Vendrak
Nowy 3DMark na horyzoncie
Nigdy nie przepadałem za tego typu benchmarkami, ale graficznie zapowiada się miodzio :)
link
To trochę chore, ciągła zabawa benchmarkami, założę się, że większość osób nie gra w gry a w 3DMarka.
Gość ŁIKENDMAN
Fiu Fiu czekamy czekamy :E
to widzieliśmy w 2005:
Game Test 2 - Firefly Forest
Surface and object material shaders using Blinn-Phong reflections; exponent calculations use texture lookups rather than arithmetic operations.
Sky material uses a procedural scattering shader.
Perspective shadow mapping.
Light from the Moon casts shadows into a 2048 x 2048 D24X8 depth stencil texture or R32F depth texture.
Depth textures sampled via hardware-supported percentage closest bilinear filtering or 4 sample point filtering if PCF is not supported.
Light from the firefly uses a cubic depth texture 512 x 512 x 6 in size to cast shadows with.
Average polygon count is 1.8 million; average vertex count is 2.3 million.
Approximately 140MB of video memory is used.
Game Test 3 - Canyon Flight
Rock material shader utilises multiple colour and normal maps to provide Lambertian diffuse lighting.
Water material shader applies reflection and refraction, as well as Fresnel and depth fog.
Sky material shader applies procedural light scattering.
Volumetric fog is used in the sky.
The Sun provides a single directional light source that casts shadows using a 2048 x 2048 D24X8 DST or R32F depth texture.
Approximately 130MB of video memory is used.
a to bedzie w 2006:
HDR rendering.
Complex HDR post processing.
Dynamic soft shadows for all objects.
Water shader with HDR refraction, HDR reflection, depth fog and Gerstner wave functions.
Heterogeneous fog.
Atmospheric light scattering.
Realistic sky model with cloud blending.
Strauss lighting model for most materials.
Subsurface scattering shader for some objects (not visible in the shot).
Texture & normal map sizes: 1024 x 1024 to 2048 x 2048.
Approximately 5.4 million triangles and 8.8 million vertices.
odrazu trzeba napisać na serii x700-8xx nie pójdą wszystkie testy ale co z tego jak i tak na serii gf6 bedzie straszna faza(chyba że sli) , ilość trójkątów i verteksów powala i to nieszczesne soft shadows(strasznie zamula) , w nastepnym 3dmarku jeszcze bardziej cpu bedzie odciążony , a gpu obciażony(akurat mnie to nie cieszy , ale chociaż gry są inaczej robione)
Gość DDiablo
W 2005 mam kolo 1500 ptk, boje sie kilkac :P
nie boj sie tam tylko jest fotka :P
Fotki ladniutkie :)
Znowu beda lamenty dlaczego jak mam tylko XXXX pkt w nowym 3dsmarku :E
Fotki ladniutkie :)
No przesadzasz już (z tymi czterowam X-ami) :P
to bedzie test dla całego kompa wiec myśle że walka bedzie zacieta kto bedzie miał najwiecej punktów w nowym 3dMarku. oj bedzie sie działo :thumbup:
genialny screen ustawiłem go sobie na pulpicie :P;) Narazie moge pomazyc u uruchomieniu 3d marka 2007 , choc do czasu jego wydania moze cos sie zmieni :D
walić nowego 3D marka :P bo coś czyje że bedę w nim miał 3 X'owy wynik ;)
Etam ja będę miał 3 X-owy. :E
ciekawe cy zobaczy chcocuaż 1/3 testów i wynik będzie wyższy niż 300pkt. slideshow oczywiście gwarantowany :E
No raczej wiecej to nie, bo twoja grafa nie obsluzy niektorych testow.
P.
te fale jakies takie nienaturalne :-)
takie proste sa tylko spotykane w sztucznych zbiornikach a nie w przyodzie (no choba ze na wodach o duuzej glebokosci)
ale fajnie ze sa
ale fajnie ze sa
nienaturalne ale robią wrażenie :P
Hm... w 3dmarku03 miałem ok. 10 k pkt ..... w 3dmarku05 miałem 4600 .... czyli w 07 bede miał ok. 2000-2500 okt :E ale cienizna :D
Ciekawe jak bedzie z grywalnoscia. Jesli ok to sobie kupie :rotfl:
