Portek
wymiana procesora i bsod'y'
Jaka reszta sprzętu, jaki zasilacz. Jakie temperatury? Jaką pastę nakładałeś?
Supremo m2 550w, karta graficzna gtx 1070, ram 2x8gb g.skill 2800mhz pasta jaką nakładałem to revoltec grease jakis noname a tempy w OCCT po 10 minutach max na 1 rdzeniu 74 stopnie a reszta max 66
Zaraz dodam screena z temperaturami
EDIT 1:
SKRIN z temperatur w idlu HW INFO
https://gyazo.com/7935ad0adddebc8bed676c2e257d79e2
Cpu kupiłeś używany ? Nie jest skalpowany ?
Ktoś zwalił skalpa na 100%
na i7 7700k wogle discord nie chcial sie odpalic zmienilem procesor na g4560 i discord dziala i jak narazie nic nie wyrzuca bsod
Żle zrobiony skapl żeletką, skąd wiem sam tak miałem i zepsułem cpu i5 7600k
Takie dump file mam
On Fri 02.03.2018 16:25:11 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\030218-27562-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x16BFD0)
Bugcheck code: 0xD1 (0xFFFFAB000532E108, 0x2, 0x1, 0xFFFFC20A57A14026)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Fri 02.03.2018 15:23:28 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\030218-27312-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFAB035C8B72B1, 0x0, 0xFFFFFFFFFFFFFFFF)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver.
po zmianie procesora to nie występuje myślicie ze to wina proca czy software jakis sie gryzie?
Człowieku na 100% proc jest uwalony
Tak jest z używkami. Ale nie ma co gadać bo każdemu może to się wydarzyć. Nawet jak była gwarancja to po skalpów już jej nie ma. Jak możesz procka odac to podaj i tyle
