above181
Carbon i ati 9600 pro a brak motion blur'a
Witam posiadam radeona 9600 pro plus najnowsze stery, sp2(xp), dx9.0c i dalej nie moge wlaczyc motion blur w grze bo jest poprostu niedostepny. W poprzednich czesciach bez problemu ba w innych grach, a tutaj nie moge dlaczego ?
a tutaj dxdiag:
System Information
Time of this report: 12/13/2006, 14:23:20
Machine name: AMD
Operating System: Windows XP Professional (5.1, Build 2600) Dodatek Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: Polish (Regional Setting: Polish)
System Manufacturer: American Megatrends Inc.
System Model: Uknown
BIOS: Version 1.00
Processor: AMD Sempron, MMX, 3DNow, ~2.0GHz
Memory: 768MB RAM
Page File: 321MB used, 1556MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file ati2dvag.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: The file cmaudio.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9600 Series (Omega 3.8.291)
Manufacturer: ATI Technologies Inc. (Omega 3.8.291)
Chip type: ATI RADEON 9600 Series AGP (0x4152)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4152&SUBSYS_0200174B&REV_00
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (85Hz)
Monitor: FLATRON 775FT
Monitor Max Res: 1280,1024
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6635 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/23/2006 03:53:30, 260096 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/d
Mini VDD: ati2mtag.sys
Mini VDD Date: 8/23/2006 03:53:14, 1723904 bytes
Device Identifier: {D7B71EE2-0212-11CF-106D-0A22A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4152
SubSys ID: 0x0200174B
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: C-Media Wave Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_13F6&DEV_0111&SUBSYS_011113F6&REV_10
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: cmaudio.sys
Driver Version: 5.12.0001.0635 (English)
Driver Attributes: Final Debug
WHQL Logo'd: No
Date and Size: 1/29/2002 02:43:14, 370382 bytes
Other Files:
Driver Provider: C-Media
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 17, 16
Static/Strm HW 3D Bufs: 17, 16
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: Yes, Yes
Sensaura ZoomFX: Yes
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\system32\drivers\gm.dls
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
C-Media Wave Device, Software (Kernel Mode), Output, DLS, Internal
Mapowanie MIDI [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, Internal
Syntezator SW Microsoft GS Wave [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401 [Emulowany], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mysz
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Klawiatura
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ G| Vendor/Product ID: 0x1039, 0x7001
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:54:52, 57600 bytes
| Driver: usbd.sys, 10/26/2001 19:03:24, 4736 bytes
Gameport Devices
+ Magistrala PCI
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/3/2004 23:54:52, 68608 bytes
+-+ Standardowy port gier
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/3/2004 23:08:22, 10624 bytes
+ CMI8738/C3DX PCI Audio Device
| Location: Magistrala PCI 0, urz| Matching Device ID: pci\ven_13f6&dev_0111&subsys_011113f6&rev_10
| Service: cmpci
| | Service: gameenum
PS/2 Devices
+ Standardowa klawiatura 101/102 klawisze lub Microsoft Natural Keyboard PS/2
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 23:54:52, 53504 bytes
| Driver: kbdclass.sys, 8/3/2004 23:54:52, 24960 bytes
+ Sterownik klawiatury serwera terminali
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:44:40, 40840 bytes
+ Mysz zgodna z HID
| Vendor/Product ID: 0x15CA, 0x00C3
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/3/2004 23:54:52, 23296 bytes
| Driver: mouhid.sys, 10/26/2001 19:03:24, 12160 bytes
+ Sterownik myszy serwera terminali
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Speedtouch Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 kilobitów/s
Voxware SC06 6,4 kilobitów/s
Voxware SC03 3,2 kilobitów/s
MS-PCM 64 kilobitów/s
MS-ADPCM 32.8 kilobitów/s
Microsoft GSM 6.10 13 kilobitów/s
TrueSpeech 8.6 kilobitów/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 3.0 GB
Total Space: 26.7 GB
File System: FAT32
Model: WDC WD800BB-00JHC0
Drive: D:
Free Space: 9.6 GB
Total Space: 49.6 GB
File System: FAT32
Drive: E:
Model: HL-DT-ST DVD-RAM GSA-H22L
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Polish), 8/3/2004 23:54:52, 49536 bytes
Drive: F:
Model: LITE-ON LTR-52327S
Drive: G:
Model: Generic DVD-ROM SCSI CdRom Device
System Devices
Name: CMI8738/C3DX PCI Audio Device
Device ID: PCI\VEN_13F6&DEV_0111&SUBSYS_011113F6&REV_10\3&61AAA01&0&68
Driver: n/a
Name: Rozszerzony kontroler hosta PCI do USB SiS
Device ID: PCI\VEN_1039&DEV_7002&SUBSYS_70011849&REV_00\3&61AAA01&0&1A
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:54:52, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:54:52, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (Polish), 8/4/2004 00:44:14, 77312 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:54:52, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/3/2004 23:54:52, 7168 bytes
