olivvierr007
Witam podkrecanie i7 920 pomoc
Witam znalazłem na forum poradnik jak podkręcić i7 920 na płycie Asus P6X58D lecz po zrobieniu tego zawiesza mi się przy ładowaniu widowsa możne ktoś by poradził coś poniżej ustawienia których próbowałem użyć
1.
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21.0]
Intel® SpeedStep Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[172]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1379MHz]
UCLK Frequency.........................[2758MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.10625]
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.20000]
IOH Voltage............................[1.12]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel® Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel® HT Technology.................[Disabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel® C-STATE Tech..................[Disabled]
2 ustawienia
CPU Voltage............................[1.11875]
QPI/DRAM Core Voltage..................[1.20625]
IOH Voltage............................[1.14]
Intel® HT Technology.................[Enabled]
W obu przypadkach się zawiesza przy ładowaniu widowsa za porady z góry dziękuje
Przypuszczam, ze za niskie V.
Spróbuj obniżyć mnożnik czy ruszy.
CPU Ratio Setting......................[20.0]
W razie czego
CPU Voltage............................[1.11875] - wyżej.
IOH CORE spróbuj wyżej - czasami pomaga przy podnoszeniu BCLK.
Reszta wygląda dobrze.
W razie czego
Witam
zrobilem tak i niestety po okolo 15 minutach mam blue screen jakies pomysly jeszzce :>?
podbijaj delikatnie napięcie, skoro 15 min wytrzymał, 99% szansy, że za mało papu dostaje
Mój przy 4,5ghz i 1,36v sie wykrzaczał po paru godzinach gry w BF1, podbiłem do 1,37v (0,01v) i jest gitara
Pytanie jaka rewizja procesora, najnowsza D0 ma o wiele lepszy potencjał OC.
Miałem kiedyś C1 i były problemy powyżej 18x200.
Spróbować możesz ustawić mnożnik x20 a bclk 166 i jedź z bclk w górę co 3-4 MHz.
QPI ustaw na sztywno najniższy mnożnik.
Ostatnio podkręcałem i7 920 C0/C1 i około 3,8 ghz da radę i więcej, jednak napięcie procesora to nawet powyżej 1,4V (nie zbijałem jeszcze, temperatury trochę wysokie, ale muszę zmienić pastę)
CPU V - do 1,5
CPU PLL - do 2.0
QPI/DRAM - do 1.6/1.7 mój niezły farmazon
IOH - do 1.3
płyta to px658d-p, chłodzenie fortis 3
na internetach masz dużo informacji sprzed paru lat, a także chyba na polskim pure pc jakiś obszerny poradnik do wielu platform, są tam podane w miarę bezpieczne wartości z objaśnieniem
Zdecydowanie za niskie napięcie, daj od razu 1,3 i zobacz jak działa w jakimś benchu. Jakie masz chłodzenie i pastę?
Oczywiście C0/C1 też się kręcą.
Ale czy jest sens żyłować proca? U mnie C1 @ 3.6 potrzebowało 1.38-1.39V gdzie na D0 robiłem 4GHz na 1.35V od ręki.
hehe, dlatego jakbym miał niedługo zmieniać proca to kupię sobie jakiegoś 930/950/960 lub nawet 970, dosłownie za grosze. A zmiana platformy najwcześniej jak intel tą swoją nową architekturę wprowadzi w 2020;O
racja po wielu próbach z temperaturami, całkiem możliwe, że będę musiał zejść do 3,6/3,7 (teraz jest zima więc i powietrze w domu chłodniejsze), a maksymalna wydajność przyda się tylko przy sporadycznym gierczeniu, jednak na napięciu 1.11 nikt nie wątpi, że to się uda.
C0/C1 Strasznie oporne napięcie jakie u mnie potrzebne do 4 ghz z włączonym HT 1.41v temp 78/80 stopni
Jak jeszcze tu zajrzysz, to mój poprzedni post możesz włożyć między bajki, pisałem już wcześniej, ale mi komputer zawiesiło.
