Dominix1910
Last Epoch - PC
Nie można zmienić profesji, można zresetować punkty jak i umiejętności.
Użyłem po raz pierwszy Rune of ascendance i od razu wypadł dagger Smoke Weaver pod build :E
Hello Travelers,
In between attempting to save the citizens of Eterra, and eradicating them, almost 70,000 of you have joined in with your voices to discuss mid-cycle balance changes. The turnout for this survey has been fantastic; and further, is in addition to the many discussions here on the forums and other platforms on the topic. We want to first thank you all for your enthusiasm on this topic driving it forward.
Today, we want to share the results of the survey, as well as the decisions which have come as a result of the feedback.
LE_Steam_1.0-MidCycleSurvey-RECAP
For the purpose of reading the below results, the following information can help:
  • Scale:
    • 1 - Strongly Disagree
    • 2 - Disagree
    • 3 - I have no opinion on this topic
    • 4 - Agree
    • 5 - Strongly Agree
  • When we first started the survey, the scale was in reverse. We received immediate feedback about this, and swapped it before too many results came in. While the results below do not reflect this change, we made this change very early into survey so it had minimal impact on the results
OVERPERFORMING BUGS
With over 74% of all votes in the survey crushing the other options, as well as in written feedback, the stance from the involved community is fairly clear. We should be fixing bugs which cause skills or items to highly overperform, and as such, will be doing so. This is a change from our previous stance where we didn’t want to alter balance mid-cycle. Now, if it’s the case of a bug, we will be pushing out these fixes in mid-cycle patches.
MILDLY OVERPERFORMING BUGS
In the case of a bug resulting in a build, skill, or item mildly overperforming, there’s a much less clear stance. From written feedback, it’s a bit clear as to why: What is “mildly” overperforming? Being a bit of a vague categorization, it’s left up to an individuals interpretation.
We have decided in this case to use case-by-case discretion. This would be based on feedback we’re seeing in the community, and just how far the bug results in a power shift. So we may chose to, or not to fix bugs which are ‘mildly’ overperforming mid-cycle and will discuss them as they arise.
OVERPERFORMING BALANCE
On the other hand, if a build is overperforming, but not caused by a bug, the feedback has largely weighted towards “do not change”. While not quite as one sided as with bugs, this is still a fairly strong sentiment from the community with over 57% voting not to make these changes. This also matches our existing stance as well, in not taking too many steps to alter balance mid-cycle. As such, we’ll be avoiding balance changes which are not bug related, even if it’s resulting in a build, skill, or item highly overperforming.
MILDLY OVERPERFORMING BALANCE
As one might expect, as the power from something not bug-related becomes less impactful, the desire is even less for changes to be seen to them. Weighted quite heavily towards no changes, we agree with this stance and will not be making balance changes mid-cycle which are not bug related, and only result in the skill, build, or item mildly over-performing.
MID-CYCLE LEADERBOARD RESET
In the event that we release a change or bug-fix which was resulting in an item, skill, or build to overperform, the desire for leaderboards to reset has been quite mixed. We discussed this a fair amount, and have made the following determination: We will not reset leaderboards in this instance, however, we will instead add information to the entry to indicate when the entry occurred. The goal of this being to make the information available to identify entries which may have used a build that has since changed.
We decided against a mark or icon on the entry indicating it was an overperforming build, as we didn’t want these to appear as a “mark of shame”. We felt this was the best way to be able to allow competitive players to continue competing on the leaderboards, without taking away other player’s previous hard work on their builds, even if they were overperforming.
PARTIAL LEADERBOARD RESET
While the above answer also addresses this question, for consistency we want to show the results of all of your votes here.
NOTIFICATIONS VIA PUBLIC POSTS
To everyone’s surprise, it looks like almost everyone agrees that receiving notifications about upcoming balance altering bugfixes or changes is a very strong desire. As we’ve been showing this last week since we started getting feedback on the survey, we fully agree with this, and will start trying to provide more head’s up when these changes are coming.
