Spl97
Zen 3(AMD Ryzen 5xxx) - wątek zbiorczy
Ostateczna lista procesorów AMD Ryzen 5xxx :
- Vermeer  -  5.11.2020/4.04.2022/31.07.2024 (1 CCD + CIOD - Ryzen 5/7 , 2 CCD + CIOD - Ryzen 9 CCD - ~83 mm^2 7 nm CIOD ~125 mm^2 12 nm)
AMD Ryzen 5 5600 - 6C/12T 3,5 GHz Base 4,4 GHz Boost 35MB Cache L2+L3 TDP 65W $199
AMD Ryzen 5 5600X - 6C/12T 3,7 GHz Base 4,6 GHz Boost 35MB Cache L2+L3 TDP 65W $299
AMD Ryzen 7 5700X - 8C/16T 3,4 GHz Base 4,6 GHz Boost 36MB Cache L2+L3 TDP 65W $299
AMD Ryzen 7 5800 - 8C/16T 3,4 GHz Base 4,6 GHz Boost 36MB Cache L2+L3 TDP 65W OEM
AMD Ryzen 7 5800X - 8C/16T 3,8 GHz Base 4,7 GHz Boost 36MB Cache L2+L3 TDP 105W $449
AMD Ryzen 7 5800XT - 8C16T 3,8 GHz Base 4,8 GHz Boost 36MB Cache L2+L3 TDP 105W $249
AMD Ryzen 9 5900 - 12C/24T 3,0 GHz Base 4,7 GHz Boost 70MB Cache L2+L3 TDP 65W OEM
AMD Ryzen 9 5900X - 12C/24T 3,7 GHz Base 4,8 GHz Boost 70MB Cache L2+L3 TDP 105W $549
AMD Ryzen 9 5900XT - 12C/24T 3,3 GHz Base 4,8 GHz Boost 70MB Cache L2+L3 TDP 105W $349
AMD Ryzen 9 5950X - 16C/32T 3,4 GHz Base 4,9 GHz Boost 72MB Cache L2+L3 TDP 105W $799
- Vermeer-X 20.04.2022/07.07.2023/31.01.2024 (Zen 3 CCD 7 nm, CIOD 12 nm + 64 MB AMD 3D V-Cache L3)
AMD Ryzen 5 5600X3D - 6C/12T 3,3 GHz Base 4,4 GHz Boost 35 MB Cache L2+L3 + 64 MB 3D V-Cache L3 TDP 105W $229 US Only
AMD Ryzen 7 5700X3D - 8C/16T 3,0 GHz Base 4,1 GHz Boost 36 MB Cache L2+L3 + 64 MB 3D V-Cache L3 TDP 105W $249
AMD Ryzen 7 5800X3D - 8C/16T 3,4 GHz Base 4,5 GHz Boost 36 MB Cache L2+L3 + 64 MB 3D V-Cache L3 TDP 105W $449
- Vermeer (OEM)  (1 CCD + CIOD - Ryzen 5/7 , 2 CCD + CIOD - Ryzen 9 CCD - ~83 mm^2 7 nm CIOD ~125 mm^2 12 nm)
AMD Ryzen 5 5600E - 6C/12T 3,6 GHz Base ? Boost 35 MB Cache L2+L3 TDP 65W
AMD Ryzen 5 PRO 5645 - 6C/12T 3,7 GHz Base 4,6 GHz Boost 35 MB Cache L2+L3 TDP 65W
AMD Ryzen 7 5800E - 8C/16T 3,7 GHz Base ? Boost 36 MB Cache L2+L3 TDP 100W
AMD Ryzen 7 PRO 5845 - 8C/16T 3,4 GHz Base 4,6 GHz Boost 36 MB Cache L2+L3 TDP 65W
AMD Ryzen 9 5900E - 10C/20T 3,7 GHz Base ? Boost 69 MB Cache L2+L3 TDP 105W
AMD Ryzen 9 PRO 5945 - 12C/24T 3,0 GHz Base 4,7 GHz Boost 70 MB Cache L2+L3 TDP 65W
AMD Ryzen 9 5950E - 12C/24T 3,4 GHz Base ? Boost 70 MB Cache L2+L3 TDP 105W
