Yab
[Win 7]BSODy od pewnego czasu
Od pewnego czasu mam BSODy. Tutaj zrzut:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.19045.amd64fre.win7sp1_gdr.151019-1254
Machine Name:
Kernel base = 0xfffff800`02a1e000 PsLoadedModuleList = 0xfffff800`02c65730
Debug session time: Fri Feb 26 19:23:07.009 2016 (UTC + 1:00)
System Uptime: 0 days 0:56:20.852
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 50, {fffff8000000fbcf, 0, fffff8000000fbcf, 0}
*** ERROR: Module load completed but symbols could not be loaded for athurx.sys
Probably caused by : athurx.sys ( athurx+9f3bb )
Followup: MachineOwner
3: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff8000000fbcf, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff8000000fbcf, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000000, (reserved)
Debugging Details:
READ_ADDRESS:  fffff8000000fbcf
FAULTING_IP:
+6535313565366132
fffff800`0000fbcf ??              ???
MM_INTERNAL_CODE:  0
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x50
PROCESS_NAME:  System
CURRENT_IRQL:  0
TRAP_FRAME:  fffff880062048a0 -- (.trap 0xfffff880062048a0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8000000fbcf rsp=fffff88006204a30 rbp=0000000000000000
r8=fffffa80069f1b48  r9=0000000000000000 r10=fffffffffffffff7
r11=0000000000cce170 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei ng nz na pe nc
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002b0e297 to fffff80002a91c40
FAILED_INSTRUCTION_ADDRESS:
+6535313565366132
STACK_TEXT:
fffff880`06204738 fffff800`02b0e297 : 00000000`00000050 fffff800`0000fbcf 00000000`00000000 fffff880`062048a0 : nt!KeBugCheckEx
fffff880`06204740 fffff800`02a8fd6e : 00000000`00000000 fffff800`0000fbcf 00000000`00000000 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x417df
fffff880`062048a0 fffff800`0000fbcf : 2004622c`408f0089 fffff880`068ad3bb fffffa80`00000000 00000000`00004048 : nt!KiPageFault+0x16e
fffff880`06204a30 2004622c`408f0089 : fffff880`068ad3bb fffffa80`00000000 00000000`00004048 fffff880`00000000 : 0xfffff800`0000fbcf
fffff880`06204a38 fffff880`068ad3bb : fffffa80`00000000 00000000`00004048 fffff880`00000000 00000000`00000000 : 0x2004622c`408f0089
fffff880`06204a40 fffffa80`069f1ac0 : 00000000`00000080 fffff880`02f69f40 00000000`00000000 fffff880`06814eb0 : athurx+0x9f3bb
fffff880`06204a80 00000000`00000080 : fffff880`02f69f40 00000000`00000000 fffff880`06814eb0 fffffa80`09fab030 : 0xfffffa80`069f1ac0
fffff880`06204a88 fffff880`02f69f40 : 00000000`00000000 fffff880`06814eb0 fffffa80`09fab030 00000000`00000001 : 0x80
fffff880`06204a90 00000000`00000000 : fffff880`06814eb0 fffffa80`09fab030 00000000`00000001 fffffa80`069f1ac0 : 0xfffff880`02f69f40
STACK_COMMAND:  kb
FOLLOWUP_IP:
athurx+9f3bb
fffff880`068ad3bb 89442420        mov     dword ptr [rsp+20h],eax
SYMBOL_STACK_INDEX:  5
SYMBOL_NAME:  athurx+9f3bb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: athurx
IMAGE_NAME:  athurx.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4daeb071
FAILURE_BUCKET_ID:  X64_0x50_CODE_AV_BAD_IP_athurx+9f3bb
Z tego co się dokopałem na googlu to może być to związane z sieciówką. Używam karty wifi pod USB, konretnie TP-Link TL-WN722NC. Ktoś miał podobny problem? Dodam, że coś nie do końca jest ok z tą kartą sieciową. Często gubi sieć, albo w ogóle się wyłączy. Mam ustawione USB żeby nigdy nie odłączał zasilania, ale to nie pomaga.
