Krzyn
2x16GB 3200, czy 2x8GB 3600?
Witam.
Jak sądzicie, czy lepiej dokupić drugą kość 16GB 3200, aby zrobić 32GB, czy zmienić na 2x8GB 3600?
Mam aktualnie Kingston Fury 1x16GB 3200. Tak, przypadkowa i głupia pomyłka przy zamówieniu. Uważacie, że lepiej dokupić drugą kość 16GB 3200, czy zmienić je na 2x8GB 3600? Dlaczego w ogóle chce to zrobić? Bo uważam, że mam trochę za mało FPS w Warzone. Średnio 120-130, gdzie na testach wyciągają przy identycznych ustawieniach nawet do 180 max.
Reszta specyfikacji
13600KF, 3060Ti, B660 MSI
Dzięki z góry
Edytowane przez Krzyn
Whether it is better for you to buy a second 16GB 3200 die to make 32GB or change to 2x8GB 3600 depends on a few factors:
  1. Compatibility: Make sure that the new RAM is compatible with your motherboard, check the RAM's specifications and compare it with the motherboard's specifications.
  2. Speed: Generally, faster RAM (3600) will result in better performance, particularly in games like Warzone where there is a lot of data that needs to be processed quickly.
  3. Capacity: Having more RAM (32GB) will provide more memory for your games and applications to use, which can help to reduce stuttering and improve performance.
  4. Price: consider the price of the options, if the difference in price is not significant then it's better to buy the faster and bigger RAM.
Based on the information you've provided, it sounds like you may be experiencing some performance issues in Warzone, and you're looking to improve your FPS. Upgrading to 2x8GB 3600 RAM would likely give you a boost in performance, particularly in games like Warzone that require a lot of memory. Additionally, having more memory can help to reduce stuttering and improve overall performance. However, it's important to make sure that the new RAM is compatible with your motherboard and that the price is reasonable before making a purchase.
Dziękuję. Czyli 2x8GB 3600 da mi lepszą wydajność, niż 2x16GB 3200 na ten moment, więc będzie lepszym wyborem?
A swoją 1x16GB sprzedam, więc zawsze jakaś część kasy się zwróci. :D
Możesz przecież podkręcić tą pamięć 3200MHz. Ważne też jakie będziesz miał timingi na danej prędkości.
Szczerze nigdy się nie bawiłem w takie rzeczy. Ja wolę kupić i niech jest, a jak zacznie być za slabe, to nie upgraduje, a sprzedaje i kupuje nowe. Dlatego też wolałbym tutaj się nie bawić i kombinować, tylko kupić, wsadzić i ma działać. 😅 Ramy to nie są jakieś wielkie pieniądze. Dlatego się zastanawiałem co jest bardziej opłacalne. Dokupienie 16GB do Duala i zapomnieć, czy bawić się i kupować nowe 2x8GB 3600 i sprzedawać ten. Czy duży przyrost poczuje przy wymianie na 2x8GB 3600, niż 2x16GB 3200, czy gra nie jest warta świeczki i prościej dokupić 16GB 3200 i już.
Wszystko jak zwykle opiera się nie o same kości RAM tylko o kontroler pamięci w samym CPU. To, że płyta główna gwarantuje np. zasięg działania do 4000MHz nie oznacza, że kontroler pamięci w Twoim CPU na to pozwoli. Tak samo 2x8GB to co innego niż 4x8GB, które jednak bardziej wykorzystują kontroler pamięci w CPU. Podkręcenie pamięci RAM z 3200MHz na 3600MHz to nie jest jakaś wielka filozofia, jeszcze z fabrycznym napięciem 1.35V no ale skoro nie masz na to ochoty i nie planujesz wymiany platformy przez dłuższy czas to równie dobrze możesz sprzedać to co masz i kupić 2x8GB 3600MHz skoro nie chcesz bawić się w OC tego co już masz. Z drugiej strony to też zależy w jakiej rozdzielczości grasz bo im wyższa tym większy profit z wyższej częstotliwości taktowania i timingów pamięci RAM. Jeśli grasz w 1080p to równie dobrze możesz sobie dokupić kolejną kość 16GB 3200MHz i tyle w temacie. Warto jednak pamiętać, że sama ilość pamięci RAM (16GB, 32GB) ma właściwie żaden wpływ na wzrost wydajności - liczy się częstotliwość oraz timingi.
