popey7
Medal of Honor a win XP
Ładuje się gierka i ......
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
D:gryMOFHmainPol.pk3 (504 files)
D:gryMOFHmainPAK5.PK3 (259 files)
D:gryMOFHmainPAK4.PK3 (593 files)
D:gryMOFHmainPAK3.PK3 (669 files)
D:gryMOFHmainPAK2.PK3 (4722 files)
D:gryMOFHmainPAK1.PK3 (772 files)
D:gryMOFHmainPAK0.PK3 (11175 files)
D:gryMOFH/main
18694 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
execing configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 186
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:WINDOWSSystem32opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
i wyskakuje powyższy błąd oco chodzi ???????
Pomocy !!!!!!!
zainstaluj sobie stery do grafiki bo pewnie pracujesz na standardowych windowsa
Z tego logu wychodzi, ze gra wykrywa, ze masz 3dfx nie moze załadowac opengl no i nic dziwnego bo 3dfx wkprowadził własną ulepszoną interpretacje openGl nazwali to podajrze minigl lub cos w tym stylu, ale przy oakzji wyrzuca tez ze nei mzoe zaladowac glide, wieć polecam reinstalkę sterow do 3dfx chyba, że nie masz 3dfx wtedy jest problem:)
ja gralem w nia pod XP'kiem bez najmniejszych problemow
Posłuchaj kolegów i zainstaluj sterowniki do karty graficznej, bo standardowe windowsowe nie posiadają OpenGL i takie gierki jak MOHAA i Q3 nie będą na nich działać. MOHAA działa bez problemu pod XP, bo zacinam w nia prawie codziennie :)
jaki jest najnowszy detonator do nvidi pod XP i gdzie go szukać??
http://www.nvidia.com
Albo na PcLabie (chyba jest z tego co pamiętam)