- Chagall 8.03.2022 (OEM) / 8.08.2022 (max.8 CCD ~83 mm^2 7 nm + CIOD 12 nm)
AMD Ryzen Threadripper PRO 5945WX - 12C/24T 4,1 GHz Base 4,5 GHz Boost 70 MB Cache L2+L3 TDP 280W
AMD Ryzen Threadripper PRO 5955WX - 16C/32T 4,0 GHz Base 4,5 GHz Boost 72 MB Cache L2+L3 TDP 280W
AMD Ryzen Threadripper PRO 5965WX - 24C/48T 3,8 GHz Base 4,5 GHz Boost 140 MB Cache L2+L3 TDP 280W $2,399
AMD Ryzen Threadripper PRO 5975WX - 32C/64T 3,6 GHz Base 4,5 GHz Boost 144 MB Cache L2+L3 TDP 280W $3,299
AMD Ryzen Threadripper PRO 5995WX - 64C/128T 2,7 GHz Base 4,5 GHz Boost 288 MB Cache L2+L3 TDP 280W $6,499
- Milan  -  15.03.2021 (max.8 CCD ~83mm^2 7 nm + CIOD 12/14 nm)
AMD Epyc 72F3 - 8C/16T 3.7 GHz Base 4,1 GHz Boost 256 MB Cache L3 TDP 180W
AMD Epyc 7313P - 16C/32T 3,0 GHz Base 3,7 GHz Boost 128 MB Cache L3 TDP 155W
AMD Epyc 7313 - 16C/32T 3,0 GHz Base 3,7 GHz Boost 128 MB Cache L3 TDP 155W
AMD Epyc 7343 - 16C/32T 3,2 GHz Base 3,9 GHz Boost 128 MB Cache L3 TDP 190W
AMD Epyc 73F3 - 16C/32T 3,5 GHz Base 4,0 GHz Boost 256 MB Cache L3 TDP 240W
AMD Epyc 7413 - 24C/48T 2,65 GHz Base 3,6 GHz Boost 128 MB Cache L3 TDP 180W
AMD Epyc 74F3 - 24C/48T 3,2 GHz Base 4,0 GHz Boost 256 MB Cache L3 TDP 240W
AMD Epyc 7443P - 24C/48T 2,85 GHz Base 4,0 GHz Boost 128 MB Cache L3 TDP 200W
AMD Epyc 7443 - 24C/48T 2,85 GHz Base 4,0 GHz Boost 128 MB Cache L3 TDP 200W
AMD Epyc 7453 - 28C/56T 2,75 GHz Base 3,45 GHz Boost 64 MB? Cache L3 TDP 225W
AMD Epyc 7513 - 32C/64T 2,6 GHz Base 3,65 GHz Boost 128 MB Cache L3 TDP 200W
AMD Epyc 7543P - 32C/64T 2,8 GHz Base 3,7 GHz Boost 256 MB Cache L3 TDP 225W
AMD Epyc 7543 - 32C/64T 2,8 GHz Base 3,7 GHz Boost 256 MB Cache L3 TDP 225W
AMD Epyc 75F3 - 32C/64T 2,95 GHz Base 4,0 GHz Boost 256 MB Cache L3 TDP 280W
AMD Epyc 7643 - 48C/96T 2,3 GHz Base 3,6 GHz Boost 256 MB Cache L3 TDP 225W
AMD Epyc 7663 - 56C/112T 2,0 GHz Base 3,5 GHz Boost 256 MB Cache L3 TDP 240W
AMD Epyc 7713P - 64C/128T 2,0 GHz Base 3,675 GHz Boost 256 MB Cache L3 TDP 225W
AMD Epyc 7713 - 64C/128T 2,0 GHz Base 3,675 GHz Boost 256 MB Cache L3 TDP 225W
AMD Epyc 7763 - 64C/128T 2,45 GHz Base 3,5 GHz Boost 256 MB Cache L3 TDP 280W
- Milan-X - 21.03.2022 (max.8 CCD ~83mm^2 7 nm + CIOD 12/14 nm + 64 MB per CCD 3D V-Cache L3)
