MeneVes
Jak zrobic skrypt w JS (kopiowanie tekstu do schowka) aby działał również pod operą....... :( ??
Witam..
Nie moge nigdzie znalezc zadnego skrypta ktory by kopiowal jakis tekst rowniez pod przegladarka Opera. Mam tylko taki: (dziala pod mozilla, IE)
<script language="javascript" type="text/javascript">
function copy_clip(meintext){
if (window.clipboardData)
window.clipboardData.setData("Text", meintext);
else if (window.netscape)
netscape.security.PrivilegeManager.enablePrivilege('UniversalXPConnect');
var clip = Components.classes['@mozilla.org/widget/clipboard;1'].createInstance(Components.interfaces.nsIClipboard);
if (!clip) return;
var trans = Components.classes['@mozilla.org/widget/transferable;1'].createInstance(Components.interfaces.nsITransferable);
if (!trans) return;
trans.addDataFlavor('text/unicode');
var str = new Object();
var len = new Object();
var str = Components.classes["@mozilla.org/supports-string;1"].createInstance(Components.interfaces.nsISupportsString);
var copytext=meintext;
str.data=copytext;
trans.setTransferData("text/unicode",str,copytext.length*2);
var clipid=Components.interfaces.nsIClipboard;
if (!clip) return false;
clip.setData(trans,null,clipid.kGlobalClipboard);
alert("Following info was copied to your clipboard:nn" + meintext);
return false;
user_pref("signed.applets.codebase_principal_support", true);
Tekscior
HELP!
