-_- greg
AM4 Lista płyt do Ryzen
Słowem wstępu :)
X470 | B450 | ..........(premiera 2018r.)
X370 | B350 | A320 (premiera 2017r.)
ASRock (26)
X470 Taichi Ultimate
X470 Taichi
X470 Master SLI/ac
X470 Master SLI
Fatal1ty X470 Gaming K4
Fatal1ty X470 Gaming-ITX/ac ..(format ITX)
X370 Taichi
X370 Killer SLI/ac
X370 Killer SLI
X370 Pro4
Fatal1ty X370 Professional Gaming
Fatal1ty X370 Gaming K4
Fatal1ty X370 Gaming X
Fatal1ty X370 Gaming-ITX/ac ..(format ITX)
Fatal1ty AB350 Gaming K4
AB350 Pro4
AB350M Pro4
AB350M
AB350M-HDV
AB350M Pro4/DASH
Fatal1ty AB350 Gaming-ITX/ac ..(format ITX)
A320M Pro4
A320M-DGS
A320M-HDV
A320M
A320M-ITX ..(format ITX)
ASUS (30-*4)
ROG CROSSHAIR VII HERO (WI-FI)
ROG STRIX X470-F GAMING
PRIME X470-PRO
TUF X470-PLUS GAMING
ROG STRIX X470-I GAMING ..(format ITX)
* ROG STRIX B450-F GAMING
* PRIME B450-PLUS
* PRIME B450M-A
* ROG STRIX B450-I GAMING..(format ITX)
ROG CROSSHAIR VI EXTREME
ROG CROSSHAIR VI HERO (WI-FI AC)
ROG STRIX X370-F GAMING
PRIME X370-PRO
PRIME X370-A
ROG Strix X370-I Gaming..(format ITX)
ROG STRIX B350-F GAMING
PRIME B350-PLUS
TUF B350M-PLUS GAMING
PRIME B350M-A/CSM
PRIME B350M-A
PRIME B350M-E
PRIME B350M-K
ROG Strix B350-I Gaming..(format ITX)
PRIME A320M-A
PRIME A320M-C R2.0
PRIME A320M-E
PRIME A320M-K
EX-A320M-GAMING
Biostar (16)
X470GT8
X470GTN ..(format ITX)
X370GT7 Ver. 5.x
X370GT5 Ver. 5.x
X370GT3 Ver. 6.x
X370GTN Ver. 5.x ..(format ITX)
TB350-BTC Ver. 6.x
B350GT5 Ver. 5.x
B350GT3 Ver. 6.x
B350ET2 Ver. 6.x
Hi-Fi B350S1 Ver. 6.x
B350GTN Ver. 5.x ..(format ITX)
A320MH PRO Ver. 6.x
A320MD PRO Ver. 6.x
TA320-BTC Ver. 6.x
A320MH Ver. 6.x
GIGABYTE (28)
X470 AORUS GAMING 7 WIFI
X470 AORUS GAMING 5 WIFI
X470 AORUS ULTRA GAMING
B450M DS3H
GA-AX370-Gaming K7
GA-AX370-Gaming K5
GA-AX370-Gaming K3
GA-AX370-Gaming 5
GA-AX370-Gaming
GA-AX370-Gaming 3
GA-AX370M-Gaming 3
GA-AX370M-DS3H
GA-AB350-Gaming
GA-AB350-Gaming 3
GA-AB350M-Gaming 3
GA-AB350M-HD3
GA-AB350M-D3H
GA-AB350M-D3V
GA-AB350M-DS2
GA-AB350M-DS3H
GA-AB350M-DASH
GA-AB350N-Gaming WIFI ..(format ITX)
GA-A320-DS3
GA-A320M-DS2
GA-A320M-D2P
GA-A320M-HD2
GA-A320M-S2H
GA-A320MA-M.2
MSI (37)
X470 GAMING M7 AC
X470 GAMING PRO CARBON AC
X470 GAMING PRO
X470 GAMING PLUS
X370 GAMING M7 ACK
X370 XPOWER GAMING TITANIUM
X370 GAMING PRO CARBON AC
X370 GAMING PRO
X370 KRAIT GAMING
X370 GAMING PLUS
X370 SLI PLUS
B350 GAMING PRO CARBON
B350 KRAIT GAMING
B350 GAMING PLUS
B350 PC MATE
B350 TOMAHAWK
B350 TOMAHAWK PLUS
B350 TOMAHAWK ARCTIC
B350M MORTAR
B350M MORTAR ARCTIC
B350M BAZOOKA
B350M GAMING PRO
B350M PRO-VDH
B350M PRO-VD PLUS
B350M PRO-VH PLUS
B350I-PRO-AC ..(format ITX)
A320M BAZOOKA
A320M GRENADE
A320M GAMING PRO
A320M PRO-VD/S
A320M PRO-VD
A320M PRO-VD PLUS
A320M PRO-VH PLUS
A320M PRO-VHL
A320M PRO-M2
Płyty
*ROG STRIX B450-F GAMING
*PRIME B450-PLUS
*PRIME B450M-A
*ROG STRIX B450-I GAMING
tajemniczo zniknęły ze strony producenta. Być może chwilowo.
