Forum PCLab.pl: Trzeszczenie i pukanie. - Forum PCLab.pl
Strona 1 z 1
Trzeszczenie i pukanie. Problem z dźwiękiem. Oceń temat: -----
#1 Użytkownik jest niedostępny   PatD17th
  • Dyskutant
  • PipPip
  • Postów: 78
Napisany 04 Październik 2019 - 17:53
Publikowałem już na innym forum ale zagranicznym, wstawię oryginał.
PC: -Ryzen 7 2700x, -GTX 1080 Gigabyte 8GB vram, -Kingston HyperX DDR4 3200Mhz 16GB, -Gigabyte Aorus x470 Ultra Gaming, -Two Seagates 1TB HDD, -One SSD Crucial 120GB, -Win 10 Home 64,
Everything is up to date, nothing is overclocked, everything is stock. The problem is that whenever I speak with someone on the Discord their sound pop and crackle, the same thing is in ArmA3 etc. It's so fu* annoying I can't play normally.
LatencyMoon doesn't see any problems but InDepthLatency running for 8 minutes a Tight Loop Latency everything is RED.
Every spec and devices: https://imgur.com/a/Wh4tvOE
PLS HELP, I don't know what to do (this problem is almost a year long).
RAPORT:
REPORT
In Depth Latency Tests has been analyzing your system for 0:08:23 (h:mm:ss) on all processors in the system.
Test performed: Tight Loop Latency Test at HIGH_LEVEL IRQL Tight Loop Latency Test at HIGH_LEVEL IRQL: measure SMIs and CPU stalls. Run test with all maskable interrupts disabled. NOTE: SMIs that are initiated by software have not been measuded.
Highest latency measured: 211,0 µs This value reflects the highest measured interruption interval of a tight loop spinning at HIGH_LEVEL interrupt request level.
PER CPU MEASURINGS
Highest latency on CPU 0: 209,50 µs Highest latency on CPU 1: 209,30 µs Highest latency on CPU 2: 208,20 µs Highest latency on CPU 3: 208,30 µs Highest latency on CPU 4: 209,10 µs Highest latency on CPU 5: 209,0 µs Highest latency on CPU 6: 208,50 µs Highest latency on CPU 7: 208,50 µs Highest latency on CPU 8: 210,50 µs Highest latency on CPU 9: 210,60 µs Highest latency on CPU 10: 209,90 µs Highest latency on CPU 11: 209,80 µs Highest latency on CPU 12: 211,0 µs Highest latency on CPU 13: 102,10 µs Highest latency on CPU 14: 210,10 µs Highest latency on CPU 15: 210,10 µs
SYSTEM INFORMATION
Computer name: DESKTOP-NOA5J5A OS version: Windows 10 , 10.0, build: 17763Highest latency on CPU 15: 210,10 µs Hardware: X470 AORUS ULTRA GAMING, Gigabyte Technology Co., Ltd., X470 AORUS ULTRA GAMING-CF CPU: AuthenticAMD AMD Ryzen 7 2700X Eight-Core Processor Logical processors: 16 Processor groups: 1 RAM: 16331 MB total
#2 Użytkownik jest niedostępny   PatD17th
  • Dyskutant
  • PipPip
  • Postów: 78
Napisany 09 Październik 2019 - 23:56
Zero odpowiedzi? XD
Strona 1 z 1
