Forum PCLab.pl: Stacjonarka do PIOsolver (2500zł) - Forum PCLab.pl
Ikona Ostatnio dodane tematy
Strona 1 z 1
Stacjonarka do PIOsolver (2500zł) Oceń temat: -----
#1 Użytkownik jest niedostępny   Qeriks
  • Dyskutant
  • PipPip
  • Postów: 19
Napisany 16 Czerwiec 2019 - 12:50
Witam
Potrzebuję jak najmocniejszego sprzętu do pracy w PIOsolver. Jest to program pokerowy który buduje bardzo rozbudowane drzewka. Nie wiem co aktualnie jest na topie i co się najbardziej opłaca.
Krótki opis ze strony autora żeby przybliżyć z czym mamy do czynienia:
System requirements:
---4+GB of free RAM for comfortable usage (full single-raised-pot with 2/3 pot bets everywhere takes about 1.2GB of RAM for wide 6max ranges and 1.9GB for wide HU ranges (90% vs 70%)); you need more for trees with multiple bet sizes (25bb HU tree with 2 sizes everywhere (30%-60%) is 5.9GB, 100bb tree with 2 sizes everywhere and 6max ranges is 7.8GB; the trees are proportionally smaller with smaller ranges).
--modern 64-bit CPU (for comfortable usage i5/i7 quad or equivalent is recommended but we tested on older quads as well and it will work just slower (anywhere from 2x to 5x slower))
--modern Windows (7 or newer) (but see next point)
--Mac works. Our customers run the solver using Parallels or Bootcamp. If you would like to give it a shot, try the free-version first.
--modern .Net Framework (available for free on Microsoft's website, already present on most modern computers)
PioSOLVER implements benchmark command to measure how good your hardware is for solving big trees. It measures how many seconds it takes to do a few iterations on a sizeable tree (2.2GB). To see your benchmark time start PioSOLVER and type "bench". On my 3 years old quad (i7-3770 @ 3.4 GHz) I get 10 seconds as of today (PioSOLVER 1.4.1 July 10th 2015). Here are some logs for solving typical spots using this hardware, every test run until 0.25% of the pot accuracy is reached. The solver doesn't have problems getting it down to 0.1% but it's very rarely practical as the solution doesn't change much at that point (even 0.25% is a bit of an overkill). The solver is significantly faster on suited or paired boards and 3x faster on monotone (or same-rank) ones. Out of 1755 flops in Holdem 286 are rainbow unpaired, 1170 are either paired or suited and 299 are monotone or same rank. Average flop is about 1.64x faster than rainbow unpaired one."
32gb pamięci ram wystarczy na moje potrzeby. Musimy celować w zestaw z jak najlepszym procesorem do tego typu zadań. Będę wdzięczny za wszelkie sugestie.
Budżet 2500zł (bez systemu)
Pozdrawiam
Strona 1 z 1
