steven69
Pikseloza w Project Diablo 2
Cześć,
chciałem pograć w Project Diablo 2 na laptopie Dell Latitude e5440 z Win10 ale po odpaleniu pojawia się pikseloza, pewnie brak wygładzania krawędzi.
Jak to naprawić, wie ktoś ?
Edytowane przez steven69
Reszta działa dobrze tylko pixeloza ? Co masz w ddraw.ini ?
Mój tak wygląda.
; cnc-ddraw - https://github.com/CnCNet/cnc-ddraw - https://cncnet.org
; ### NOTE TO PROJECT DIABLO 2 PLAYERS ###
; To enable upscaling via shaders in -fullscreen mode- just change 'fullscreen=false' to 'fullscreen=true'
; To enable upscaling via shaders in -windowed mode- just resize your window or set 'width=' and 'height=' to the desired window size
[ddraw]
; ### Optional settings ###
; Use the following settings to adjust the look and feel to your liking
; Stretch to custom resolution, 0 = defaults to the size game requests
width=1920
height=1080
; Override the width/height settings shown above and always stretch to fullscreen
; Note: Can be combined with 'windowed=true' to get windowed-fullscreen aka borderless mode
fullscreen=false
; Run in windowed mode rather than going fullscreen
windowed=true
; Maintain aspect ratio - (Requires 'handlemouse=true')
maintas=false
; Windowboxing / Integer Scaling - (Requires 'handlemouse=true')
boxing=false
; Real rendering rate, -1 = screen rate, 0 = unlimited, n = cap
; Note: Does not have an impact on the game speed, to limit your game speed use 'maxgameticks='
maxfps=144
; Vertical synchronization, enable if you get tearing - (Requires 'renderer=auto/opengl/direct3d9')
; Note: vsync=true can fix tearing but it will cause input lag
vsync=false
; Automatic mouse sensitivity scaling  - (Requires 'handlemouse=true')
; Note: Only works if stretching is enabled. Sensitivity will be adjusted according to the size of the window
adjmouse=false
; Preliminary libretro shader support - (Requires 'renderer=opengl') https://github.com/libretro/glsl-shaders
; 2x scaling example: https://imgur.com/a/kxsM1oY - 4x scaling example: https://imgur.com/a/wjrhpFV
shader=Shaders\xbr\xbr-lv3.glsl
; Window position, -32000 = center to screen
posX=-32000
posY=-32000
; Renderer, possible values: auto, opengl, gdi, direct3d9 (auto = try direct3d9/opengl, fallback = gdi)
renderer=opengl
; Developer mode (don't lock the cursor)
devmode=false
; Show window borders in windowed mode
border=false
; Save window position/size/state on game exit and restore it automatically on next game start
; Possible values: 0 = disabled, 1 = save to global 'ddraw' section, 2 = save to game specific section
savesettings=1
; Should the window be resizeable by the user in windowed mode?
resizeable=true
; Enable C&C video resize hack - Stretches C&C cutscenes to fullscreen
vhack=false
; ### Compatibility settings ###
; Use the following settings in case there are any issues with the game
; Hide WM_ACTIVATEAPP and WM_NCACTIVATE messages to prevent problems on alt+tab
noactivateapp=false
; Max game ticks per second, possible values: -1 = disabled, 0 = emulate 60hz vblank, 1-1000 = custom game speed
; Note: Can be used to slow down a too fast running game, fix flickering or too fast animations
; Note: Usually one of the following values will work: 60 / 30 / 25 / 20 / 15 (lower value = slower game speed)
maxgameticks=0
; Gives cnc-ddraw full control over the mouse cursor (required for adjmouse/boxing/maintas)
; Note: Set this to 'false' if your cursor becomes invisible at some places in the game
handlemouse=true
; Windows API Hooking, Possible values: 0 = disabled, 1 = IAT Hooking, 2 = Microsoft Detours, 3 = IAT+Detours Hooking (All Modules), 4 = IAT Hooking (All Modules)
; Note: Change this value if windowed mode or upscaling isn't working properly
; Note: 'hook=2' will usually work for problematic games, but 'hook=2' must be combined with renderer=gdi
hook=4
; Force minimum FPS, possible values: 0 = disabled, -1 = use 'maxfps=' value, 1-1000 = custom FPS
; Note: Set this to a low value such as 5 or 10 if some parts of the game are not being displayed (e.g. menus or loading screens)
minfps=0
; Disable fullscreen-exclusive mode for the direct3d9/opengl renderers
; Note: Can be used in case some GUI elements like buttons/textboxes/videos/etc.. are invisible
nonexclusive=false
; Force CPU0 affinity, avoids crashes/freezing, *might* have a performance impact
singlecpu=true
Cytat
[ddraw]
width=1366
height=768
fullscreen=true
windowed=true
maintas=false
boxing=false
maxfps=60
vsync=false
adjmouse=false
shader=Shaders\xbr\xbr-lv2-noblend.glsl
posX=-32000
posY=-32000
renderer=opengl
devmode=false
border=false
savesettings=1
resizeable=true
vhack=false
noactivateapp=false
maxgameticks=0
handlemouse=true
hook=4
minfps=0
nonexclusive=false
singlecpu=true
