czarny1910
logi do sprawdzenia
Ktoś pomoże odczytać gdzie leży przyczyna rozłączania WAN?
Jan 25 21:40:43 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 10 mbps full duplex
Jan 25 21:41:05 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 25 21:41:08 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 1000 mbps full duplex
Jan 25 21:41:18 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 25 21:41:21 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 1000 mbps full duplex
Jan 25 21:41:51 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 25 21:41:53 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 10 mbps full duplex
Jan 25 21:42:33 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 25 21:42:36 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 1000 mbps full duplex
Jan 25 21:51:27 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 25 21:52:03 kernel: eth2 (Int switch port: 2) (Logical Port: 2) (phyId: a) Link Up at 1000 mbps full duplex
Jan 25 22:42:15 WAN Connection: Fail to connect with some issues.
Jan 25 22:42:15 nat: apply redirect rules
Jan 25 22:42:18 kernel: eth4 (Int switch port: 4) (Logical Port: 4) (phyId: c) Link Up at 1000 mbps full duplex
Jan 25 22:42:20 WAN Connection: Ethernet link up.
Jan 25 22:42:20 rc_service: wanduck 1226:notify_rc restart_wan_if 0
Jan 25 22:42:25 pppd[19133]: pppd 2.4.7 started by admin, uid 0
Jan 25 22:42:41 kernel: eth4 (Int switch port: 4) (Logical Port: 4) (phyId: c) Link DOWN.
Jan 25 22:42:43 kernel: eth4 (Int switch port: 4) (Logical Port: 4) (phyId: c) Link Up at 1000 mbps full duplex
Jan 25 22:42:45 nat: apply nat rules (/tmp/nat_rules__eth4)
Jan 25 22:42:45 nat: apply redirect rules
Jan 25 22:42:48 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 10 mbps full duplex
Jan 25 22:43:00 pppd[19133]: Timeout waiting for PADO packets
Jan 25 22:43:01 miniupnpd[19440]: Listening for NAT-PMP/PCP traffic on port 5351
Jan 25 22:43:01 kernel: Archer TCP Pure ACK Enabled
Jan 25 22:43:03 ntp: start NTP update
Jan 25 22:43:10 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 25 22:43:13 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 1000 mbps full duplex
Jan 25 22:43:26 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 25 22:43:29 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 1000 mbps full duplex
zaczyna brakować mi pomysłów... rozłącza WAN przynajmniej raz dziennie, wifi w tym momencie też przerywa...
Edytowane przez czarny1910
A co to za urządzenie z tym problematyczny WANem?
IMHO wygląda na problem z kablem. Podłącz jakiś komputer pod WAN innym sprawdzonym kablem i zobacz czy port się podniesie na gigabicie i nie spadnie.
Pod router podpięta ps5, pc i tv, w momencie rozłączenia pc był wyłączony.
A jak mogę konkretnie sprawdzić, co jest podłączone pod port 0? na routerze w 2 wpięta sonka, w 3 i 4 kolejno tv i pc
A przykładowo port 0 to może być kabel od dostawcy który wpinam w WAN?
dziś rano pod nieobecność znów:
Jan 26 08:56:34 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 26 08:56:37 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 1000 mbps full duplex
Jan 26 08:56:45 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 26 08:56:48 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 1000 mbps full duplex
Jan 26 08:57:27 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link DOWN.
Jan 26 08:57:29 kernel: eth0 (Int switch port: 0) (Logical Port: 0) (phyId: ? Link Up at 10 mbps full duplex
Na to wygląda że port WAN to eth0.
Czyli co, dzwonić do dostawcy o wymianę kabla? U siebie go nie ruszałem w chacie, od 3 lat w jednym miejscu pod listwami
Wszystko zależy czy dostawca odpowiada za kabel pod listwami...
Ale zgłosić problem możesz, bo może jest jakaś awaria po ich stronie.
Dostawca, oni montowali u mnie kabel aż do routera, bo to prywatny dostawca. dzięki za pomoc, zobaczymy co się wydarzy :E
Jakby miał ktoś podobny problem, u mnie faktycznie kabel WAN zawinił, dostawca zmienił, od ręki problemy ustały, dzięki za pomoc