Miłego :D
Edytowane przez -_- greg
Może pierwsze sztuki pojawią się w połowie marca.
edit
wygląda na to że niektóre modele są już dostępne :E
Aktualnie jedyna fizycznie dostępna płyta to pięknie świecąca Gigabyte GA-AB350-Gaming 3.
Ale ile ta "dyskoteka" jest warta trudno powiedzieć.
2:10.... widzicie to co ja, jeśli chodzi o otwory montażowe chłodzenia? Czyżby niektórzy producenci zdecydowali się na kompatybilność otworów również z AM3?
Edytowane przez radek_z
Wygląda na to że tylko Asus o tym pomyślał.
Na razie wiadomo że w tym topowym modelu - tylko dlaczego się tym oficjalnie nie chwali na swojej stronie ?
Wkrótce się okaże jak to wygląda w innych płytach.
Poniżej znalezione fotki
A jak z PRIME-X370-PRO ma otworki z am 3 ? :P
Również jestem ciekawy :E
Gdy będę coś wiedział to chętnie podzielę się informacją.
O co dokładnie Ci chodzi to podpowiem? :)
Gloin pyta czy płyta PRIME-X370-PRO ma drugi zestaw otworów do zamocowania chłodzenia kompatybilnego z socketem AM3
(tak jak najdroższa płyta Asusa Crosshair 6 Hero).
Edytowane przez Mhelkir
Ja takich otworków nie widziałem, aczkolwiek nie byłem tym zainteresowany więc mogłem przeoczyć, a teraz się do tego nie dostane bo mi DR zasłania.
Witam
Czy ktoś z forumowiczów posiadających płytę ASUS PRIME X370-PRO może mi potwierdzić jakiego jest ona formatu ?? :hmm:
W części sklepów piszą iż jest to ATX a w części iż jest to E-ATX :kwasny:
Nie wiem czy wejdzie mi do budy SPC Aquarius X70W
I kolejne pytanko. jaka jest różnica między zasilaniem ATX a E-ATX :hmm:
Według specyfikacji płyta ma zasilanie "24-pin EATXPWR; 8-pin EATX12V"
Czy ktoś może polecić jakąś płytę dla ryzena 5 1600x do OC może 4GHz . Do max 800 zł , taką ze wsparciem , rozwojową , że tak powiem ;p
Dodam od siebie że Crosshair VI ma otwory montażowe AM3 ale musicie zmienić backplate na AM3 (i którego nie ma w zestawie) standardowy ma nawiercone otwory tylko pod AM4 wink.gif
Także użytkownicy chłodzeń typu Corsair Hydro (i innych używających standardowego BP) i tak w sumie będą musieli kupić zapinki AM4 albo zmienić BP.
Co wybrałeś?
Wstępnie mam oko na Gigabyte Aorus GA-AX370-Gaming 5
Nie no, już jest lepiej niż na FM2+. Mamy aż jednego ITX'a z displayportem! :mad2:
Nadaje się na konkurs w deseń "znajdź trzy różnice" ...wygrasz helikopter :lol2:
Gdyby dostępny był procek Ryzen z wbudowaną grafiką RX,
to było by wincyj płyt, wincyj złączy, wincyj wszystkiego :E
Coś mi podpowiada, że pośpieszyłem się trochę z tym biostarem :E nie mówię, że zły czy coś, ale chociaż wici by się przydało. :E nie mniej kolorystyka (czerwone akcenty) itxów od GB i aarocka mi nie podchodzi.
Zanim to się pojawi w sklepach to trochę wody w Wiśle upłynie ;) a jeśli potrzebowałeś "na wczoraj", to nie miałeś innej opcji.
