Greexowy
Blue screen - memory magement
Ostatnio dosyć często wywala mi BSOD z kodem Memory Managment. Ostatnio wymieniałem kartę graficzną, a błąd wywala w losowych momentach.
Uzyłem programu WinDbg Preview aby zobaczyć cały plik dmp, oto on:
Cytat
*                        Bugcheck Analysis                                    *
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041792, A corrupt PTE has been detected. Parameter 2 contains the address of
	the PTE. Parameters 3/4 contain the low/high parts of the PTE.
Arg2: ffff96000002bff8
Arg3: 0000080000000000
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 3656
    Key  : Analysis.DebugAnalysisProvider.CPP
    Value: Create: 8007007e on DESKTOP-O9L0MSA
    Key  : Analysis.DebugData
    Value: CreateObject
    Key  : Analysis.DebugModel
    Value: CreateObject
    Key  : Analysis.Elapsed.mSec
    Value: 15490
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 82
    Key  : Analysis.System
    Value: CreateObject
    Key  : WER.OS.Branch
    Value: vb_release
    Key  : WER.OS.Timestamp
    Value: 2019-12-06T14:06:00Z
    Key  : WER.OS.Version
    Value: 10.0.19041.1
ADDITIONAL_XML: 1
OS_BUILD_LAYERS: 1
BUGCHECK_CODE:  1a
BUGCHECK_P1: 41792
BUGCHECK_P2: ffff96000002bff8
BUGCHECK_P3: 80000000000
BUGCHECK_P4: 0
MEMORY_CORRUPTOR:  ONE_BIT
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  MSIAfterburner.exe
STACK_TEXT:
fffffc05`40eb50f8 fffff807`0f54ccaa     : 00000000`0000001a 00000000`00041792 ffff9600`0002bff8 00000800`00000000 : nt!KeBugCheckEx
fffffc05`40eb5100 fffff807`0f4e9526     : 00000000`00000000 ffffe400`12983700 00000000`0000001a ffff9600`0002bff8 : nt!MiDeleteVa+0x153a
fffffc05`40eb5200 fffff807`0f4e963b     : ffff964b`00000000 ffffe400`12983700 fffffc05`00000000 fffffc05`40eb5670 : nt!MiWalkPageTablesRecursively+0x776
fffffc05`40eb52a0 fffff807`0f4e963b     : ffff964b`25800000 ffffe400`12983700 fffffc05`00000001 fffffc05`40eb5680 : nt!MiWalkPageTablesRecursively+0x88b
fffffc05`40eb5340 fffff807`0f4e963b     : ffff964b`25800000 ffffe400`12983700 fffffc05`00000002 fffffc05`40eb5690 : nt!MiWalkPageTablesRecursively+0x88b
fffffc05`40eb53e0 fffff807`0f4d859b     : 00000000`00000000 ffffe400`12983700 00000000`00000003 fffffc05`40eb56a0 : nt!MiWalkPageTablesRecursively+0x88b
fffffc05`40eb5480 fffff807`0f54b541     : fffffc05`40eb5620 ffffe400`00000000 ffff9600`00000002 00000000`00000000 : nt!MiWalkPageTables+0x36b
fffffc05`40eb5580 fffff807`0f5229a0     : 00000000`00000001 fffffc05`00000000 ffffe400`12983550 ffffe400`12cb9580 : nt!MiDeletePagablePteRange+0x4f1
fffffc05`40eb5890 fffff807`0f904aa9     : ffffe400`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiDeleteVad+0x360
fffffc05`40eb59a0 fffff807`0f904882     : ffffe400`11b50b40 00000000`00000000 ffffe400`12983080 00000000`00000000 : nt!MiUnmapVad+0x49
fffffc05`40eb59d0 fffff807`0f9046f9     : ffff1949`440dd645 00000000`0019f998 00000000`770b4660 00000000`00000000 : nt!MiUnmapViewOfSection+0x152
fffffc05`40eb5ab0 fffff807`0f606bb5     : ffffe400`12cb9580 00007ff8`a3047f01 fffffc05`40eb5b80 ffffe400`12983080 : nt!NtUnmapViewOfSectionEx+0x99
fffffc05`40eb5b00 00007ff8`a462f714     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
00000000`0009e5e8 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff8`a462f714
MODULE_NAME: hardware
IMAGE_NAME:  memory_corruption
STACK_COMMAND:  .thread ; .cxr ; kb
FAILURE_BUCKET_ID:  MEMORY_CORRUPTION_ONE_BIT
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {e3faf315-c3d0-81db-819a-6c43d23c63a7}
Followup:     MachineOwner
Co może powodować ten błąd?
Edytowane przez Greexowy
Procesor
A tak na poważnie to czego tu nie rozumiesz?
Edytowane przez Atak_Snajpera
53 minuty temu, Atak_Snajpera napisał:
Procesor
Wczoraj przeskanowałem ram memtestem i wywalało błędy jednej kości, wymieniłem i działa.