AMD Epyc 7373X - 16C/32T 3,05 GHz Base 3,8 GHz Boost 256 MB Cache L3 + 512 MB 3D V-Cache L3 TDP 240W
AMD Epyc 7473X - 24C/48T 2,8 GHz Base 3,7 GHz Boost 256 MB Cache L3 + 512 MB 3D V-Cache L3 TDP 240W
AMD Epyc 7573X - 32C/64T 2,8 GHz Base 3,6 GHz Boost 256 MB Cache L3 + 512 MB 3D V-Cache L3 TDP 280W
AMD Epyc 7773X - 64C/128T 2,2 GHz Base 3,5 GHz Boost 256 MB Cache L3 + 512 MB 3D V-Cache L3 TDP 280W
- Cezanne  - Mobile Luty 2021,Desktop 5.08.2021/4.04.2022/31.01.2024 (CPU Zen 3 + iGPU Vega - ~180 mm^2 7 nm)
Mobile
AMD Ryzen 3 5125C - 2C/4T 3,0 GHz Base 8 MB Cache L3 TDP 15W Vega 3
AMD Ryzen 3 5425U - 4C/8T 2,7 GHz Base 4,1 GHz Boost 10 MB Cache L2+L3 TDP 15W Vega 6
AMD Ryzen 5 5600U - 6C/12T 2,3 GHz Base 4,2 GHz Boost 19 MB Cache L2+L3 TDP 15W Vega 7
AMD Ryzen 5 5625U - 6C/12T 2,3 GHz Base 4,3 GHz Boost 19 MB Cache L2+L3 TDP 15W Vega 7
AMD Ryzen 5 5600HS - 6C/12T 3,0 GHz Base 4,2 GHz Boost 19 MB Cache L2+L3 TDP 35W Vega 7
AMD Ryzen 5 5600H - 6C/12T 3,3 GHz Base 4,2 GHz Boost 19 MB Cache L2+L3 TDP 45W Vega 7
AMD Ryzen 7 5800U - 8C/16T 1,9 GHz Base 4,4 GHz Boost 20 MB Cache L2+L3 TDP 15W Vega 8
AMD Ryzen 7 5825U - 8C/16T 2,0 GHz Base 4,5 GHz Boost 20 MB Cache L2+L3 TDP 15W Vega 8
AMD Ryzen 7 5800HS - 8C/16T 2,8 GHz Base 4,4 GHz Boost 20 MB Cache L2+L3 TDP 35W Vega 8
AMD Ryzen 7 5800H - 8C/16T 3,2 GHz Base 4,4 GHz Boost 20 MB Cache L2+L3 TDP 45W Vega 8
AMD Ryzen 9 5900HS - 8C/16T 3,0 GHz Base 4,6 GHz Boost 20 MB Cache L2+L3 TDP 35W Vega 8
AMD Ryzen 9 5900HX - 8C/16T 3,3 GHz Base 4,6 GHz Boost 20 MB Cache L2+L3 TDP 45+W Vega 8
AMD Ryzen 9 5980HS - 8C/16T 3,0 GHz Base 4,8 GHz Boost 20 MB Cache L2+L3 TDP 35W Vega 8
AMD Ryzen 9 5980HX - 8C/16T 3,3 GHz Base 4,8 GHz Boost 20 MB Cache L2+L3 TDP 45+W Vega 8
Desktop
AMD Ryzen 3 5100 - 4C/8T 3,8 GHz Base 4,2 GHz Boost Cache L3 8 MB TDP 65W --------------- OEM
AMD Ryzen 3 5300GE - 4C/8T 3,6 GHz Base 4,2 GHz Boost Cache L3 8 MB TDP 35W  Vega 6 OEM
AMD Ryzen 3 5300G - 4C/8T 4,0 GHz Base 4,2 GHz Boost Cache L3 8 MB TDP 65W  Vega 6 OEM
AMD Ryzen 5 5500 - 6C/12T 3,6 GHz Base 4,2 GHz Boost 19MB Cache L2+L3 TDP 65W ---------------$159
AMD Ryzen 5 5500GT - 6C/12T 3,6 GHz Base 4,4 GHz Boost 19 MB Cache L2+L3 TDP 65W Vega 7 $125