Edytowane przez caleb59
Dziękuję za szczegółowe rozjaśnienie. Generalnie gram w 1080 i głównie na low, bez wyjątku. W grach ma być dla mnie wydajnie, a nie błyszczące ściany. Tym bardziej, że gram tylko w gry multi. Po prostu wpadłem na ten pomysł, bo gość na testach w tej samej specyfikacji wyciągał średnio 150+ fps, a ja wyciągam srednio 130. Dlatego pomyślałem, że problem może tutaj tkwić w tym, że ram jest w singlu.
Oczywiście, że dual channel da jakieś przyrosty więc warto zawsze mieć podstawowo dwie kości w kompie.
Opiera się również o RAM, wiele/większość kości ma bardzo słaby potencjał OC.
W dniu 18.01.2023 o 08:31, Krzyn napisał:
Witam.
Reszta specyfikacji
Dzięki z góry
Jeśli nie kręcisz memek, to 2x16GB 3200MHz będą wyraźnie szybsze, pod warunkiem że są to kości Dual Rank, inaczej różnice się zacierają. Absolutnie najważniejsze, by mieć Dual Channel, do tego Warzone potrafi luzem wejść ponad 16GB RAMu.
Akurat od Alder Lake'a dual ranki niewiele pomagają.
Nom niestety przy alder dualrank nic nie dawał, przy raptorze jest pewnie to samo czy coś się zmieniło :> 🤔
Dobra. To zamawiam druga kostkę 16GB do Dual Channel, bo podsumuwajac wątek, jest to podstawa i mus, mam rację? :D
Dzięki wszystkim za pomoc
Tak chodzi o sam dual bo jakbys miał 2x8 to mógłbyś spokojnie na tym siedzieć dalej
Oki, druga kość już zamówiona.
Dzięki
Witam. Kość dołożyłem. Włożyłem w 2 i 4 slot.
CPU-Z pokazuje Channel 2x64bit.
Nie powinno być napisane Dual? Przynajmniej chyba kiedyś tak było.
Tak trochę pograłem i faktycznie, jest lepiej, ale taka średnia fpsów w Warzone to 140. To się polepszyło, bo miałem średnio 120-130. Wciąż w sumie mnie zastanawia i mam wrażenie, że dałoby się lepiej.
TEST 13600 + 3060TI Warzone
Tutaj gość ewidentnie ma trochę więcej fpsów. On przeważnie ma 150,160, w skokach nawet do ok 200.
U mnie najwięcej podczas gry zobaczę 170 klatek. Jak patrzałem testy 3200 vs 3600 Mhz, to różnica w Warzone to jakieś zaledwie 1-3 fps.
Myślicie, że skąd może wynikać ta różnica? Ustawienia graficzne 1:1 to co ten chłop.
a pamięć pracuje synchronicznie z kontrolerem?
A jak można sprawdzić synchroniczność? :D Masz na myśli, że ramy może pracują na niższym taktowaniu? Xmp?
czy pracują w gear 1 bo przy ddr4 masz mieć gear 1 do 3600mhz
A ziomek nie będzie miał dużo lepszych kostek po prostu? Nie dość, że ma 3600MHz, to jeszcze masz nędzne Hynixy.
Swoją drogą wychodzi na to, że miałem ustawiony profil 2 XMP i pracowały na 2400? W CPU-Z miałem w Mem controller freq 1200 (x2 2400), a teraz po zmianie na 1 mam 1600 (x2 3200).
  • Sad 1
Na to wychodzi.