Czerwień też nie megusta ale tego ITX'a Gigabyte to bym przygarnął o ile blaszko-osłona (shield I/O) nie będzie paskudna ...a po obsadzeniu gniazd, czerwień praktycznie zniknie z pola widzenia.
Teraz kolej Asus'a i MSI ale coś u nich cicho w temacie ITX, żadnych plotek nawet nie ma a jakiś Strix w szarości, jest mile widziany 8:E
A znacie może jakiś model na X370, który umożliwiłby automatyczną kontrolę wentylatorów w zależności od temperatury GPU? Na Z170 korzystam do tego celu ze SpeedFana, ale ten program jest aktualizowany bardzo rzadko i z tego co wiem nadal nie obsługuje chipsetów AMD 300 i Intel 200.
Chłodzenie GPU sterowane płytą główną?
nic nie wiem o takiej konfiguracji sterowania.
Można by wentylatory GPU podpiąć pod płytę, ale to już partyzantka :E
Spróbuj MSI Afterburner lub EVGA Precision XOC
    • Jeżeli tak będzie to trochę bez sensu czekać z zakupem. Spodziewałem się po zapowiedziach że przyrosty będą znaczne.... A zapadła decyzja o zbieraniu drobnych żeby za rok (chwilę po debiucie 50xx jak już ceny się unormują) zrobić przesiadkę na coś nowszego.
    • Bezprawie dostrzegają w Europie. Sytuacja w Polsce jest poważna. Rząd Donalda Tuska, przyjaciela Macrona i von der Leyen, prześladuje sędziów, media i konserwatywnych polityków - stwierdził w mediach społecznościowych francuski europoseł Nicolas Bay. Polityk zaznacza, że "to ważny atak na praworządność, ale brukselska Komisja nie wydaje się być tym poruszona".
    • N4P zamiast N3, to już wiemy co użyje desktopowy potworek, dodatkowo jak poskładamy wszystkie przecieki do kupy to wyjdzie coś takiego.   GB202 N4P 800mm2+ 192SM 128MB L2 512bit 28Gb/s GDDR7 1792GB/s   Większość wzrostu wydajności dostaniemy dzięki GDDR7 oraz cache, z pociętego 72MB do pełnego 128MB.
    • PiS ma sektę która co by się nie działo i tak na nich zagłosuje. I ten beton 25% będzie się trzymał. Rządzący albo będą coś robić albo ludzie zwyczajnie odpłyną, nie zagłosują. Obecnie rządzący przez kilka miesięcy zrobili wielkie nic. Fikołki i wygibasy na różne strony. Nawet konkursów na państwowe stanowiska nie przywrócili. Nie zlikwidowali nadmiarowych etatów w ssp tylko powsadzali swoich. Głównie 3D bo PSL od dawna na głodzie ale dalej to idzie na konto koalicji. TVP i radio razem z nastoma dodatkowymi kanałami jak były tak są. Jeszcze brakuje poparcia dla obecnego prezydenta Krakowa i Wrocławia przez KO.
    • Crashowanie od czasu do czasu (driver timeout lub czarny ekran z możliwym recoverem od minuty do ~pięciu )  na kartach AMD to norma była dla wielu osób przez jakieś ostatnie 2 lata, bo AMD ma problem z kompatylnością z praktycznie nikomu niepotrzebną funkcją windowsa, która jest domyślnie włączona (MPO ). Starczy tylko ściągnąć i uruchomić plik wyłączający MPO, który przygotowała nvidia, bo kiedyś też takie problemy ta marka miała (zresztą czasem słychać, że u niektórych na starszych kartach nvidii wciąż jest ten problem ) https://nvidia.custhelp.com/app/answers/detail/a_id/5157/~/after-upSpam wyslij raport-to-nvidia-game-ready-driver-461.09-or-newer%2C-some-desktop-apps Niektórzy piszą, że AMD jakiś czas temu już ten problem ogarnęło, ale nie jestem przekonany (przynajmniej parę miesięcy temu wciąż widziałem narzekania niektórych ), osobiście mam wyłączone MPO i nie widzę potrzeby go włączać i sprawdzać czy naprawdę AMD w końcu to ogarnęło. Generalnie to najlepiej po zakupie karty mieć komp włączony codziennie jak najdłużej i jak są problemy to robić zwrot, bo niestety wadliwe karty istnieją.
