Femolo
Problem z nautilusem,
http://img206.imageshack.us/my.php?image=snapshot1ca2.png
Jak włączam kompa to pojawia sie taki bląd, gdy probóje odpalic nautilusa z konsoli to wypada to:
femo@femo-desktop:~$ sudo nautilus
(nautilus:5307): Gtk-WARNING **: Self Mount Volume: missing action
(nautilus:5307): Gtk-WARNING **: Self Unmount Volume: missing action
(nautilus:5307): Gtk-WARNING **: Self Eject Volume: missing action
(nautilus:5307): Gtk-WARNING **: Self Format Volume: missing action
(nautilus:5307): Gtk-CRITICAL **: find_menu_position: assertion `GTK_IS_WIDGET (prev_child)' failed
(nautilus:5307): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(nautilus:5307): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
ALSA lib confmisc.c:1105:(snd_func_refer) Unable to find definition 'defaults.pcm.ipc_key'
ALSA lib conf.c:3479:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:3947:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2146:(snd_pcm_open_noupdate) Unknown PCM dmix:CA0106
