Kszyrztow
The Callisto Protocol
Patrząc na zmiany w ostatnim patchu no to wychodzi że grę zdecydowanie ułatwili - widać spory lament na forum f
[v. 3.01] January 19, 2023
NEW GAME+
  • Users who previously completed the game will have access to NewGame+ after the patch.
    • Application restart may be required.
    • Requires an active save file from game completion.
GLOBAL
  • Fixed an issue where some users were not correctly granted the "The Protocol is About Life" achievement
  • Added New Game Plus. Complete the game to unlock New Game Plus and carry your pression over to a new save. All weapons, upgrades, and Callisto Credits can be collected at the first Reforge
  • General performance optimizations across all platforms
  • Players no longer take damage when vaulting over obstacles
  • Fixed multiple issues where certain camera angles or progression paths could cause environments to stream out and allow Jacob to fall through the ground
  • Consistency pass on cabinets, lockers, and shelves to display correctly in High Contrast mode
  • Voice leveling and subtitle mismatch adjustments across localized languages
PC
  • Fixed low frequency crash in the Tunnels level during the Two Head fight
  • Skip Cinematics button has been mapped to the Interact/Pickup input
  • Fixed a long hitch when enabling Ray-Traced Shadows in the main menu
  • Prevented mouse cursor from displaying during some area transitions
PS4
  • Fixed low frequency crash in Snowcat when Jacob is talking to Dani
[v. 2.01] December 15, 2022
GLOBAL
COMBAT OPTIMIZATION
  • Prevent enemies from attacking while you are attacking another enemy by adjusting uninterruptible windows for all player baton attacks vs standard enemies to add an extra 7 frames between hit and recover
  • Reduced frequency of players being attacked from behind. Enemies now prioritize grappling or repositioning instead of attacking
  • Widened incoming attack camera angle
  • Widened angle for dodging off screen attacks
  • Reduced damage taken multiplier when attacked from behind
  • Increased player facing away maximum angle for Grunt and Blind
  • Dodge optimization:
    • Valid dodge angle now allows player to have stick slightly forward and right/left while still dodging (45 -> 30 degrees)
    • Dodging at the end of the dodge window no longer means playing dodge animation and getting hit
  • Increased animation speed for:
    • Health injector usage
    • Weapon swapping
    • Weapon reloading
    • Upper receiver swapping
  • Auto-play reload animation when switching to an empty weapon
  • Continue initiated weapon swaps after interruptions
  • Extend amount of time between KTV appearance and mutation
  • Fixed phantom arm kills by armless NPCs
  • Increased audio cue volume for Danglers
  • Reduced default setting for camera shake
  • Added player invulnerable window to all 150 cm vaults
  • Changed Two Head to a two hit kill on the player in Medium Security, and a three hit kill in Minimum Security
  • Final boss encounter combat optimizations
  • Minetown AI pathing and spawning improvements
PERFORMANCE AND STABILITY
  • Optimized streaming to reduce memory usage in:
    • Habitat Water Maze
    • Snowcat Bridge Collapse
  • Fixed a memory leak with the Reforge 3d Printers
LOCALIZATION
  • Fixed voice leveling issues in multiple languages
  • Fixed subtitle/vo mismatch issues in Korean
  • Fixed instances of unlocalized lines in multiple languages
  • Fixed incorrect text descriptions on menus in Korean
  • Fixed untranslated instances of “Unlocked” on doors in multiple languages
  • Fixed instances of missing voice processing in multiple languages
OTHER
  • Added an option to enable performance mode when creating new games
  • Added an option to skip death cinematics and restart from checkpoint faster
PC
  • Improved lighting performance on AMD cards (reduced VGR pressure of FDeferredLightPS)
  • Fixed an exploit that allowed players to receive the "The Protocol is About Life" achievement after beating the game once on a lower difficulty
PS5
  • Optimized lighting for multiple cinematics in Habitat and Tower
[v. 1.02] December 06, 2022
PC
  • Added popup dialog to display when players change ray-tracing settings and trigger a shader compile
  • Added a popup progress dialog to display in the main menu when compiling shaders
  • (Epic Specific) Fixed an issue preventing achievements from unlocking and displaying correctly
  • (Epic Specific) Fixed an issue causing the Terms Of Service to always display upon loading the app
Teraz np walcząc z dwugłowym bossem to atak który nas dosięga ręką nie zabija nas na miejscu, tylko zabiera nieco zdrowia, tak samo widze że znerfili ostatniego bossa jak to określili "zooptymalizowali" heh a wystarczyło nieco pokombinować i boss był easy (tak jak pisałem wymanewrować go) teraz to nawet pewno nie trzeba będzie kombinować tylko kilka serii z karabinu i po sprawie.
Ciekawe czy da to jakiś skok dla takich kart typu RTX 2060 Super i podobnych wydajnościowo.
Da bo to zwykla poprawka wydajnosci w grze wiec na kazdej karcie beda zyski.Tym bardziej, ze gry na UE od strony cpu i po wlaczeniu RT leza na premiere.
To dobrze. Nie wiem kiedy wyjdzie jakieś fabularne DLC, ale wtedy na pewno sobie drugi raz przejdę.
Latem ;)
Fi7c_oQVEAAUQGj?format=jpg&name=900x900
Dzisiaj był kolejny patch, u mnie niewiele się zmieniło:
ultra@1440p średni fps 88 ze spadkami poniżej 60ciu w dwóch miejscach w benchmarku
custom ultra@1440p z cieniami z high na medium fps 111 bez spadków poniżej 60ciu w benchu ;)
Edytowane przez lamparcicho