CPU V - do 1,5 (można i tyle, jednak warto ograniczyć napięcie do 1.35
CPU PLL - do 1.89 (maksymalne; 1.82, lub 1.84 może w zupełności wystarczyć)
QPI/DRAM - do 1.35 (jednak to jest już maksymalna wartość i tak jak agent_x007 napisał)
IOH - to także podnosiłbym niewiele ponad minimalne napięcie
u mnie 3.6ghz działa na 1.3V, natomiast na 3.68, 3.72ghz, potrzebuję już około 1.33V i pojawia się problem z temperaturami. Zastanawiam się, czy nie dać czasem nawet ok. 3.8ghz, jeżeli potrzebowałbym minimalnie więcej podczas jakiejś gry, która w końcu nie rozgrzeje mi aż tak procesora jak prime.
Witam wszystkich chwile mnie nie bylo i nawet nie widzialem ze post tak ożył :) ustawiłem na na 1.30 i przestało wyrzucać
Wyżej niż 3.5 nie chce kręcić bo za cholerę nie wiem jakie mam chłodzenie procesora wsadzone nic nie pisze i wygląda tak średnio wiec wole nie ryzykować :)
w każdym razie dziękuje wszystkim za porady :)
jeszcze takie małe pytanie jakie max przewidywane temperatury tego procesora można uznać za bezpieczne ?
    • Ciekawy filozoficzny post, ja to odbieram inaczej - 9800X3D potrafi być 30% szybszy od 7800X3D i to przyrost w 18 miesięcy. Jeżeli upgrade dokonujesz w tej samych "widełkach" wydajnościowych zmieniajac starsze i5 na nowsze i5 to przyrost potrafi być przez 2 lata mniejszy niż nawet 5% za to energetycznie bywa że jest 30% lepiej, ostatecznie jest to jakaś ewolucja - pamiętaj że rozwój technologii jest iteratywny i polega na małych przyrostach które ostatecznie składają się na coś wielkiego ale ostatecznie masz rację - i7-2600 do dzisiaj może stanowić podstawę użytecznego komputera biurowego, skylake posłuszy pewnie i do 2030 w takich celach. Rasteryzacja w kartach graficznych faktycznie stoi nieco w miejscu, nVidia próbuje zrewolucjonizować rynek vendorlockowymi technikami jak swoje DLSSy, ostatecznie doprowadzi to do stagnacji gdzie bez zamydlonego ekranu nie pogramy w 4K, silniki graficzne też nie rozwijają się w oczekiwanym tempie - unity rozpadło się przez kiepski zarząd, unreal engine 5 to król mikroopóźnień, od zakończenia akceleracji sprzętowej dźwięku w windows vista (okolice 2007) nie było w audio żadnej rewolucji a wręcz ewolucji - id Tech to do dzisiaj jedyny engine który potrafi wyrysować łuk a nie koła z nakładanych trójkątów... Także sygnałów że branża kuleje nigdy nie brakowało - grunt to realizować swoje cele i jak tak jak ja od lat 2000 celujesz w średnią półkę cenową - szukać takich upgrade które faktycznie coś dają no i mieć świadomość że rtx 5090 to będzie 600w potwór z gddr7 i ceną na poziomie 12000 pln, takiej wydajności w kartach do 2000zł nie zobaczymy do 2030r. Pamiętam WOW jakie zrobił na mnie Teoria Chaosu splinter cella (mądrze zaprogramowana gra działająca również na konsolach) Far Cry 1 (był nieziemski na premierę) Crysis wyrywał z butów (8800gtx ledwo dawał radę), wszystko potem to sidegrade z momentami które pokazywały że 200 mln usd budżetu może dać jakościowy tytuł jak Red Dead 2, przez ostatnie 20 lat dobrych gier pctowych nie brakowało ale większość to ciągły sidegrade niepotrzebujący najmocniejszych sprzętów, dobieranie timingów pamięci to zawsze była nieco sztuka dla sztuki
