Ponury-X
GRUB 2 uefi/efi
Cześć
Zainstalowałem Ubuntu Mate obok Windowsa 10 [oba instalowane na uefi]
Teraz podczas uruchamiania mam GRUBa i Ubuntu jako domyślne.
Jak to zmienić, by domyślny był windows?
Pokaż wyniki poleceń z terminala - oprócz pierwszego:
sudo su -
cat /etc/default/grub
grep ^menuentry /boot/grub/grub.cfg
root@pisklak:~# cat /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
root@pisklak:~# grep ^menuentry /boot/grub/grub.cfg
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-e1bf1a65-fed7-4af3-9ebd-27b2621a7e6d' {
menuentry 'Windows Boot Manager (na /dev/nvme0n1p2)' --class windows --class os $menuentry_id_option 'osprober-efi-5038-67F4' {
menuentry 'System setup' $menuentry_id_option 'uefi-firmware' {
root@pisklak:~#
Ponury-X
Dla pewności ustaw zmienną GRUB_DEFAULT na taką:
GRUB_DEFAULT="Windows Boot Manager (na /dev/nvme0n1p2)"
Możesz skorzystać z konsolowego edytora nano:
sudo su -
nano /etc/default/grub
Zmień, zapisz zmiany za pomocą Ctrl+s, wyjdź z programu za pomocą Ctrl+x.
Uaktualnij konfigurację Gruba:
update-grub
Ponieważ menu Gruba jest ukryte to i tak go nie zobaczysz, ale po restarcie powinien uruchomić się bootloader Windows. Żeby wyświetlić menu Gruba po starcie komputera (po beepie) trzeba wcisnąć Shift albo spację.
Żeby wyłączyć ukrywanie menu Gruba, o ile dobrze pamiętam wystarczy zahaszować tą linię, ma wyglądać tak - w ten sam sposób jak wyżej + update Gruba:
# GRUB_TIMEOUT_STYLE=hidden
witek_w11
Można ustawić też numer pozycji liczony od zera, ale jeśli dojdzie "jakaś" kolejna pozycja to numer 1 stanie się dwójką i się spsuje.
Edytowane przez Gość
    • Cały czas na tym samym kablu jedziesz? A np. wyciągnięcie i ponowne włożenie kabla nie likwiduje problemu?
    • Jak oni te pasty nakładają? Ręcznie czy maszynowo? Bo jak miałem 970 strixa, to po chyba 4-5 latach od kupna uznałem że wymienię pastę, bardziej z ciekawości jak to się robi, niż ze wzrostu temperatur, jak ściągnąłem chłodzenie, to sobie myślę WTF? Pasta tak walnięta jakby ktoś to po kilku głębszych robił, nie wiem ale połówka rdzenia była bez pasty  może to tak miało być, bo wsumie jeden jedyny raz wymieniałem pastę na gpu.
    • Nie ma czegoś takiego... ta zgoda podobno istniała już kilka razy w ciągu kilku miesięcy, a jednak... Obecnie Partia Republikańska w większości to opłacane przez Putina pionki, mniejszość to ta, która chce pomóc Ukrainie. Do tego masz karierowiczów, którzy zrobią wszystko(Johnson, który bez przyzwolenia Trumpa nie kiwnie palcem). Trump jest najważniejszym politykiem po prawej stronie w USA i to on decyduje o kształcie i kierunkach polityki Partii Republikańskiej. Właśnie z tego powodu rozdzielili te pakiety pomocowe, bo okazało się, że część demokratów nie chciała poprzeć pomocy dla Izraela(morderstwa osób cywilnych w Gazie), a tym samym dla Ukrainy i zrobił się kłopot. Teraz pomoc dla Izraela przejdzie, a pomoc dla Ukrainy zostanie uwalona, jeśli w ogóle zostanie poddana pod głosowanie. Reagan przewraca się w grobie, bo jest totalnie niezrozumiałe czym stała się prawica w USA i czyich interesów broni.    Kiedy Russia Today wchodzi za mocno... "Ukraińscy naziści, którzy powinni oddać Rosji część swojego terytorium". Tak wygląda dzisiaj przeciętny Republikanin, który przedstawia narrację i propagandę rosyjską. Przerażające do czego mogą doprowadzić pieniądze i głosowanie na populistów. To pokazuje jak mocne wpływy ma Rosja w USA(ale to już wiadomo oficjalnie po raporcie dotyczącym wyborów i wygranej Trumpa).
    • To już druga osoba bodajże w tym temacie z tym samym modelem i po własnej aplikacji pasty taka duża różnica, gwarancji nie trzeba żegnać jak przyrosty są tak fajne to warto to zrobić, jak jest plomba na którejś śrubie to można zamówić i nakleić jeżeli np suszarka + żyletka nie dały rady lub w ogóle ktoś robi dziurę w plombie od razu  Chwile temu zamawiałem z alledrogo do xfx https://allegro.pl/oferta/5x-naklejki-gwarancyjne-asus-msi-palit-xfx-evga-gigabyte-zotac-15362612792
    • Dane CFM z opakowań producentów nie można porównywać między nimi, a najlepiej kompletnie na te dane nie patrzeć. Nie dość, że nie ma żadnego ogólne standardu względem którego dokonywane są te pomiary, więc każdy producent mierzy jak uważa, to dodatkowo zarówno te dotyczące przepływu jak i ciśnienia są dokonywane przy skrajnych i nierealnych sytuacjach. Na przykład w przypadku ilości przepchniętego powietrza mogą być stosowane kilkudziesięciocentymetrowe tunele z "prostownikami przepływu" na końcu którego znajduje sie wentylator i po przeciwnej stronie przyrząd do pomiaru, czyli coś czego nikt w domowym komputerze nie zastosuje przez co taki wynik jest niestosowalny w praktyce dla wentylatora zamontowanego bezpośrednio na radiatorze (czy to od wieży chłodzenia czy układu cieczą) lub kratce obudowy. Zostają tylko praktyczne testy jak np. TechPowerUP czy HWCooling.net lub takie przy stałej metodologii dla wszystkich śmigieł jak np. Cybenetics. W takim przypadku będziesz miał miarodajne wyniki. Nie potrzebujesz takiej przejściówki dopóki gniazdo do którego wpinasz 4 pinową wtyczkę nie jest blokowane plastikiem z boku w którym wtyczka by wystawała (a jeżeli blokuje to możesz próbować tę blokadę usunąć). Rozstaw pinów w wentylatorze 2, 3 i 4 pinowym jest teoretycznie identyczny, bo dwa pierwsze piny to kolejno uziemienie i napięcie, kolejny to pomiar obrotów i ostatni czwarty to pin do sterowania PWM. Wentylator 2 i 3 pin można sterować tylko poprzez zmianę napięcia pracy, a dla wentylatora PWM nie ma teoretycznie znaczenia czy steruje się go sygnałem czy napięciem, tak długo jak jego sama konstrukcja nie przeszkadza w sterowaniu jego obrotami poprzez zmianę napięcia zamiast sygnałem modulacyjnym (jak np. nie powinno się robić w przypadku łożysk magnetycznych jak w wentylatorach Phanteks T30 lub Corsair ML120 czy konstrukcjach Sunona MagLev).