    • O tym, że od momentu nadania do chwili wydania masa paczki się nie zmieniła. Czyli argument pt.: kurier ukradł byłby mocno wątpliwy. A przecież OD TEGO się zaczęło
    • @ladyskylar Zakupiłaś już coś? Warto się przymierzyć np. do takich: Egohuman od Grospol Ergo 700/800 od Bemondi Xilium G od Nowy Styl Jak fotel ma być do pracy to ma być wygodny, tym bardziej gdy są już jakieś bóle. tylko właśnie najlepiej przymierzyć, sprawdzić gdzieś w sklepie. Te co wymieniłem to już wyższa półka, ale to głównie fotele ergonomiczne (Xilium łączy ergonomię z gamingowym stylem). Duże możliwości regulacji i co najważniejsze, wsparcie odcinka lędźwiowego. Xilium ma w ogóle trochę inny sposób podparcia pleców, też trzeba przymierzyć, bo to rozwiązanie już bardzo specyficzne. Wiele sklepów online, jak wspomniane wyżej przez @armt oferuje możliwość bezpłatnego zwrotu towaru, nawet po zmontowaniu (tak wymieniałem kiedyś Grospol IOO na Ergohuman), proszą tylko w miarę możliwości o wymontowanie podstawy z siłownikiem z mechanizmu pod siedziskiem, a to się robi w prosty sposób kluczem francuskim. Właśnie, IOO od Grospol też jest ciekawą i dość wygodną konstrukcją, pod warunkiem że komuś odpowiada wyprofilowane siedzisko. Wiele zależy też od tego jaki masz budżet.
    • Wyobraźcie sobie zwykłego Zahira w Indiach. Jest rok 2016 i Zahir ma aspiracje, patrzy na cenę GPU ze średniej półki ... $250 (+podatki) za GTX 1060 6GB. Niestety Zahira nie stać, jest zmuszony kupić GT 730. Jednak Zahir nie jest usatysfakcjonowany biedakartą i biedakompem. Zahir chce podnieść swój poziom życiowy i komputerowy. Teraz jest rok 2023, Zahir nie robi już kupy na zewnątrz, ma teraz swoją własną toaletę. Zadowolony z siebie, patrzy na ceny nowych kart ze średniej półki ... $700 (+podatki) za RTX 4070 Ti 12GB. Niestety, Zahira znowu nie stać. Stać go za to na najtańszy model - RTX 4050 96-bit 6GB za $250 (+podatki), który jest tylko odrobinę szybszy od RTX 3050 albo GTX 1070. Zahir jest niezadowolony ale kupuje 4050. Postanawia, że w przyszłości będzie go stać na kartę ze średniej półki. Mija 7 lat, jest rok 2030 i Zahir sprawdza sklep ze sprzętem komputerowym ... karta Nvidii ze średniej półki kosztuje $1500 (+podatki). Zahira znowu nie stać. Kupuje najtańszy dostępny nowy model za $600 (+podatki). Smutne ale możliwe. 😔
    • https://twitter.com/techepiphany/status/1637591899639799810?s=46&t=B5CpTGNctT6It-cxP7EJbw Sprzedaż gpu w MF.
    • tak myślę, sam tak kupiłem 3tyg temu asusa TUF, tu na forum... daj ogłoszenie w dziale kupię, wertuj na spokojnie allegro, olx pokoparkowe też nie muszą być złe, wszystko zależy jak długo kopały, czy pełen komplet z dokumentami ( np faktura zakupu na 10szt ) pudełko ze zgodnym numerem seryjnym itd itp. Albo cena, Chłopak tu parę dni temu kupił 6700xt mecha za 1300zł, wtedy można się zastanowić... ogarnąć mu krzywą UV, sćiągnąć plastikowy backpalte itd itp, coś za coś   parę dni temu tu chopak z forum : https://allegro.pl/oferta/inno3d-geforce-rtx-3060-ti-twin-x2-lhr-8-gb-gw-2l-13319643451