AMD Ryzen 5 5600GE - 6C/12T 3,4 GHz Base 4,4 GHz Boost 19 MB Cache L2+L3 TDP 35W Vega 7 OEM
AMD Ryzen 5 5600G - 6C/12T 3,9 GHz Base 4,4 GHz Boost 19 MB Cache L2+L3 TDP 65W Vega 7 $259
AMD Ryzen 5 5600GT - 6C/12T 3,6 GHz Base 4,6 GHz Boost 19 MB Cache L2+L3 TDP 65W Vega 7 $140
AMD Ryzen 7 5700GE - 8C/16T 3,2 GHz Base 4,6 GHz Boost 20 MB Cache L2+L3 TDP 35W Vega 8 OEM
AMD Ryzen 7 5700G - 8C/16T 3,8 GHz Base 4,6 GHz Boost 20 MB Cache L2+L3 TDP 65W Vega 8 $359
AMD Ryzen 5 5700 - 8C/16T 3,7 GHz Base 4,6 GHz Boost 20MB Cache L2+L3 TDP 65W ---------------$179
- Rembrandt 04.01.2022 (CPU Zen 3+ + iGPU RDNA 2 - ~206-208 mm^2 6 nm)
Mobile
AMD Ryzen 5 6600U - 6C/12T 2,9 GHz Base 4,5 GHz Boost 19 MB Cache L2+L3 TDP 15W RDNA 2 6CU 1,9 GHz
AMD Ryzen 5 6600HS - 6C/12T 3,3 GHz Base 4,5 GHz Boost 19 MB Cache L2+L3 TDP 35W RDNA 2 6CU 1,9 GHz
AMD Ryzen 5 6600H - 6C/12T 3,3 GHz Base 4,5 GHz Boost 19 MB Cache L2+L3 TDP 45W RDNA 2 6CU 1,9 GHz
AMD Ryzen 7 6800U - 8C/16T 2,7 GHz Base 4,7 GHz Boost 20 MB Cache L2+L3 TDP 15W RDNA 2 12CU 2,2 GHz
AMD Ryzen 7 6800HS - 8C/16T 3,2 GHz Base 4,7 GHz Boost 20 MB Cache L2+L3 TDP 35W RDNA 2 12CU 2,2 GHz
AMD Ryzen 7 6800H - 8C/16T 3,2 GHz Base 4,7 GHz Boost 20 MB Cache L2+L3 TDP 45W RDNA 2 12CU 2,2 GHz
AMD Ryzen 9 6900HS - 8C/16T 3,3 GHz Base 4,9 GHz Boost 20 MB Cache L2+L3 TDP 35W RDNA 2 12CU 2,4 GHz
AMD Ryzen 9 6900HX - 8C/16T 3,3 GHz Base 4,9 GHz Boost 20 MB Cache L2+L3 TDP 45+W RDNA 2 12CU 2,4 GHz
AMD Ryzen 9 6980HS - 8C/16T 3,3 GHz Base 5,0 GHz Boost 20 MB Cache L2+L3 TDP 35W RDNA 2 12CU 2,4 GHz
AMD Ryzen 9 6980HX - 8C/16T 3,3 GHz Base 5,0 GHz Boost 20 MB Cache L2+L3 TDP 45+W RDNA 2 12CU 2,4 GHz
- Rembrandt - R  04.01.2023/30.04.2023 (CPU Zen 3+ + iGPU RDNA 2 - ~206-208 mm^2 6 nm)
AMD Ryzen 3 7335U - 4C/8T 3,0 GHz Base 4,3 GHz Boost Cache L3 8 MB TDP 15-30W RDNA 2 4CU 1,8 GHz
AMD Ryzen 5 7235H - 4C/8T 3,2 GHz Base 4,2 GHz Boost Cache L3 8 MB TDP 35-53W
AMD Ryzen 5 7235HS - 4C/8T 3,2 GHz Base 4,2 GHz Boost Cache L3 8 MB TDP 35-53W
AMD Ryzen 5 7535U - 6C/12T 2,9 GHz Base 4,55 GHz Boost 19 MB Cache L2+L3 TDP 15-30W RDNA 2 6CU 1,9 GHz
AMD Ryzen 5 7535H - 6C/12T 3,3 GHz Base 4,55 GHz Boost 19 MB Cache L2+L3 TDP 35-54W RDNA 2 6CU 1,9 GHz
