andruty
xorg.conf pod gentoo na laptopie
Mam laptopa Toshiba satellite 55 s106. Zainstalowałem gentoo (2 stage) , sciągnełem X11 i stworzyłem xorg.conf komendą Xorg -configure. wyskakiwał błąd z myszą (że nie może znaleźć), więc poprawiłem plik, który powstał, posługując się wskazówkami ze stron http://gentoo.pl/content/view/146/ ; http://www.gentoo.org/doc/en/usb-guide.xml i http://www.gentoo.org/doc/en/xorg-config.xml ( części o myszach). W ostatecznosci wygląda to tak:
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "USBmouse" "CorePointer"
InputDevice "TouchPad" "SendCoreEvents"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/usr/lib/X11/rgb"
ModulePath "/usr/lib/modules"
FontPath "/usr/share/fonts/misc/"
FontPath "/usr/share/fonts/TTF/"
FontPath "/usr/share/fonts/Type1/"
FontPath "/usr/share/fonts/CID/"
FontPath "/usr/share/fonts/75dpi/"
FontPath "/usr/share/fonts/100dpi/"
EndSection
Section "Module"
Load "extmod"
Load "dri"
Load "dbe"
Load "record"
Load "xtrap"
Load "glx"
Load "type1"
Load "freetype"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
Option "XkbRules" "xorg"
EndSection
Identifier "TouchPad"
Driver "synaptics"
Option "Driver" "/dev/input/mouse1"
Option "Protocol" "event"
Option "LeftEdge" "1900"
Option "RightEdge" "5400"
Option "BottomEdge" "1800"
Option "TopEdge" "3900"
Option "FingerLow" "25"
Option "FingerHigh" "30"
Option "MaxTapTime" "180"
Option "MaxTapMove" "220"
Option "VertScrollDelta" "100"
Option "MinSpeed" "0.12"
Option "MaxSpeed" "0.18"
Option "AccelFactor" "0.0010"
EndSection
Identifier "USBmouse"
Driver "mouse"
Option "Protocol" "ExplorerPS/2"
Option "Device" "/dev/input/mouse2"
Option "Emulate3Buttons" "false"
Option "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "NoAccel" # [<bool>]
#Option "SWcursor" # [<bool>]
#Option "ColorKey" # <i>
#Option "CacheLines" # <i>
#Option "Dac6Bit" # [<bool>]
#Option "DRI" # [<bool>]
#Option "NoDDC" # [<bool>]
#Option "ShowCache" # [<bool>]
#Option "XvMCSurfaces" # <i>
#Option "PageFlip" # [<bool>]
Identifier "Card0"
Driver "i810"
VendorName "Intel Corp."
BoardName "82852/855GM Integrated Graphics Device"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Po komendzie startx wyrzuca okno (czarne) z kursorem myszy , który chwile potem zamienia sie w cielisty kwadracik, z okna nie mozna wyjść ( ctr+alt+f1 nie działa) wszystko sie wiesza, kde się nie pojawia. Co może być przczyną? Może błądze i to nie problem z myszą tylko innym wrednym sprzętem?
dzięki za pomoc
gentoo-wiki.com <- wejdz do dzialu Hardware tam masz opis co i jak z laptopami Toshibe zdaje sie tez tam widzialem
Pozdrawiam
t4o 8)
    • Ciekawy filozoficzny post, ja to odbieram inaczej - 9800X3D potrafi być 30% szybszy od 7800X3D i to przyrost w 18 miesięcy. Jeżeli upgrade dokonujesz w tej samych "widełkach" wydajnościowych zmieniajac starsze i5 na nowsze i5 to przyrost potrafi być przez 2 lata mniejszy niż nawet 5% za to energetycznie bywa że jest 30% lepiej, ostatecznie jest to jakaś ewolucja - pamiętaj że rozwój technologii jest iteratywny i polega na małych przyrostach które ostatecznie składają się na coś wielkiego ale ostatecznie masz rację - i7-2600 do dzisiaj może stanowić podstawę użytecznego komputera biurowego, skylake posłuszy pewnie i do 2030 w takich celach. Rasteryzacja w kartach graficznych faktycznie stoi nieco w miejscu, nVidia próbuje zrewolucjonizować rynek vendorlockowymi technikami jak swoje DLSSy, ostatecznie doprowadzi to do stagnacji gdzie bez zamydlonego ekranu nie pogramy w 4K, silniki graficzne też nie rozwijają się w oczekiwanym tempie - unity rozpadło się przez kiepski zarząd, unreal engine 5 to król mikroopóźnień, od zakończenia akceleracji sprzętowej dźwięku w windows vista (okolice 2007) nie było w audio żadnej rewolucji a wręcz ewolucji - id Tech to do dzisiaj jedyny engine który potrafi wyrysować łuk a nie koła z nakładanych trójkątów... Także sygnałów że branża kuleje nigdy nie brakowało - grunt to realizować swoje cele i jak tak jak ja od lat 2000 celujesz w średnią półkę cenową - szukać takich upgrade które faktycznie coś dają no i mieć świadomość że rtx 5090 to będzie 600w potwór z gddr7 i ceną na poziomie 12000 pln, takiej wydajności w kartach do 2000zł nie zobaczymy do 2030r. Pamiętam WOW jakie zrobił na mnie Teoria Chaosu splinter cella (mądrze zaprogramowana gra działająca również na konsolach) Far Cry 1 (był nieziemski na premierę) Crysis wyrywał z butów (8800gtx ledwo dawał radę), wszystko potem to sidegrade z momentami które pokazywały że 200 mln usd budżetu może dać jakościowy tytuł jak Red Dead 2, przez ostatnie 20 lat dobrych gier pctowych nie brakowało ale większość to ciągły sidegrade niepotrzebujący najmocniejszych sprzętów, dobieranie timingów pamięci to zawsze była nieco sztuka dla sztuki
