Forum PCLab.pl: Asrock 880G Pro3 - Forum PCLab.pl
Strona 1 z 1
Asrock 880G Pro3 jedna z pierwszych dostępnych płyt AM3+
#1 Użytkownik jest niedostępny   mekk
  • EdytaMAN
  • PipPipPipPip
  • Postów: 672
Napisany 05 Maj 2011 - 09:38
{ten post będzie najprawdopodobniej edytowany}
Specyfikacja:
l CPU- Support for Socket AM3+ processors
- Support for Socket AM3 processors: AMD Phenom™ II X6 / X4 / X3 / X2 (except 920 / 940) / Athlon II X4 / X3 / X2 / Sempron processors
- Supports 8-Core CPU
- Supports UCC feature (Unlock CPU Core)
- 4 + 1 Power Phase Design
- Supports CPU up to 140W
- Supports AMD's Cool 'n' Quiet Technology
- FSB 2600 MHz (5.2 GT/s)
- Supports Untied Overclocking Technology
- Supports Hyper-Transport 3.0 (HT 3.0) Technology Chipset- Northbridge: AMD 880G
- Southbridge: AMD SB850 Memory- Dual Channel DDR3 memory technology
- 4 x DDR3 DIMM slots
- Supports DDR3 2000(OC)/1866(OC)/1800(OC)/1600(OC)/1333/1066/800 non-ECC, un-buffered memory
- Max. capacity of system memory: 32GB*
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS- 32Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, VCCM, NB, SB Voltage Multi-adjustment Audio, Video and Networking Graphics- Integrated AMD Radeon HD 4250 graphics
- DX10.1 class iGPU, Shader Model 4.1
- Max. shared memory 512MB
- Multi VGA Output options: D-Sub, DVI-D and HDMI
- Supports HDMI Technology with max. resolution up to 1920x1200 (1080P)
- Supports Dual-link DVI with max. resolution up to 2560x1600 @ 75Hz
- Supports D-Sub with max. resolution up to 2048x1536 @ 85Hz
- Supports HDCP function with DVI and HDMI ports
- Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback with DVI and HDMI ports Audio- 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
- Premium Blu-ray audio support LAN- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Atheros® AR8151
- Supports Wake-On-LAN
- Supports PXE Expansion / Connectivity Slots- 2 x PCI Express 2.0 x16 slots (PCIE2 @ x16 mode; PCIE3 @ x4 mode)
- 1 x PCI Express 2.0 x1 slot
- 3 x PCI slots
- Supports ATI™ Quad CrossFireX™ , CrossFireX™ and Hybrid CrossFireX™ SATA3- 5 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 0+1 and RAID 5), NCQ, AHCI and "Hot Plug" functions USB 3.0- 2 x USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s Connector- 5 x SATA3 6.0 Gb/s connectors
- 1 x IR header
- 1 x COM port header
- 1 x IEEE 1394 header
- 1 x HDMI_SPDIF header
- 1 x Power LED header
- CPU/Chassis/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports)
- 1 x Dr. Debug (7-Segment Debug LED) Rear Panel I/OI/O Panel
- 1 x PS/2 Keyboard Port
- 1 x VGA/D-Sub Port
- 1 x VGA/DVI-D Port
- 1 x HDMI Port
- 1 x Optical SPDIF Out Port
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x eSATA3 Connector
- 2 x Ready-to-Use USB 3.0 Ports
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- 1 x Clear CMOS Switch with LED
- HD Audio Jack: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone Other Features / Miscellaneous Unique Feature- ASRock Extreme Tuning Utility (AXTU)
- Instant Boot
- ASRock Instant Flash
- ASRock AIWI
- ASRock APP Charger
- SmartView
- ASRock XFast USB
- Hybrid Booster:
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
- Turbo 40 / Turbo 50 GPU Overclocking
- Turbo UCC Smart Switch- 1 x Power Switch with LED
- 1 x Reset Switch with LED
- 1 x Clear CMOS Switch with LED Support CD- Drivers, Utilities, AntiVirus Software (Trial Version), AMD OverDrive™ Utility, AMD Live! Explorer, AMD Fusion, ASRock Software Suite (CyberLink DVD Suite - OEM and Trial; Creative Sound Blaster X-Fi MB - Trial) Accessories- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables (optional) Hardware Monitor- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU/Chassis/Power Fan Tachometer
- CPU Quiet Fan
- CPU/Chassis Fan Multi-Speed Control
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore Form Factor- ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
- All Solid Capacitor design OS- Microsoft® Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit / XP / XP 64-bit compliant Certifications- FCC, CE, WHQL
- ErP/EuP Ready (ErP/EuP ready power supply is required)
Fotogaleria
Dodaj obrazek
Dodaj obrazek
Dodaj obrazek
Dodaj obrazek
płyta w kolorze .... ziemistym jak widać:
Dodaj obrazek
Dodaj obrazek
Przyciski Power i Reset - są tu:
Dodaj obrazek
zalecana kolejność obsadzania gniazd pamięci:
Dodaj obrazek
Dodaj obrazek
Naklejka, jak widać zaraz się zacznie odklejać:
Dodaj obrazek
Dodaj obrazek
Śruby w podzielonym na 2 części koszyku oraz gniazdo AM3b w całej okazałości
Dodaj obrazek
znowu nie zrobiłem zdjęcia tyłu płyty....
