chrubson
Logi FRST/GMER
1) Uruchom FRST. Na klawiaturze naciśnij jednocześnie CTRL+Y.Otworzy się Notatnik - wklej do niego:
HKU\S-1-5-21-2413265655-223109335-3009265283-1001\...\StartupApproved\Run: => "NLIGLIW867T3YIJ"
HKU\S-1-5-21-2413265655-223109335-3009265283-1001\...\StartupApproved\Run: => "5257678"
GroupPolicy: Ograniczenia - Chrome <==== UWAGA
CHR HKLM\SOFTWARE\Policies\Google: Ograniczenia <==== UWAGA
HKU\S-1-5-21-2413265655-223109335-3009265283-1001\Software\Microsoft\Internet Explorer\Main,Search Page = hxxps://%66%65%65%64.%73%6F%6E%69%63-%73%65%61%72%63%68.%63%6F%6D/?p=mKO_AwFzXIpYRaHdGKBRGNclVS1AC6sNoGk3GzeHhcr-ccYvFFRN1uU-W1HsQgcT-b7dmf_HA7w3cbaAl366QgmI2fjO_0PbEWRdOFi9fLm7mpUQjIVbULNzKFBoHgGSxlCLDmakSp8HuXA6L21BCCaxpJck7od5b9_RztwL7-4J7R83shgu_A06rqSm2v6P0bwW-S7IrB2-&q={searchTerms}
HKU\S-1-5-21-2413265655-223109335-3009265283-1001\Software\Microsoft\Internet Explorer\Main,Start Page = hxxps://%66%65%65%64.%68%65%6C%70%65%72%62%61%72.%63%6F%6D/?p=mKO_AwFzXIpYRaHdGKBRGNclVS1AC6sNoGk3GzeHhcr-ccYvFFRN1uU-W1HsQgcT-b7dmf_HA7w3cbaAl366QgmI2fjO_0PbEWRdOFi9fLm7mpUcMvDpY22IjoejFCuOnJXPznwzX2SjwGbhyuT7Kc_Yw0QYd34Inv3RuYS1A92PINUCF4uDHo4BccdqQRPtGWhcRbPcBsxK
SearchScopes: HKLM-x32 -> DefaultScope - brak wartości
CHR Extension: (Search Manager) - C:\Users\chrub\AppData\Local\Google\Chrome\User Data\Default\Extensions\pilplloabdedfmialnfchjomjmpjcoej [2018-10-30]
CHR NewTab: Default -> Active:"chrome-extension://pilplloabdedfmialnfchjomjmpjcoej/index.html"
CHR HKLM\...\Chrome\Extension: [pilplloabdedfmialnfchjomjmpjcoej] - hxxps://clients2.google.com/service/update2/crx
CHR HKU\S-1-5-21-2413265655-223109335-3009265283-1001\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [pilplloabdedfmialnfchjomjmpjcoej] - hxxps://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [pilplloabdedfmialnfchjomjmpjcoej] - hxxps://clients2.google.com/service/update2/crx
R2 PowerSvc; C:\ProgramData\Microsoft\Windows\Power\PowerSvc.exe [6406448 2018-06-25] () [brak podpisu cyfrowego] <==== UWAGA
S2 EventSvc; C:\ProgramData\Microsoft\Windows\EventSvc\eventsvc.exe [360448 2018-07-24] (CloudBees, Inc.) [brak podpisu cyfrowego] <==== UWAGA
S1 qbuxgnyd; \??\C:\WINDOWS\system32\drivers\qbuxgnyd.sys [X]
U3 fgndifob; \??\C:\Users\chrub\AppData\Local\Temp\fgndifob.sys [X] <==== UWAGA
RemoveDirectory: C:\ProgramData\zVmiMcGqez
RemoveDirectory: C:\Program Files\85L805N3JD
RemoveDirectory: C:\Users\chrub\AppData\Roaming\wnq5mexxyot
RemoveDirectory: C:\Program Files (x86)\Replay
RemoveDirectory: C:\Users\chrub\AppData\Local\AdvinstAnalytics
2018-10-30 00:23 - 2018-10-30 00:24 - 000722944 _____ C:\Users\chrub\AppData\Local\sham.db
2018-10-30 00:23 - 2018-10-30 00:23 - 007800320 _____ C:\Users\chrub\AppData\Local\agent.dat
2018-10-30 00:23 - 2018-10-30 00:23 - 002020875 _____ C:\Users\chrub\AppData\Local\LamBam.tst
2018-10-30 00:23 - 2018-10-30 00:23 - 001995264 _____ C:\Users\chrub\AppData\Local\Lotfix.exe
2018-10-30 00:23 - 2018-10-30 00:23 - 001995264 _____ C:\Users\chrub\AppData\Local\LamBam.exe
2018-10-30 00:23 - 2018-10-30 00:23 - 001895382 _____ C:\Users\chrub\AppData\Local\Goodjob.bin
2018-10-30 00:23 - 2018-10-30 00:23 - 000278511 _____ C:\Users\chrub\AppData\Local\Lotfix.tst
2018-10-30 00:23 - 2018-10-30 00:23 - 000140800 _____ C:\Users\chrub\AppData\Local\installer.dat
2018-10-30 00:23 - 2018-10-30 00:23 - 000126464 _____ C:\Users\chrub\AppData\Local\noah.dat
2018-10-30 00:23 - 2018-10-30 00:23 - 000070896 _____ C:\Users\chrub\AppData\Local\Config.xml
2018-10-30 00:23 - 2018-10-30 00:23 - 000005568 _____ C:\Users\chrub\AppData\Local\md.xml
2018-10-30 00:22 - 2018-10-30 00:22 - 003469281 _____ (ZONER software) C:\ProgramData\ffas.exe
Powershell: wevtutil el | Foreach-Object {wevtutil cl "$_"}
EmptyTemp:
Na klawiaturze naciśnij jednocześnie CTRL+S. W FRST kliknij na Fix (NAPRAW).
2) Zrób nowe logi FRST.
F.
FF NewTab: Mozilla\Firefox\Profiles\gska0cqs.default -> file:///C:/ProgramData/Quoteexs/ff.NT
R2 SysSvc; C:\Users\chrub\AppData\Local\NtvHost\syssvc.exe [360448 2018-07-24] (CloudBees, Inc.) [brak podpisu cyfrowego]
2018-10-30 00:25 - 2018-10-30 12:00 - 000000000 ____D C:\Users\chrub\AppData\Local\NtvHost
2018-10-30 00:25 - 2018-10-30 00:25 - 000000000 ____D C:\Users\chrub\AppData\Local\WServices
2018-10-30 00:25 - 2018-10-30 00:25 - 000000000 ____D C:\Users\chrub\AppData\Local\GoogleChromeApplication
2018-10-30 00:22 - 2018-10-30 00:22 - 000000000 ____D C:\ProgramData\Blogger
EmptyTemp:
F.
Dzięki za pomoc jest dużo lepiej ale zj*bane reklamy dalej nie dają za wygraną, w przeglądarce chrome.
Skanowałem kilka razy AdwCleaner i za każdym razem coś znajduje ale chyba nie usuwa i tak w kółko.
Zagrożenie to : PUP.Optional.Legacy
Przeinstaluj Chrome.
A jeśli i to nie pomoże, to całkowicie, na zawsze, usuniesz Chrome.
To tylko nieusuwalny klucz w Rejestrze.
F.
