seedan
[Zamknięty]Serwery Riverbed CX770 oraz CXA1555
Dzień dobry,
do sprzedania mam następujące serwery:
Riverbed CX770 - 5 szt cena do negocjacji, zacznijmy od 2000zł szt
4 GB Memory
320 GB 2.5 " HDD Drive
160 GB 2.5" HDD Drive Intel SSD
12 V AC Adapter
Riverbed Steelhead CXA-01555-B010 - 5szt, zacznijmy od 2000zł szt
Processor: AMD Opteron 4122 @ 2.2 GHz, 4 Cores
Mermory: 8GB DDR3 ECC Reg PC3
PCI-Express Slots: 2x PCIe x8
HDD-Fr: 4 x WD 500GB Enterprise Class
3,5 " 8,89 cm
Remote Management: 1x RJ-45
Interface: 7x RJ-45, 2x USB, 1x SerialPort
LAN-Ports: 2x RJ-45
AC : 2x 450Watt
Case Size 19 cali 48,26 cm Rack
Size (BxHxT): 485 x 42 x 690 mm
Waga: 16 KG
The Riverbed SteelHead CX series features dedicated WAN optimization appliances, ideal for organizations that want to improve application performance and data transfers served over a wide area network. The series is engineered for seamless network integration into remote sites and data centers, with scalable performance designed to support a growing number of users, devices, and data.
As a result, SteelHead CX breaks through the application-performance barrier, helping you deliver on your application SLAs, while also optimizing your networking budgets. Whether you are an international Navy needing to optimize communication with a distributed fleet or an enterprise building out your private cloud, the SteelHead CX series delivers the performance and ROI necessary to ensure your project’s success.
Designed to provide the highest performing and most scalable WAN optimization solution for any sized environment, SteelHead CX appliances accelerate business applications, speed data transfers, and optimize WAN bandwidth costs to improve user productivity and simplify IT management across geographic boundaries.
Używane, sprawne - zasilacz, dyski w komplecie - można odebrać w Warszawie
Cena do negocjacji, FV możliwa
Edytowane przez seedan