"dlaczego właśnie wybrałem tą?"
  • "czarny socket" vel AM3+ vel AM3b
  • radiator na sekcji zasilania (4+1)
  • EPS 8 pin (spożytkowałem FSP500-60GHN) i obsługa procesorów do 140W
  • cena (300 parę zł) i dostępność
  • dyski i napęd DVDRW miałem już na SATA
  • USB 3.0
  • SATA3
  • UEFI (ryzyk-fizyk, nadzieja na szybki rozruch)
  • przycisk Clear CMOS na tylnym panelu
  • przycisk POWER i RESET na płycie
  • 4 wtyczki na wiatraki, w tym dwa 4 pin
  • grafika na płycie (miałem się pozbyć HD4770 i wskoczyć na 5850, jednakże ułożyło się inaczej)
  • łatwo demontowalny koszyk i backplate (beż żadnych kołeczków, tylko normalne śruby)
  • możliwość (od)blokowania rdzeni
  • wszystkie kondensatory typu SOLID (są mniejsze :))
... w toku pierwszych tygodni użytkowania:
Pierwsze minusy: :thumbdown:
  • skreślony minus: wyszło, że to pamięci problemy użytkownika Soulson klik
  • problem z pamięciami na 1600 - tylko przy małym oc (230) można uruchomić sprzęt (szyna źle ustawiona?)
  • pamięci na 1333Mhz dostają 1.65v mimo że spd chce 1.5V
  • szyna HT ustawiona przy OC na 1800Mhz, pod odkręceniu niemożliwe był powrót do standardowych 2000Mhz (pomógł reset cmos)
  • profile oc nie zapisują ustawień z innych zakładek
  • czasem klawisz DEL nie działa aby wejść do bios i trzeba użyć F2
  • sterowanie wiatrakami nie do końca działa (nie potrafi regulować jednego wiatraka, podnosi obroty wiatraka na proc tylko w trakcie grzania w bios, nie w trakcie pracy windowsa) - to muszę zweryfikować czy przypadkiem speedfan po zamknięciu nie ustawia obrotów na sztywno)
  • SENSORS nie wykrywa czujników [LINUKS]
  • HWMONITOR nie wykrywa wentylatorów
  • płyta to pełny ATX, co przy umiejscowieniu 4 z 6 gniazd SATA stanowić może w płytkich obudowach spory problem (mojego 8 letniego czołgu to nie dotyczy)
  • brak ATA (czasem może się przydać)
  • gniazdo eSATA3 na tylnym panelu jest niemal bezużyteczne (bo gdzie wyprowadzenie zasilania?)
  • brak pełnej papierowej instrukcji
  • mostek południowy wymaga ruchu powietrza
  • krzywo zamontowane wtyczki na dodatkowe USB, podobnie krzywo dławiki...
  • po co są te odobne blaszki na radiatorach mostków?
