asusek147
Powershell podniesienie uprawnień
Potrzebuję kodu żrudłowego który będzie dodany w skrypcie Powershell jego zadaniem będzie podniesienie uprawnień co spowoduje uruchomienie skryptu jako administrator
będę wdzięczny za pomoc
RunAs może?
RUNAS USAGE:
RUNAS [ [/noprofile | /profile] [/env] [/savecred | /netonly] ]
       /user:<UserName> program
RUNAS [ [/noprofile | /profile] [/env] [/savecred] ]
       /smartcard [/user:<UserName>] program
RUNAS /trustlevel:<TrustLevel> program
  /noprofile        specifies that the user's profile should not be loaded.
                    This causes the application to load more quickly, but
                    can cause some applications to malfunction.
  /profile          specifies that the user's profile should be loaded.
                    This is the default.
  /env              to use current environment instead of user's.
  /netonly          use if the credentials specified are for remote
                    access only.
  /savecred         to use credentials previously saved by the user.
                    This option is not available on Windows 7 Home or Windows 7
Starter Editions
                    and will be ignored.
  /smartcard        use if the credentials are to be supplied from a
                    smartcard.
  /user             <UserName> should be in form USER@DOMAIN or DOMAIN\USER
  /showtrustlevels  displays the trust levels that can be used as arguments
                    to /trustlevel.
  /trustlevel       <Level> should be one of levels enumerated
                    in /showtrustlevels.
  program         command line for EXE.  See below for examples
Examples:
> runas /noprofile /user:mymachine\administrator cmd
> runas /profile /env /user:mydomain\admin "mmc %windir%\system32\dsa.msc"
> runas /env /user:user@domain.microsoft.com "notepad \"my file.txt\""
NOTE:  Enter user's password only when prompted.
NOTE:  /profile is not compatible with /netonly.
NOTE:  /savecred is not compatible with /smartcard.
To będzie lepsze
psexec -u [użytkownik] -p [hasło] "notepad.exe"
Edytowane przez Atak_Snajpera
    • To akurat wiemy. Liniowy wzrost stężenia gazów cieplarnianych powoduje wykładniczy wzrost przeciętnych temperatur a także wariancji temperatur. Termodynamika i nic poza tym. A jak rośnie wariancja temperatur to i rośnie szybkość wiatrów itd.
    • To zobacz która karta jest najchętniej kupowana i nie patrz na forum gdzie masz jednak miłośników sprzętu z zasobnym portfelem
    • nieprawda - także, i w późniejszym okresie nawet głównie, żeby mieć rynki zbytu - np GB w 19 wieku produkowała już tyle tkanin, głównie bawełnianych, że rynek europejski i amerykański był dla nich zbyt ciasny, i głównym rynkiem zbytu stały się Indie - i w zasadzie zniszczyły głównie chałupniczy przemysł tekstylny w Indiach, za pomocą ceł, ale i samych cen, bo ręczni tkacze w Indiach nie byli w stanie konkurować z  fabrycznym przemysłem w GB - jest o tym mnóstwo materiałów, a niejaki Marks napisał np że równiny Bengalu pokryły się kośćmi zmarłych z głodu tkaczy indyjskich (o ile pamiętam w artykule z 1857) - raczej przesada, ale w zasadzie zgodne z rozwojem historycznym; dodam, że bawełna na tkaniny z GB pochodziła z USA, choć Indie same były wielkim producentem bawełny, i że Indie już wtedy liczyły ponad  200 mln ludności, gdy np USA ok 50 - więc nie rabowanie z bogactw, których Indie zresztą dużo nie miały (głównym importem z Indii do GB była herbata), było decydującym bodźcem rozwoju krajów przemysłowych, tylko pozyskiwanie dużych rynków zbytu i wykorzystywanie przewagi produkcji maszynowej nad ręczną; czyli potęgi gospodarcze dorobiły się na postępie technicznym, tzn produkcji maszynowej, nie ręcznej, a rabowanie tzw bogactw, które wtedy z reguły były produktami rolniczymi, odgrywało drugorzędną rolę; jeśli już rabowanie, to przede wszystkim niewolników z Afryki do produkcji bawełny w USA i cukru w Brazylii i na Karaibach, bo oba te produkty stały się podstawą masowej konsumpcji w Europie, która napędzała wzrost i umaszynowienie produkcji, itd
    • Właśnie jestem w tym kotle Skończę go i zapoluję na alfę. Dz.
