===MARK===
K-Lite Codec Pack 2.11 Full RC11
K-lite Codec Pack to zestaw kodeków potrzebnych do bezproblemowego (w większości przypadków) odtwarzania plików multimedialnych. Zamiast pieczołowicie i pracochłonnie gromadzić wszystkie po kolei - otrzymujemy całość w pigułce. Obecnie doczekaliśmy sie jedenastej wersji RC (Release Candidate) 2.06 tego programu - v2.11 RC11.
Zawartosc K-Lite Codec Pack 2.10 Full:
BSplayer 0.86.501
DivX Pro Decoding 5.1
DivX Pro Encoding 5.1
DivX ;) MPEG-4 Low and Fast motion 4.1.0.3927
XviD Decoding Koepi's build 24/06/2003 and 04/10/2002
XviD Encoding Koepi's build 24/06/2003
3ivX 4.0.4
Windows Media 7.1.0.3055
Windows Media 8.0.0.371
Windows Media VCM 9.0.1.369
Cyberlink DVD decoder 5.0.0.803
Ligos MPEG-2 decoder 4.0.77
Elecard MPEG-2 decoder 2.0.0.2525
huffyuv 2.1.1
Ligos Indeo XP 5.2820.15.58
Intel Indeo 4.51.16.2
Intel Indeo 3.24.15.03
Intel I.263 2.55.1.16 (for NT systems only)
WMA DirectShow decoder 8.0.0.4487
AC3 DirectShow decoder 0.70b
Fraunhofer IIS MPEG Layer-3 DirectShow decoder 1.9.0.311
Fraunhofer IIS MPEG Layer-3 ACM Codec 1.2.0.63
LAME MP3 ACM Codec 3.93.1
Ogg Vorbis DirectShow splitter 0.9.9.6
Ogg Vorbis DirectShow decoder (CoreVorbis) 1.0b5
AAC DirectShow decoder (CoreAAC) 1.0b7
MusePack DirectShow decoder 1.0.0.2
Matrix Mixer 0.30b
Morgan Multimedia Stream Switcher 0.9.7
DirectVobSub (vsfilter) 2.29
Matroska DirectShow splitter 1.0.1.8
DivX Anti-Freeze 0.4
FourCC Code Changer
GSpot Codec Information Appliance 2.21 build 030711
Zmiany:
Updated DivX decoder to 5.1.1 beta2
Added MatrixMixer configuration shortcut
Now you can install either version 5.1 or version 5.0.5 of the DivX encoder
Added On2 VP6
Added On2 VP3 codec
Added Voxware DirectShow decoder
Updated DirectVobsub to version 2.30
Updated Matroska Splitter to version 1.0.1.9
Updated BSplayer to version 1.00.800
Added AAC parser
Added AVI DirectShow splitter 1.0.0.3
Added SHOUTcast Source 1.0.0.1
Updated 3ivx to version D4 4.5
Removed XviD decoders
Pobierz
http://www.storage.cidernet.pl/modules.php...article&sid=695
hmm, mam jeden teledysk który mi przestał działać bo niemam jakiś kodeków, zobaczymy czy to pomoże :-)
Sciagnij sobie programik Gspot 2.1 - on Ci pokaze jakiego kodeku Ci brakuje - nie bedziesz musial instalowac wszystkich :)
w K-lite Codec Pack jest ten programik
P.S. Dzieki za powitanie :)
[Edytowane: 20/11/2003 przez ===MARK===]
W/g mnie kodeki wszelkiej masci, tylko mieszaja. Ja polecam     Ffdshow
Ten filtr jest niestabilny jesli masz divxy. Bardzo lubi wykrzaczac eksploratora windows.
Podalem alfe? Sorry...ffdshow-20020617. Ten jest stabilny. Chociaz ja z alfa problemow nie mam...
fddshow jest naprawdę niezły, szczególnie jeśli masz jakąś kinówkę i chcesz poprawić jej jakość.