  • naklejka na płycie "880G Pro3" zaraz się odklei (plus: zobaczę co jest pod nią)
  • średnio oznakowane wyprowadzenia dla przycisku POWER i diody HDD/POWER
Pierwsze plusy: :thumbup:
  • stabilne CL7 na ciut poniżej 1333Mhz (240Mhz)
  • UEFI: F12 umożliwia zrzut ekranu, szybki rozruch, "MICE" zamiast "MOUSE" (LOL)
  • dwa gniazda zasilania wiatraków dedykowane CPU (4 pin i 3 pin)
  • już się nie zastanawiam po co mi 2x PCI-Express (... REVODRIVE! ;-))
  • pamięci w DUALu nie muszą być obok siebie, a same gniazda nie są zbyt blisko przy sobie
OC i testy:
{będzie CPUZ, OCCT, Furmark, Geekbench - ale dopiero jak załatwię sprawę drugiej kości pamięci}
pożyczony Kingston - SPD:
Dodaj obrazek
Doplhin - SPD, jeden moduł wadliwy
Dodaj obrazek
Dodaj obrazek
Płytka zamontowana, obudowa słabo odkurzona, kable średnio poukładane ;-)
Klik
KATOWANIE KOMPA (nadal jeden moduł pamięci):
{wszystko stabilnie}
...procesor, 2 dyski, grafika, nagrywarka
Dodaj obrazek
Odpalenie uninstallera Xpand Rally zamuliło system na tyle, że zaraz dałem spokój dalszym testom:
Dodaj obrazek
Jak widać najbardziej grzeje Furmark plus prime95 (CPU-64 stopnie, System - 46 stopni):
Dodaj obrazek
Mam już dwa moduły pamięci, ale ustawiam jeszcze timingi.... z przygodami bo płyta sama ustawia je tak, że memtest wywala błędy, dodatkowo przy ręcznych timingach (w tym 1T) miałem dopiero po dłuższym czasie użytkowania kompa BSOD w trakcie zamykania systemu (....przede mną zapoznanie się z BlueScreenView)
KATOWANIE KOMPA (już dwa moduły pamięci):
Furmark, prime95, Crystal na dyski, Nero (CPU- stopnie, System - stopni):
{będzie za jakiś czas}
Dodaj obrazek
Mój link - chłodny dzień [widać po temperaturze system], jeszcze na 3600Mhz (pamięci przy głównej szynie 240Mhz są poniżej 1333Mhz, napięcie cpu podbite o "jedno oczko")
aktualnie testuję 3500Mhz, pamięci 1333Mhz CL9, główna szyna na 250Mhz, mnożnik na 14 i napięcie obniżone o 0,025V w stosunku do domyślnych 1.4V - jest chłodniej i właściwie tak samo wydajnie (np. Geekbench nie wykazuje różnic wartych uwagi) :
Dodaj obrazek
Mój link
Mój link
CL9 := CL8 - chwilowo działa, ~3,5% szybciej kompresuje XVID 1.3.1, więc fajnie :-)
{z 2 godzin kompresji robi się 1h i 55,8 minuty LOL}
1.35V, nadal CL8 i 3500Mhz, stabilnie, choć przede mną ponowne testy OCCT, tak dla pewności
Ten post był edytowany przez mekk dnia: 13 Czerwiec 2011 - 10:54
#2 Użytkownik jest niedostępny   JoHnNy08PL
  • Johnny Drama
  • Postów: 1949
Napisany 06 Maj 2011 - 12:56
Zobacz postmekk, o 05 Maj 2011 - 10:38, napisał(a):
Naklejka na płycie "880G Pro3" zaraz się odklei (plus: zobaczę co jest pod nią)
Może znów będzie tak: Dodaj obrazek
:lol2:
#3 Użytkownik jest dostępny   Mroczny Nelu
  • Makankosappo
  • Postów: 14898
Napisany 06 Maj 2011 - 13:11
No przecież tak właśnie jest :E
#4 Użytkownik jest niedostępny   Seba5959
  • Dyskutant
  • PipPip
  • Postów: 18
Napisany 12 Maj 2011 - 14:04
Planuję kupno tej płyty. Polecacie ją? Czy lepiej poszukać coś innego?
#5 Użytkownik jest niedostępny   EpicLulz!
  • Gaduła
  • PipPipPip
  • Postów: 406
Napisany 23 Maj 2011 - 20:59
Ja również planuję zakupić tę płytę, czy EFI to jest ten kolorowy BIOS sterowany myszka?
#6 Użytkownik jest niedostępny   mekk
  • EdytaMAN
  • PipPipPipPip
  • Postów: 672
Napisany 24 Maj 2011 - 08:08
a czemu nie? :thumbup:
tak
galeria tu:
http://www.fotosik.p...12/album/835017
#7 Użytkownik jest dostępny   Mroczny Nelu
  • Makankosappo
  • Postów: 14898
Napisany 25 Maj 2011 - 10:57
Z minusów można już wyrzucić "problemy użytkownika soulson" - problemem okazały się uwalone pamięci, nie płyta.