Though with this, we will still reserve the right to not provide information regarding the upcoming change if: Doing so would result in players rushing to take advantage causing severe issues, or we could release the fix almost as fast as releasing the notification that the fix is coming
So for these changes, if we feel we can release the information in full about the change, we’ll do so. Otherwise, we may try to be more vague (such as with the Infernal Shade infinite damage bug) to limit its impact before the change, or we may withhold it completely if it’s something which is regularly crashing servers when it’s utilized to minimize its impact until we can get it fixed.
CONCLUSION
This round of discourse with the community has resulted in some great changes to our stances that we’re quite happy with. The two big changes here being:
  • We will release fixes mid-cycle for bugs which result in an item, skill, or build highly overperforming
  • We will add leaderboard functionality displaying which specific patch, or timespan an entry happened during.
Once again, we’d like to thank everyone for your involvement in Last Epoch, and taking the time to make your voices heard. It’s with all of your feedback we’ve made Last Epoch as great as it is, and is only by continuing to work with the community and listening to feedback that we’ll continue to improve.
Until next time, may RNG be with you Travelers!
Ciekawe kiedy pojawią się osiągnięcia na Steam.
Przydałyby się.
Pomimo 69 poziomu latam wciąż z jakimiś głownie żółtymi itemkami, bo co się uda lepszego wydropić to nie posiada interesujących mnie skilli.
A broń to już w ogóle... co widzę to jakieś dwuręczne topory głownie dla Nekromanty ze skillami boostującymi Minionki.
Szkoda, że ten Planer Builda nie przelicza cyferek na ten moment. Chętnie bym się dowiedział jak dane rozdysponowanie punktów wpływa na obrażenia i defensywę.
Edytowane przez Szambo
jak widzisz bronie które nie są dla ciebie to musisz aktualizowac albo zrobic filtr lootu, tak aby pokazywalo tylko to czego potrzebujesz.
Będę musiał to ogarnąć.
Wrzucałem tutaj filmik Raxxa jak to zrobic.
Można ściągnąć filtr z maxroll dla danego buildu i go poprawić. Ja np. dodałem kolorowanie części które mają 3 affixy z endgame, nie muszę sprawdzać czy się nadaje, od razu widzę.
Jak w grze działają obrażenia?
Powiedzy, że mamy:
Miecz z bazowymi 100 obrażeniami i mamy sufiksy:
+ 50 obrażeń wręcz
+ 50 obrażeń od pustki
+ 100% obrażeń wręcz
+ 100% obrażen od pustki.
To czy taki miecz zada: (biorąć pod uwagę jak ja na ten moment rozumiem obrażenia)
300 obrażeń wręcz bo (100 + 50)*100%
100 obrażeń od pustki bo 50*100%?
Dzięki.
Jakoś muszę to zrozumieć, bo moje badanie użyteczności broni polega głownie na tym, że podmieniam w inwentarzu i sprawdzam jak się zmieniły obrażenia od skilli.
Póki co wychodzi, że najważniejsze bazowe obrażenia typu:
+52 melee damage, void damage niż
+70% void damage, bo te procenty i tak są liczone od bazowych obrażeń.
chyba lepiej testowac na trainning dummy, gdzie widzisz obrazenia zadawane.
Przydałyby się.
Po 200h ja sobie robię pass -  kupuje League passa żeby się odchamić w innych grach.
Ta gra jest super i będzie jeszcze lepsza ale co za dużo to nie zdrowo:) Więc pewnie wrócę za parę tygodni - pewnie jak mi się znudzi kolejny sezon w d4
ja dopiero 50h, 87lev na jednej postaci i od czasu do czasu pykam, nie jest zle, pewnie do 4 sezonu w d4 pogram i zmiana
U mnie na razie 34h i też 87 lvl
Ja mam dopiero 11 godzin i 48 level na razie, zacząłem grać magiem, i szczerze mówiąc to byłem nieźle rozczarowany, granie magiem było nudne, monotonne i nie sprawiało mi frajdy, ale jako drugą klasę dodałem mistrza run i to był strzał w dziesiątkę, rozpierducha że aż milo :thumbup:
Ja po 50 godzinach robię sobie odpoczynek... do 83 poziomu dotarłem i nie mam póki co parcia na levelowanie Void Knighta. Poczekam może na osiągnięcia i wtedy wrócę.
