konop13
[logi] wyskakujace okienka z rundll (sysmenu)
Otwórz Notatnik i wklej w nim:
Task: {7425F52D-9EE3-41AC-9290-9505AE84B3AB} - System32\Tasks\Microsoft\Windows\Maintenance\SMupdate2 => Rundll32.exe C:\PROGRA~1\COMMON~1\System\SysMenu.dll ,Command701 update2 <==== UWAGA
Task: {AA1B3884-CF37-4612-8065-25346271AB6A} - System32\Tasks\Microsoft\Windows\Multimedia\SMupdate3 => Rundll32.exe C:\PROGRA~1\COMMON~1\System\SysMenu.dll ,Command701 update3 <==== UWAGA
Task: {C7C76D20-4E31-4C59-84A7-7F0FD16E8ACF} - \SMupdate1 -> Brak pliku <==== UWAGA
Task: {E4E70125-3033-4B6B-A6F4-4840824B32F2} - System32\Tasks\YTDownloader => C:\Program Files (x86)\YTDownloader\YTDownloader.exe <==== UWAGA
Task: {EDDF1D7C-EBF7-41AE-8D77-5B91698DA1EC} - \Yahoo! Search Updater -> Brak pliku <==== UWAGA
HKLM-x32\...\Run: [YTDownloader] => /boot [0 2015-03-15] ()
HKU\S-1-5-21-1719921228-3808722310-1140186609-1000\...\Run: [YTDownloader] => /boot [0 2015-03-15] ()
HKU\S-1-5-21-1719921228-3808722310-1140186609-1000-{ED1FC765-E35E-4C3D-BF15-2C2B11260CE4}-0\...\Run: [YTDownloader] => /boot [0 2015-03-15] ()
ShellIconOverlayIdentifiers: [00avast] -> {472083B0-C522-11CF-8763-00608CC02F24} => Brak pliku
GroupPolicy: Zasady grupy Chrome wykryto <======= UWAGA
CHR HKLM\SOFTWARE\Policies\Google: Zasada ograniczeń <======= UWAGA
FF SelectedSearchEngine: Yahoo! Search
FF Extension: Hold Page 1.0.1 - C:\Users\Ola\AppData\Roaming\Mozilla\Firefox\Profiles\ss3u0y7p.default\Extensions\{f0087990-17d0-4537-ad91-6a7a9c5c1b37}.xpi [2014-11-27]
S2 51cdb72; "C:\Windows\system32\rundll32.exe" "c:\Program Files (x86)\Optimizer Pro 3.11\OptProCrash.dll",ENT
S3 ewusbnet; system32\DRIVERS\ewusbnet.sys [X]
S3 ew_hwusbdev; system32\DRIVERS\ew_hwusbdev.sys [X]
S3 huawei_enumerator; system32\DRIVERS\ew_jubusenum.sys [X]
S3 hwdatacard; system32\DRIVERS\ewusbmdm.sys [X]
S3 VGPU; System32\drivers\rdvgkmd.sys [X]
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść obok FRST.exe
Uruchom FRST i kliknij przycisk Fix (NAPRAW).
Jeśli będzie OK, to będziemy kończyć:
DeleteQuarantine:
Plik zapisz pod nazwą fixlist.txt i umieść obok FRST. Uruchom FRST i kliknij w Fix (NAPRAW).
przez SHIFT+DEL usuń pozostały folder C:\FRST.
F.
zrobione wszystko do konca ale pozostaly otwierajace sie procesy po uruchomieniu Win7:
igfxtray.exe
hkcmd.exe
igfxpers.exe
iusb3mon.exe
które nadal trzeba/mozna uruchamiac z "palca"
iusb3mon.exe - nie musi być uruchamiany razem z Systemem - on potrzebny jest tylko do wykrywania USB 3.0.
Pozostałe raczej powinny być uruchamiane razem z Systemem.
F.
Ok,
ale czy jest jakas szybka metoda, by kazdorazowo po wlaczeniu W7 nie trzeba bylo klikac w te okienka?
    • 40 powinno na górkę styknąć. I to na luzie jako dodatkowe.  Ewentualnie powinieneś pomyśleć nad jakimiś listwami przypodlogowymi z systemem dowolnego dodawania gniazdek.