AMD Ryzen 5 7535HS - 6C/12T 3,3 GHz Base 4,55 GHz Boost 19 MB Cache L2+L3 TDP 35-54W RDNA 2 6CU 1,9 GHz
AMD Ryzen 7 7435H - 8C/16T 3,1 GHz Base 4,5 GHz Boost 20 MB Cache L2+L3 TDP 35-54W
AMD Ryzen 7 7435HS - 8C/16T 3,1 GHz Base 4,5 GHz Boost 20 MB Cache L2+L3 TDP 35-54W
AMD Ryzen 7 7735U - 8C/16T 2,7 GHz Base 4,75 GHz Boost 20MB Cache L2+L3 TDP 15-30W RDNA 2 12CU 2,2 GHz
AMD Ryzen 7 7736U - 8C/16T 2,7 GHz Base 4,7 GHz Boost 20MB Cache L2+L3 TDP 15-28W RDNA 2 12CU 2,2 GHz
AMD Ryzen 7 7735H - 8C/16T 3,2 GHz Base 4,75 GHz Boost 20MB Cache L2+L3 TDP 35-54W RDNA 2 12CU 2,2 GHz
AMD Ryzen 7 7735HS - 8C/16T 3,2 GHz Base 4,75 GHz Boost 20MB Cache L2+L3 TDP 35-54W RDNA 2 12CU 2,2 GHz
Edytowane przez Spl97
Ryzeny 4000 to będą naprawdę fajne procesory więc przykładowo przeskok z takiego i5 4670 na np. Ryzen 4600 to będzie spory boost.
gdyby faktycznie podnieśli IPC o 17% to mielibyśmy małą przepaść pomiędzy pierwszą i czwartą iteracją. a Intel byłby w małej dupie bo wtedy AMD by ich odstawiło.
czekam na 4600X czy coś w ten deseń.
  • Like 2
Mimo iż nie dawno kupiłem 2700X, to jeżeli przecieki się sprawdzą to z miłą chęcią uderzę w trzecią generację Ryśków, bo brzmi to bdb. Drugą generację olewam ze względu na opłacalność.
  • Confused 1
Trzecia generacja to Ryzen 3000. Zen3 to czwarta generacja Ryzenów.
Kupię na pewno 8/16.
No, chodzi mi o Zen 3 właśnie :E
A między zen+ a zen2 jak jest? 15% to lekko mówiąc są gry gdzie nawet 30% np cs go więc kolejne 15% to minimum względem zen2 a zen3 jeśli ma to być efekt łał
Edytowane przez Send1N
Jeśli faktycznie będzie 15%+ to AMD powinno przegonić Intela w grach.
Jutro o 23:00 może być ciekawie :D
Czy płyty X570 będą w pełni obsługiwać procki 4x00 od AMD?
Czy przy wydaniu nowych procków czwartej generacji wyjdzie też nowy chipset? Jeśli tak to czym będzie się różnił?
1.X570 mają mieć pełną kompatybilność z Ryzenami 4xxx
2.Razem z 4 gen.Ryzen ma wyjść X670 - X670 ma być produkowany przez ASMedia
4 gen.Ryzen według zapowiedzi ma być ostatnią generacją procesorów na socket AM4
@up
Dokładnie. Od siebie dodam, że starsze płyty na B450/x470 raczej na 90% też będą obsługiwać Ryzeny 4xxx, z tą różnicą że najprawdopodobniej BIOSy, które to umożliwią będą wydawane tylko w wersji beta.