Przez tyle godzin podropiłem pełno Unikatów akurat nie dla mnie :D
Dramat... nawet nie mam z czym kombinować, żeby robić przedmioty legendarne.
Ja mam 84h, właśnie dobijam 100lev, korupcje max mam max 240 wiec bez szalu :D mam troche unikatow z potencjalem 2-3 i troche fioletowych aby sprobowac je wsadzic i jak cos sie uda i dam rade robic wyzej to moze do 300 korupcji podciagne i zacnze sie troche druidem bawic bo mam go na 18lev czekajac do maja.
Ja mam na tyle słabiutki build, że mam problem z Oroborosem i korupcja za bardzo nie idzie do góry. Zresztą nie dotarłem do finałowego Monolitu jeszcze.
Grind większy niż w D4, ale bardziej prosty i przejrzysty. Jak widzę że ktoś ma korupcję 1000 to mnie skręca ile godzin musiał klepać :D
Last Epoch Roadmap <-   Link dla osób z białym tłem
Hello, Travelers,
We are thrilled to give you an early look at what's coming for Last Epoch over the next few cycles!
As always, the team here at Eleventh Hour Games is dedicated to making the ARPG of our dreams, and we all know that’s a process that takes time, determination, and commitment. As of this writing, we have brought on excellent new people, continue looking for more, and are developing new and exciting content faster than ever. Our roadmap continues to showcase that we have long-term plans for Last Epoch and its content, and we are excited to showcase it here today.
Here’s the thing about roadmaps, though: we are striving to be one of the best and most community-centered game studios in the industry, and oftentimes the best-laid plans of Groles and Gods need to change. While this could be for a variety of reasons; the primary one is you, the community. As each new cycle is released, we plan to collaborate with the community to let you know what’s being worked on, listen to your feedback and suggestions for those plans, and continuously monitor how we can improve.
Each of the items listed on the roadmap are just a few examples of key features we plan to introduce for that cycle and do not represent the only things being worked on. Rest assured; the team is working harder and developing faster than before while also expanding with many new team members to bring you the game you deserve and produce a whole host of other features we have planned beyond those listed on the roadmap!
As we move toward each new patch, we also plan to update our roadmap to keep you informed of our plans and any changes that may have been made based on feedback we hear from the community!
We plan to update the roadmap just after Update 1.2 and again after Update 1.4.
Pinnacle Content - Realm Release Timing Poll
Lastly, development for 1.1 is coming along nicely, and we’re excited to show you all of the great content, balances, bug fixes, and end-game pinnacle boss content coming along with it. Over the last few months, the community has started discussing Cycles and how content is made available to both Legacy and new Cycle characters. Our current plan for the 1.X series of patches is to bring all content to Offline, Cycle, and Legacy realms; but we also believe in allowing Cycle characters a small bit of time to attempt new pinnacle content before extremely well-geared and optimized Offline and Legacy characters have a chance to showcase just how fast they can conquer it.
For a refresher, existing Cycle characters will be moved to Legacy at the beginning of a new Cycle. Creating new Cycle characters will give everyone an even playing field with an economy reset and the need to re-roll a new separate character. Cycle is also where people may compete on that Cycle’s leaderboards.
With that said, we would love to hear from you about our currently proposed plans. Please take just a few minutes (it is 4 questions) and help us continue to grow with our community.
Link to Poll: https://forms.gle/58bE39Q2uTrUZFea6
Thank you for your amazing support thus far fellow Travelers, and we look forward to seeing you once again in the world of Eterra.
Edytowane przez Dominix1910
Jak wklejasz coś z innego źródła, usuwaj formatowanie bo czasem czytać nie idzie :)
