Jaycob
Biomutant
New-Biomutant-Gameplay-Looks-Impressive-
BIOMUTANT is an open-world, post-apocalyptic Kung-Fu fable RPG, with a unique martial arts styled combat system allowing you to mix melee, shooting and mutant ability action.- Steam.
Świetny opis. :D
https://twitter.com/biomutant
Cytat
What kind of game is Biomutant?
Developer Experiment 101 officially describes Biomutant as a “post-apocalyptic Kung-Fu fable RPG.” That’s a mouthful, but it seems appropriate for the strange vibes that Biomutant puts off. From the limited gameplay we’ve seen, it’s essentially an action-RPG with an ambitious “Mutations” system that changes the genetic makeup of your custom cat hero over time.
There’s also a deep crafting system for making new weapons and armor. The gameplay demos so far have been fairly linear, but Biomutant is an open-world game with a 4x4 kilometer sandbox, not including its underground areas.
What is Biomutant story?
Biomutant has a unique take on post-apocalyptic worlds. Instead of your typical natural disaster, Biomutant’s world was destroyed by a massive oil flood that rose from the ground.
Experiment 101 has been cagey about the story, but it has emphasized that the choices your cat makes has a huge impact on the story. As an oil plague has infected the Tree of Life try to return vitality to the world, it’s your job to save it while uniting the world’s "tribes."
The Tree of Life quest sounds similar to Mass Effect 3’s "Galactic Readiness." Curing each of the Tree of Life’s "roots" will increase your percentage chance of saving the world at the end of the game.
You can craft weapons out of random pieces of junk
Supplies found in the open world can be used to craft unique weapons. We’ve seen swords, staffs, rifles, and pistols so far. One sword might have bent stop sign reinforcing the base while another uses a monkey wrench as a grip.
Biomutant’s simple 'Karma' system will change your ending
Your actions in Biomutant will teeter a simple Karma meter back and forth between good and bad. Apparently, you’ll see a different ending depending on your Karma by the end of the game. It’s not yet clear if this directly connects to your percentage chance to save humanity, as mentioned above.
Biomutant's combat plays like Devil May Cry
In a sit-down with YouTube channel Radioactive Games, Biomutant representatives apparently compared the combat to Devil May Cry, and it’s not hard to see the influence. The combat is a mix of melee and ranged with the same lock-on style that DMC is known for. Melee is reliant on combos and crowd control.
Your custom cat’s physique will affect its stats
At the beginning of Biomutant, players will tweak their cat protagonist’s genetic code to their liking—including strength, agility, vitality, charisma, and intellect. Shifting them around in the character creator drastically changes the physique of your cat. They can be short or tall, buff or skinny, whatever you want. Stats have a direct effect on things like weapon damage, persuasion, and movement speed.
Players will discover new physical and ‘Psy” abilities
The "mutant" part of Biomutant comes from your cat’s tendency to pick up new powers when exposed to the post-apocalypse wastelands. We’ve only seen a few powers so far—a telekinesis ability that lets you hurl small enemies at each other, and an ability that stuns enemies and force them to attack indiscriminately by swarming them in moths.
- pcgamer.com
Biomutant Collector's Edition:
Standardowa edycja gry
Oficjalna ścieżka dźwiękowa
Tkanina z grafiką w formacie A1
Wysokiej jakości figurka protagonisty
Pudełko kolekcjonerskie
Biomutant Atomic Edition:
Steelbook
T-shirt
Duża podkładka
Wysokiej jakości figurka walczącego protagonisty
Moim zdaniem zapowiada się całkiem ciekawie! Brakuje mi takich kolorowych gierek. Podoba mi się ten pokręcony, zróżnicowany, unikatowy otwarty świat.
Co mnie irytuje jak na razie to ten lektor, psuje immersję i jest nie potrzebny? Twórcy obiecują, że będzie można będzie go wyłączyć.
Podobnie mam zastrzeżenia do tych wyskakujących "pop-upów" podczas uderzeń niczym z komiksów. Biednie to wygląda.
Czekam na więcej trailerów i materiałów z Gamescomu z tej gry i liczę, że w końcu podadzą datę premiery.
Czekacie?
Edytowane przez Jaycob
Gameplay przypomina mi Sly Cooper i trochę Mini Ninja :)
Niby jak na moje standardy tak z 20x za bardzo pokręcone, ale kurczę, gameplay wydaje się bardzo przyjemny, customizacja postaci jest niesamowita, grafika ciekawa...
Ych, nie lubię tego typu gierek z jakimiś walczącymi zwierzakami i ogromnymi mieczami. Ale co tam kto woli ;)
Zapomniałem o tym. Przy zapowiedzi mnie zaintrygowało.
Kiedy ta gra będzie miała premierę bo czekam na jakieś informacyjnie o tu dupa nie nima :E
Data premiery: "kiedy będzie gotowa". :E Można posłuchać więcej o m.in dacie wydania z ostatniego wywiadu na Gamescomie.
Świat jest ogromy, a ludzi pracujących nad tą produkcją nie wielu.
Gość mówił też, że walka będzie przypomniała trochę tą z DMC i Batmana, co mi osobiście pasuje. Dość mam już Soulslike'ów.
Ja już o tej grze zdążyłem zapomnieć :E
Nie dziwie się bo ja o tej grze też zapomniałem. :lol2:
Ale już prawie gotowa
