szakala
ASUS K52F upgrade RAMU problem
Niedawno postanowiłem wymienić oryginalnie zainstalowaną 2GB kość RAMU w moim ASUSie K52F na jakąś 4GB. Oryginalna kość to: A-Data ad73i1b1672eg.
Skan z CPU-Z:
Chipset
Northbridge Intel Havendale/Clarkdale Host Bridge rev. 18
Southbridge Intel HM55 rev. 06
Memory Type DDR3
Memory Size 2 GBytes
Channels Single
Memory Frequency 532.1 MHz (4:16)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Row Refresh Cycle Time (tRFC) 60
Command Rate (CR) 1T
Host Bridge 0x0044
Host Bridge 0x2C62
Host Bridge 0x2D01
Host Bridge 0x2D10
Host Bridge 0x2D11
Host Bridge 0x2D12
Host Bridge 0x2D13
Memory SPD
DIMM # 1
SMBus address 0x52
Memory type DDR3
Module format SO-DIMM
Module Manufacturer(ID) A-Data Technology (7F7F7F7FCB000000000000)
Size 2048 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number AD73I1B1672EG
Manufacturing date Week 29/Year 10
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 03 02 11 00 09 03 52 01 08 0C 00 3C 00
10 69 78 69 30 69 11 20 89 70 03 3C 3C 00 F0 83 05
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 05 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 04 CB 01 10 29 00 00 00 00 A1 11
80 41 44 37 33 49 31 42 31 36 37 32 45 47 20 20 20
90 20 20 00 00 00 00 00 00 31 33 30 30 32 38 32 31
A0 00 00 00 00 53 33 36 48 33 4A 34 31 5A 31 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 05 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Mainboard Model K52F (0x000000F8 - 0x00002870)
Kupiłem taką i po wymianie starej na nową komputer nie chce się włączyć. Pamięć tą kupiłem sprawdzając wcześniej parametry ale najwidoczniej czegoś musiałem nie dopatrzyć. Proszę o wskazanie mojego błędu i pomoc w wyborze prawidłowej kości.
Z góry dziękuję za pomoc.
Edytowane przez szakala
Tylko niektóre moduły 4GB zadziałają na tej platformie.
Szukasz tych, które mają na sobie 16 kości (tzw. dual rank - szukaj też oznaczeń 2Rx8 albo 256×8).
Kupiony moduł to single rank, dlatego nie działa.
Kupiłeś GR1333S364L9S/4G, a przykładowy kompatybilny goodram ma oznaczenie GR1333S364L9/4G. Ale na dobrą sprawę wystarczy cokolwiek, byle dual rank. Taktowanie ram i tak nie będzie wyższe niż 1066MHz, co widzisz na przykładzie obecnego modułu.
Dzięki za szybką odpowiedź. Raczej mało prawdopodobne by jakakolwiek kupiona przeze mnie kość 4GB mogła współdziałać z oryginalną 2GB, czy dobrze myślę? Czy łączenie dwóch kości, różnych producentów i różnych rozmiarów jest w ogóle możliwe, a jeżeli tak, to czy przynosi to jakiś wymierny efekt?
Nie kość tylko moduł. Kości to te czarne prostokąciki znajdujące się na module.
No wręcz przeciwnie - zwykle przy łączeniu dwóch różnych modułów problemów nie ma. Czasami się zdarzają jakieś niekompatybilności, ale na tyle rzadko, że zawsze warto najpierw spróbować połączyć dwa różne moduły.
Niezależnie od wszystkiego, 4GB które kupiłeś i tak nie zadziała. Zwróć i wymień na kompatybilny z platformą.
OK. Czyli brać tego GOODRAMa, którego podałeś jako przykład, czy może szukać czegoś innego?
Absolutnie cokolwiek, byle spełniało wymagania (w przypadku modułu 4GB musi być dual rank).
Poza oczywistą oczywistością, czyli format laptopowy (so-dimm), ddr3 (ddr3l też będzie ok).
Edytowane przez MitycznyJeż
