Doctor Malik
[Zamknięty]SZAFA MALIKA
SZAFA MALIKA:
INNE:
1. Asus Strix GTX 970 OC – 1200 PLN - DyndaS
2. Fractal Design Define S (bez okna) – 200 PLN
3. Cooltek W2S – 200 PLNZizu32
4. Phanteks Evlov Mini (bez okna, ITX) – 200 PLN
5. Cryorig H5 Ultimate – 100 PLN - Plastek
6. Cryorig A80 – 200 PLN
WENTYLATORY:
1. Fractal Design Dynamic GP-12 x 7 – 20 PLN/szt. - DyndaS - 5-7 sztuk
2. Fractal Design Venturi HP-14 x 3 - 40 PLN/szt. - DyndaS - 1 sztuka
3. Cougar CF-D12HB-B x 5 – 30 PLN/szt.
4. Cougar CF-D14HB-B x 3 – 30 PLN/szt.
5. Be Quiet Pure Wings 2 120 mm x 2 – 25 PLN/szt.
6. Be Quiet Pure Wings 2 140mm x 2 – 25 PLN/szt.
7. Cryorig QF 120 Balance – 30 PLN – Zizu32
WC:
1. EAN: 3831109869451 - EK-FC970 GTX Strix – Nickel – 300 PLN
2. EAN: 3831109869482 - EK-FC970 GTX Strix Backplate – Nickel – z blokiem gratis
3. EAN: 3831109800065 - EK-Supremacy EVO – Nickel – 200 PLN
4. EAN: 3831109843062 - EK-XRES 100 Revo D5 PWM (incl. pump) – 400 PLN - DyndaS
5. EAN: 3831109860304 - EK-CoolStream SE 240 (Slim Dual) – 100 PLN - DyndaS
6. EAN: 3831109860311 - EK-CoolStream SE 360 (Slim Triple) – 150 PLN - DyndaS
7. EAN: 3830046997999 - EK-UNI Pump Bracket (120mm FAN) Vertical – 20 PLN - DyndaS
8. EAN: 3830046999658 - EK-Ekoolant EVO UV BLUE (premix 1L) – 25 PLN
9. EAN: 3830046999689 - EK-Ekoolant EVO CLEAR (premix 1L) – 25 PLN
10. EAN: 3831109846599 x 10 - EK-ACF Fitting 12/16mm – Blue – 10 PLN/szt.
11. EAN: 3831109846544 x 10 - EK-ACF Fitting 12/16mm – Nickel – 10 PLN/szt.
12. EAN: 3831109846605 x 10 - EK-ACF Fitting 12/16mm – Black – 10 PLN/szt. - DyndaS 6 sztuk
13. EAN: 3831109850619 - TUBE PrimoChill PrimoFlex™ Advanced LRT™ 15,9 / 11,1mm
- Crystal Clear RETAIL 3m – 20 PLN - DyndaS
14. EAN: 3831109850640 - TUBE PrimoChill PrimoFlex™ Advanced LRT™ 15,9 / 11,1mm
- Onyx Black RETAIL 3m – 20 PLN – Zizu32
15. EAN: 3830046997982 - EK-UNI Pump Bracket (120mm FAN) – 20 PLN - DyndaS
16. EAN: 3831109845288 x 5 - EK-AF Angled 90° G1/4 Black – 15 PLN/szt. - DyndaS 4 sztuki
17. EAN: 3831109845264 x 3 - EK-AF Angled 90° G1/4 Nickel – 15 PLN/szt.
18. EAN: 3831109845233 x 4 - EK-AF Angled 45° G1/4 Nickel – 15 PLN/szt.
19. EAN: 3830046999269 x 4 - EK-CSQ Plug G1/4 (for EK-Badge) – Nickel – 45 PLN
20. EAN: 3830046999283 x 4 - EK-CSQ Plug G1/4 (for EK-Badge) – Black – 45 PLN - DyndaS 3 sztuki
Informacje dodatkowe:
- płatność przelewem lub odbiór własny na terenie Bielska-Białej
- wysyłka kurierem UPS 15PLN
- przy większym zamówieniu - rabat
I jak inni mieliby się rozmyślić:
Dam znać czy biorę jutro koło popołudnia :)
Biorę A80, o ile jeszcze jest dostępny. PW wysyłałem po 11.30.
Po tygodniu będzie wolny, chcę go tylko na testy :D
To jak jeszcze się ostanie to ja biorę Cryorig A80.
Wiem, jakby Lipton może zrezygnował. Sypie mi się chłodzenie Cryorig właśnie. Chyba łożyska poszły lekko. Tu nawet bym nie musiał backplate zdejmować.
EK-UNI Pump Bracket (120mm FAN)[/s] – 20 PLN - DyndaS
Jeśli Dyndas się rozmyśli to biorę.
DyndaS już pozamiatał wszystko :E
I to jeszcze przed założeniem tematu :E
8:E 8:E 8:E
