrobić?
Może to coś z okolicy lokalnych fal śmieci. Zmienić SSID, hasło, zrobić update routera jeśli jest, skontrolować listę klientów, zobaczyć czy Firewall na routerze włączony.
Mam NIS 2015. Nic nie widzi :/. Też już myślalem tak.
To moze nie twoj komputer tylko ktos inni ciagnie po wifi od ciebie, moze sie wlamal na twoj MAC adres jakis i ty myslisz, ze to twoje urzadzenie jakies, a to ktos obcy np. zaposcil p2p. Logiroutera nie zawsze sa 100% realne do tego co sie dzieje w sieci domowej ;)
Lista klientów się zgadza. To też sprawdzałem. Męczę się już tydzień z tym.
Rozumiesz co ja mowie?? Mogl ktos odczytac MAC adres twojego smartfona, sa aplikacje rozne i przypisal go sobie do swojej karty w laptopie, mogl odczytac tez haslo i sie tak wlamuje. Zmien nazwe sieci wifi i haslo w routerze i zobaczysz co i jak. Wylacz wifi w urzadzeniu operatora.
Mam ustawione,że tylko zaufane MACi mają dostęp. WiFi wyłączone. Na liście klientów pojawia się 1 komputer, mój podłączony kablem. Więc opcja podszycia odpada, tak? Więc lista klientów się zgadza.
Jak ktos odczytal MAC adres twojej karty sieciowej w PC i go wpisal w Windowsie do swojej karty sieciowej to jak masz zaufany ten MAC to sie moze podlaczyc do ciebie, ale wtedy twoj PC by sie nie polaczyl z routerem. Nie uzywasz smartfona, tableta, siostra, rodzice laptopa??
Najprosciej zalogowac sie na router i ogladnac ruch przychodzacy i wychodzacy i wtedy masz jasnosc. Niestety na 99% Twoj router nie daje takiej opcji.
Wlacz swojego kompa z bootowalnego linuksa i sprawdz. Wykluczysz wtedy wirusy.
Jak masz DDoS to nie jestes w stanie nic zrobic
Najprostsze było wyłączyć WiFi i próbować tylko po kablu. Sytuacja nie zmienia się. Od kiedy tylko WAN się podepnie leci DDoS. Rozłączę WAN - log pusty (sama inicjacja routera). Zastanawiam się czy inny router lepiej by sobie poradził z tymi atakami?
Podlacz sie kablem do sprzetu Neti bez posrednictwa Asusa czy bedzie to samo :)
Bedziesz widzial czy ci zwalnia czy nie. ;)
Ten model Asusa juz nie ma wsparcia, nie poprawiaja firmware-u ;)
Mam tą wersę 0.0.37. DDWRT czy Tomato nie współpracuje z tym routerem. Chip jest Realtek.
Podepnę się pod temat, również korzystam z starego Asusa(dsl-31), w logach od początku tego roku zaobserwowałem również ataki(żeby było śmieszniej oprogramowanie tego routera jest dziurawe jak ser szwajcarski, za każdym razem reup softu pomagał), jakie teraz są polecane i bezpieczne routery co wystarczą na najbliższe kilka lat?
Swój przypadek znam i nie zalicza się do powyższych, ot zwykły robak na soft router próbujący pomieszać w dns'ch i otworzyć furtkę dla innych robaków(w tym rootkitów, ba, nawet adres tej sieci namierzyłem, ale firma do której należy albo o tym wie albo ma to w 4 literach), to tez pytam o router z dobrymi zabezpieczeniami bo moje adresy wpadły do jakiejś trefnej bazy danych. W sofcie routera już po blokowałem co trzeba, jednak co jakiś czas widzę na logach, że znowu ten sam adres próbował się połączyć.
Może warto zgłębić temat bezpieczeństwa DDWRT czy Tomato w porównaniu do oryignalnych firmwarów, i szukać czegoś kompatybilnego z dobrym wsparciem.
Dokładnie, tylko w routerach nie siedzę od 5 lat :( Nie mam zamiaru wydawać kasy na szmelc, myślałem tez o tanich cisco ale czy to coś warte?
Zadzwon do operator Internetu i wytlumacz jaka jest sytuacja. Powinni zmienic Ci adress IP, ew. przelaczyc na inne DNS-y. Obecny adres zostanie poddany kwarantannie jako nieaktywny na jakis czas, dopoki booty ziejace DD0s-em wymarza Cie z potencjalnych ofiar.
Innej drogi opcji nie ma.
Wszystko pod warunkiem że wszyscy w tej sieci nie mają tego samego adresu.
Tutaj mamy Netię. Powinna być zmiana IP po każdym wyłączeniu routera, a on ma cały czas ataki.
Nikt inny nie moze miec miec Twojego adresu IP, bo bylby konflikt. Czuwa nad tym DHCP operatora.
Za to Ty mozesz siedziec w grupie DNS, ktora obrywa DDos-em.
    • Kiedy premiera ? Kupię na pewno super gierka
    • https://www.polsatnews.pl/wiadomosc/2024-04-18/do-tusk-najblizsze-tygodnie-moga-rozstrzygnac-o-losach-wojny-w-ukrainie-sytuacja-jest-krytyczna/ https://www.money.pl/gospodarka/cudzoziemcy-w-policji-ruszyla-analiza-7018246868503488a.html Jak do policji przyjmą Białorusinów z wrogiego nam państwa pod butem Rosji to policjant będzie zatrzymywał policjanta ? Ukraina upada ? Przecież Rosja miała upaść w 3 dni ? To jak to z tym jest ?
    • https://rozrywka.dorzeczy.pl/show-biznes/575775/kubicka-wsciekla-na-lekarza-z-ukrainy-nie-mowil-po-polsku.html Ostatecznie Kubicka w zaawansowanej ciąży, sprowadziła swoją mamę do prywatnego warszawskiego szpitala, gdzie lekarze nie kryli zdumienia tym, że nie wykonano jej odpowiednich badań. Tam właśnie zamierza kontynuować leczenie. czyli standard , gdzie są zwolennicy publicznej "służby zdrowia" ? @kanon7  https://polin.pl/pl/aktualnosci/2016/07/05/prezydent-andrzej-duda-w-kielcach
    • allegro lepsze i drozsze ale wiesz czemu bo jak kupisz nawet od prywatnego to na 99% dostaniesz item, i to nie chodzi o to ze cie oszukaja, kupilem 3 plyty glowne, jeden odrzucił zakup bo juz nieaktualne, dwoch pozostalych nie zaakceptowalo i 24h x2 nie mialem srodkow, do tego musisz czekac te 24/7 bo nawet jak zwroca srodki to tracisz caly jeden dzien bo przeciez nie kupisz 5 roznych rzeczy bo potem tego nie zwrocisz
    • Siemka, Mam takie pytanie, co w obecnej sytuacji bardziej opłaca się kupić, LG C3 42 czy AW2725DF   LG C3 obsługuje 4k i można go kupić już za 3600zl  AW2725DF obsługuje 1440p i jest droższy , kosztuje 4000zl.   Obecnie mam komputer który nie jest gotowy do grania w 4k, ale też trochę bez sensu płacić więcej za monitor który teoretycznie jest gorszy, bo obsługuje mniejsza rozdzielczość. A z tego co słyszałem LG C3 radzi sobie ze skalowaniem obrazu do 1440p bardzo dobrze.