#8 Użytkownik jest niedostępny   mekk
  • EdytaMAN
  • PipPipPipPip
  • Postów: 672
Napisany 13 Czerwiec 2011 - 11:09
Zobacz postGalvatron, o 05 Lipiec 2011 - 18:32, napisał(a):
Od dwóch lat używam Ubuntu i nigdy nie miałem z Flashem problemów, poza oczywistą kwestią mułowatości tego badziewia.
:lol2:
no prawie BINGO!
Asrock 880G pro3 = Asrock 890GX pro3 // Edyta: na wnioski odnośnie pełnej tożsamości jeszcze przyjdzie :-)
http://www.asrock.co...Model=880G Pro3
http://www.asrock.co...odel=890GX Pro3
Dodaj obrazek
Dodaj obrazek
Summa summarum po kilku tygodniach:
:thumbdown:
  • po co są te ozdobne blaszki na radiatorach mostków?
  • konfiguracja pamięci 2x2GB plus 2x4GB wymusiła CL9 (brak czasu + 8GB mi wystarczy - wywaliłem 2x2GB, mam CL8)
:thumbup:
  • stabilne CL7 na ciut poniżej 1333Mhz (240Mhz), CL8 na 1333Mhz (250Mhz)
  • po aktualizacji nie robi już wrażenia niestabilnego badziewia :-)
  • przycisk clr cmos przy tylnych gniazdach czasem się przydaje
Do sprawdzenia przy okazji (BIOS/UEFI mam nowe, więc te problemy to już może tylko przeszłość):
Przy undervoltingu wychodzi, że system 64 bitowy wymaga więcej napięcia na rdzeniach :-)
//roboczo wytłuściłem to co dodałem w lipcu 2011
W 1680x1050 jak widać klatek nie jest dużo (3625Mhz, hd4770, w7), ale silnik nie jest tak nastawiony na 60fps jak np. Burnout Ultimate Paradise i grać się da - jadąc w bardziej urozmaiconej scenerii, z kilkoma widocznym przeciwnikami ilość klatek zauważalnie spada (czyżby procesor nie wyrabia? Mój link ) - czeka mnie jego wymiana, dalsze OC, a może wymiana grafiki (bezkosztowo: zejdę z rozdzielczością :E)
Dodaj obrazek
Mój link :E
Ten post był edytowany przez mekk dnia: 01 Sierpień 2011 - 14:44
#9 Użytkownik jest niedostępny   Sobol
  • Intel® i7 @ 4.00GHz Club™
  • Postów: 5743
Napisany 13 Czerwiec 2011 - 12:22
Cytuj
nie prawda. Asus tez kiedyś stosował takie naklejki. Prosty przykład Asus P5N32 SLI PLUS a pod naklejką Striker Extreme . I co ? To znaczy że mam P5 czy Strikera ? Oczywiście że P5 bo to na bazie starszego modelu został zrobiony niższy okrojony.
#10 Użytkownik jest niedostępny   mekk
  • EdytaMAN
  • PipPipPipPip
  • Postów: 672
Napisany 13 Czerwiec 2011 - 13:49
Płyty wyglądają tak samo, o ile mnie patrzałki nie mylą, a dodatkowo różnice między chipsetami 880g a 890gx są tak małe, że 880g może okazać się przemienialne w 890gx ...tylko nie wiem jeszcze po co :E... crossfire 8/8 będzie dostępne? {wg www producenta obie są 16/4 ... hmmm}
down
@romo
 - ale właśnie czy warto? co bym zyskał przemieniając na 890GX, nad tym się nadal zastanawiam, ale znając siebie pewnie wcześniej czy później zdejmę radiator, np. żeby przesmarować mostek :E
Ten post był edytowany przez mekk dnia: 13 Czerwiec 2011 - 14:54
#11 Użytkownik jest niedostępny   romo
  • addicted to ....
  • Postów: 7290
Napisany 13 Czerwiec 2011 - 14:19
warto zdjąć radiator i sprawdzić jaki siedzi mostek , czy 880G czy 890GX
#12 Użytkownik jest niedostępny   Sobol
  • Postów: 5743
Napisany 13 Czerwiec 2011 - 19:49
down
@romo
Laminat strikera i P5 odróżniał tylko radiator i naklejka oraz przyciski do startu , resetu i wyczyszczenia biosu ;)
#13 Użytkownik jest niedostępny   Nielot2
  • Gaduła
  • PipPipPip
  • Postów: 236
Napisany 12 Grudzień 2011 - 11:56
Czy integra na tej płycie działa bezproblemowo po HDMI ?
Strona 1 z 1