Zastanawiam się natomiast co się stało z B550 i czy w ogóle mają je w planach, bo miały pojawić się w Q4 19 / Q1 20, mamy już styczeń i zero informacji. Mam nadzieję że jutro się czegoś więcej dowiemy.
Edytowane przez parcu
Trochę lipa, upada mit o wiecznej podstawce. Z drugiej strony i tak entuzjasta za każdym razem zmienia mobasa.
Być może AMD zrobi w końcu jakiś uzysk z tego pcie4 na X670. Nie chce mi się zbytnio wierzyć w te Wasze b450 na Zen3 :E
Czekam do jutra z niecierpliwością, mam nadzieje że Zen3 dogoni Intela w grach a we Wtorek zobaczymy kolejne odgrzewane kotlety od Intela które znów podbiją słupki w testach.
Edytowane przez Jack White
Nie wiem,czy jutro powiedzą coś o B550,raczej wątpię.Prędzej będą gadać o RX 5600XT
A ile lat jest już AM4 ? Zen3 dogoni Intela w grach ? Przecież zrobiły to obecne procesory AMD. Trochę fantazjujesz, chyba że miałeś na myśli przegoni Intela w grach szczerbaty.gif
Edytowane przez Pitt_34
To już 4 rok,licząc od roku 2017
B550 jest tak potrzebne jak gtx 1650 super itp :E :E
Ja to wiem wink.gif ironicznie zapytałem kolegi, który trochę fantazjuje szczerbaty.gif
Po części masz rację.
Ale z drugiej strony jest potrzebne choćby ze względu na sytuację z rx5500.
Bo były plotki że na b550 GPU ma dostać pcie 4.0 oraz jeden slot na nvme bezpośrednio z cpu. Tego na b450 nie ma a do x570 dopłacac nie ma sensu. W jaki sposób miałoby to wyglądać od strony technicznej, tego nie wiem bo się w tym nie odnajduje zbytnio.
Tylko kto by wtedy kupowal X570?
P.S. Moze by tak przykleic ten temat?
Ja pewnie kupie jak już Ryzen 5 4600 6/12 jak wyjdzie i do tego jakąś płytę na B550.
Jakto kto? Te same osoby, które wcześniej wybierały x470 zamiast b450.
Co jest "sytuacją" z rx5500?
Tak uproszczona, że aż błędna teoria, że PCIe3 ogranicza rx5500?
Edytowane przez MitycznyJeż
Ciekawe, czy znów trzeba będzie czekać pół roku z zakupem, tak aby poleciały marne sztuki z pierwszych rzutów. Wydało się już jakiś czas temu, że np Ryzeny 3600 z końca 2019 są znacznie lepsze od tych pierwszych sztuk.
Bo wtedy kupię, ale na black friday 2020... :hmm:
raczej celuję w topowy proc z serii (może 4700x, a może 4900x nawet). Powinien trzymać cenę 5 lat, liczę na powtórkę z rozrywki z 4790k i sprzedaż za 80% ceny po 5 latach :E :E Wydajność na pewno będzie wystarczająca.
O ile w ogóle będą teraz te Ryzeny 4000 dla desktopów. Tak na logikę, to nie widzę żadnego sensu wprowadzania teraz czegokolwiek na Zen3, skoro dla AMD ważniejsze jest nie ciśnięcie rynku desktop, z którego jest gówno a nie pieniądze, tylko układów mobilnych (a te będą na Zen2) oraz jednostek serwerowych (tu będzie priorytet). Do tego AMD nie ma nie wiadomo jak dużej dostępności wafli krzemowych, a gigantyczną ich część, nawet po zwolnieniu zasobów przez Apple, idzie na chipy do konsol.
Już nie wspomnę, że nie było żadnych przecieków na temat desktopowych Ryzenów 4. generacji, więc o Zen3 mogą sobie mówić, ale pewnie w kontekście serwerów właśnie.
AMD ma ok.20% mocy produkcyjnych u TSMC,jeśli chodzi o 7nm.
@Blind Podwiesisz temat?
