demisen
RPCS3 - emulacja Playstation 3, gramy w hity.
RPCS3 was founded by programmers DH and Hykem. The developers initially hosted the project on Google Code and eventually moved it to GitHub later in its development. The emulator was first able to successfully boot and run simple homebrew projects and was then later publicly released in June of 2012. Today RPCS3 is dubbed one of the most complex video game console emulators of all time with an endless goal to effectively emulate the Sony PlayStation 3 and all of its aspects.
The goal of this project is to experiment, research, and educate on the topic of PlayStation 3 emulation that can be performed on compatible devices and operating systems. All information was obtained legally by purchasing PlayStation 3 hardware and software. Additional information was obtained from various sources on the internet that include but is not limited to system hardware and software documentation. Most of this information can be found on the PlayStation 3 Developer Wiki.
Strona domowa: KLIK
Pobieranie: KLIK
Lista kompatybilnych gier: KLIK
Oficjalny kanał YT: KLIK
Wymagania:
Recommended System Requirements
CPU: Intel Quad-core and above with TSX-NI (Haswell and above)
CPU: AMD Hexa-core and above (Ryzen)
GPU: Vulkan compatible AMD or NVIDIA card
RAM: 8GB or greater
OS: Windows 7/8/10 64-bit / Linux 64-bit / BSD 64-bit
+ PlayStation 3 PS3UPDAT.PUP system update file
Minimum System Requirements
CPU: Any x64 capable processor
GPU: OpenGL 4.3 compatible or greater
RAM: 2GB minimum
Plik PS3UPDAT.PUP jest możliwy do pobrania przez emulator.
Przy pierwszym uruchomieniu gry, emulator buduje cache co może trochę potrwać (w zależności od sprzętu), do tego opóźnione ładowanie modeli, jednak wystarczy ponownie uruchomić grę i wszystko działa jak powinno.
Na chwilę obecną sprawdziłem Tekken 6 - stałe 60FPS, Virtua Fighter 5 - stałe 60FPS, Killzone 2 - wywala się (I5-4670K/8GB RAM/GTX 1060).
Na zachętę Demon's Souls 4K 60FPS:
https://www.youtube.com/watch?v=5oBSR5fAyTU
Edytowane przez demisen
Pytanie laika i leniucha. Czy da radę pod tym odpalić Tekken 3 i World's Scariest Police Chases czyli gierki z Plejstacji czy łyka tylko gry przeznaczone dla PS3
Do PSX jest inny emulator, to tylko do PS3.
Gość Azazell
Chyba się nie da.. ale moge sie mylić.. Tekken 3 bez problemów śmiga na emulatorze MAME lub ePSXe
[quote name='Reddzik' date='29 Wrzesień 2019 - 12:31' timestamp='1569760288' post='15647136']
[/quote]
Dzięki.
[quote name='Kszyrztow' date='29 Wrzesień 2019 - 12:32' timestamp='1569760335' post='15647137']
Przecież masz całą masę dobrych emulatorów pierwszego PS.
[/quote]
Z tym który używałem dotąd mam niewielkie problemy. (nie pamiętam nazwy - inna maszyna inny dysk).
Za często nie pykam ale...
Jako że lubię testować nowe programy to miałbym powód do instalacji. ;-)
Jaki masz problem z Tekken 3 ? U mnie na ePSXe działa wyśmienicie, może poszukaj Bleem!. Jeżeli Tekken 3 jest w PSStore to nie widzę problemów by nie działał. W wolnej chwili obadam temat.
@ B166ER
Nowe znaczące emulatory to już są bardziej modułowe projekty rozwijane wielosystemowo:
Retroarch/Lakka/Retroboot/autobleem
https://www.libretro.com/
https://www.retroarch.com/
https://www.lakka.tv/
https://www.autobleem.tk/
Polecam w szczególności, bo tam mocno trwają prace nad perfekcyjną emulacją PSXa, obok usuwania glitchy, dodawania różnych bajerów (vulkan, akceleracja sprzętowa) to teraz nawet nadchodzi mała rewolucja w wydajności:
https://www.youtube.com/watch?v=mue4PmNC6Z0
PCSX ReARMed kop w wydajności:
https://www.libretro.com/index.php/retroarch-3ds-full-speed-ps1-now-possible-with-pcsx-rearmed-w-unai-renderer/
Do tego projekty jak:
https://batocera-linux.xorhub.com/
https://www.recalbox.com/
https://retropie.org.uk/
PS
Retroarch zmierza na steama:
https://store.steampowered.com/app/1118310/RetroArch/
Edytowane przez Kazubin
Dziękuję serdecznie Panowie nie róbmy jednak totalnego offtopa Koledze w temacie.
Sprawdzę te zaproponowane.
Pozdrawiam.
Temat o emulatorze PS3 jest i tak obecny na forum już sporo czasu, myślę, że powinien być jeden wspólny, ogólny dla emulacji, bo bardzo dużo się dzieje w tej dziedzinie ostatnio ;)
Ach tak. To chyba wypada żeby to zgłosić. Nie wiem w "Uwagi odnośnie..." ze stosowną prośbą. Jeśli Modery i Usery nie będą widzieć przeciwwskazań to chyba tak trzeba będzie uczynić. :-)
Jeszcze z rok i być może będzie można zagrać w RDR na PC w 4k@60fps :E
Z jakiś miesiąc, dwa patrzyłem to chyba dalej były bugi typu nie da się zacząć misji.
Ale i tak progres w ciągu w sumie ilu? Roku? Półtora? Piorunujący.
Zakładając, że R* tego nie wyda na PC to fajnie byłoby mieć możliwość powrotu do tego.
Pierwsze co chciałem pytać, czy rdr działa. Skoro nie to dziękuję ^^
Strona domowa: KLIK
Pobieranie: KLIK
Wymagania:
RAM: 8GB or greater
RAM: 2GB minimum
Jakie ustawiania dla Virtua Fighter 5 ?1440p.?
Mam akurat tą grę na ps3 jak i samą ps3.Chętnie sprawdzę jak to wygląda sprawa emulacji.Pewnie tymczasowo na 980ti 1560 nie da rady+do kompletu z 6950x [4600mhz taki zegar specjalnie do emulacji].
Dla mnie konkurencyjne emulator w postaci xenia jest przereklamowany,ponieważ nie jest w stanie ogarnąć fable 2 nadal.A czekam aż będzie w pełni działający na emulku tym.
Edytowane przez kosiarz66
Mam Demon Souls na RPCS3 i niby 60 fps jest, ale czasami łapie dropy, czego nawet nie pokazuje w overlay. Ustawienia mam takie same jak ludzie zalecają. Ogólnie to już nie raz testowałem ten emulator i za każdym razem jest coraz lepiej. Genialna robota. ;)
Edytowane przez Isharoth
Na kompie za ile? 20 tyś o ile nie więcej...
Soulcalibur IV - 60fps @ AF 4X + Resolution scale 300% (3840x2160) na potato PC. Nic tylko się cieszyć z progresu ekip od RPCS3 i CEMU :D
Edytowane przez tbs1987
Na tej i5 i 1060? To faktycznie dobrze to zoptymalizowali.
Zgadza się. Uwielbiam grać w salonach gier w celowniczki i nie mogłem sobie odmówić odpalenia Time Crisis: Razing Storm w cutscenkach mimo 60fps strasznie ścinki, sam gameplay płynny (FHD), jedynie dźwięk przerywa nonstop.
Jak ktoś lubi nier autoamta to jest dobra wiadomość. Nier gestald i drakengard 3 już działają bez problemu w 60fps, nawet w 4K.