Name: Otwarty kontroler hosta PCI do USB SiS 7001
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_70011849&REV_0F\3&61AAA01&0&19
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/3/2004 23:54:52, 17024 bytes
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_70011849&REV_0F\3&61AAA01&0&18
Name: Kontroler SiS PCI IDE
Device ID: PCI\VEN_1039&DEV_5513&SUBSYS_55131849&REV_00\3&61AAA01&0&15
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Polish), 8/3/2004 23:54:52, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 23:54:52, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (Polish), 10/26/2001 19:03:24, 3456 bytes
Name: Karta PCI Fast Ethernet oparta na SiS 900
Device ID: PCI\VEN_1039&DEV_0900&SUBSYS_82011849&REV_90\3&61AAA01&0&20
Driver: C:\WINDOWS\system32\DRIVERS\sisnic.sys, 1.16.0000.0005 (English), 8/3/2004 22:31:36, 32768 bytes
Name: Mostek (bridge) standardu PCI do CPU hosta
Device ID: PCI\VEN_1039&DEV_0746&SUBSYS_00000000&REV_10\3&61AAA01&0&00
Driver: n/a
Name: Mostek (bridge) SIS PCI do ISA
Device ID: PCI\VEN_1039&DEV_0008&SUBSYS_00000000&REV_25\3&61AAA01&0&10
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (Polish), 10/26/2001 19:03:24, 36224 bytes
Name: SiS Accelerated Graphics Port
Device ID: PCI\VEN_1039&DEV_0002&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\GAGP30KX.SYS, 5.01.2600.2180 (English), 8/3/2004 23:07:44, 46464 bytes
Name: RADEON 9600 Series Secondary (Omega 3.8.291)
Device ID: PCI\VEN_1002&DEV_4172&SUBSYS_0201174B&REV_00\4&1C526AC9&0&0108
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6635 (Polish), 8/23/2006 03:53:14, 1723904 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0008 (English), 8/23/2006 03:43:22, 45056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 8/23/2006 04:14:38, 35056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 7/17/2006 15:52:46, 58560 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 7/19/2006 17:08:04, 929 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 7/19/2006 17:08:04, 917986 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6635 (English), 8/23/2006 03:53:30, 260096 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0319 (English), 8/23/2006 03:14:40, 290816 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 8/23/2006 03:46:48, 26112 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0431 (English), 8/23/2006 03:38:44, 2401984 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0117 (English), 8/23/2006 03:33:46, 2510752 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 8/16/2006 19:52:54, 133583 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 8/23/2006 03:44:38, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 8/23/2006 03:19:52, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 16:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4142 (English), 8/23/2006 03:45:14, 413696 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4142 (English), 8/23/2006 03:46:30, 86016 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2506 (English), 8/23/2006 03:47:14, 114688 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0016 (English), 8/23/2006 03:46:56, 77824 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2504 (English), 8/23/2006 03:46:42, 41984 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0041 (Polish), 8/23/2006 03:21:16, 221184 bytes
Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.02.2425.37013 (Polish), 8/23/2006 03:33:48, 303104 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 6/22/2006 15:02:06, 6126 bytes
Driver: C:\WINDOWS\system32\DIRECTX.CPL, 5.04.0000.3900 (English), 9/30/2004 17:17:14, 135168 bytes
Driver: C:\WINDOWS\system32\atfchtxx.hlx, 2/22/2006 02:05:00, 24589 bytes
Driver: C:\WINDOWS\system32\atfchsxx.hlx, 2/22/2006 02:05:00, 26864 bytes
Driver: C:\WINDOWS\system32\atfaraxx.hlx, 2/22/2006 02:05:00, 24652 bytes
Driver: C:\WINDOWS\system32\atfcsyxx.hlx, 2/22/2006 02:05:00, 24569 bytes
Driver: C:\WINDOWS\system32\atfdanxx.hlx, 2/22/2006 02:05:00, 24065 bytes
Driver: C:\WINDOWS\system32\atfdeuxx.hlx, 2/22/2006 02:05:00, 24557 bytes
Driver: C:\WINDOWS\system32\atfellxx.hlx, 2/22/2006 02:05:00, 25224 bytes
Driver: C:\WINDOWS\system32\atfenuxx.hlx, 2/22/2006 02:05:00, 23224 bytes
Driver: C:\WINDOWS\system32\atfespxx.hlx, 2/22/2006 02:05:00, 24382 bytes
Driver: C:\WINDOWS\system32\atffinxx.hlx, 2/22/2006 02:05:00, 24260 bytes
Driver: C:\WINDOWS\system32\atffraxx.hlx, 2/22/2006 02:05:00, 24640 bytes
Driver: C:\WINDOWS\system32\atfhebxx.hlx, 2/22/2006 02:05:00, 27697 bytes
Driver: C:\WINDOWS\system32\atfhunxx.hlx, 2/22/2006 02:05:00, 24892 bytes
Driver: C:\WINDOWS\system32\atfitaxx.hlx, 2/22/2006 02:05:00, 24506 bytes
Driver: C:\WINDOWS\system32\atfjpnxx.hlx, 2/22/2006 02:05:00, 49807 bytes
Driver: C:\WINDOWS\system32\atfkorxx.hlx, 2/22/2006 02:05:00, 66161 bytes
Driver: C:\WINDOWS\system32\atfnldxx.hlx, 2/22/2006 02:05:00, 24186 bytes
Driver: C:\WINDOWS\system32\atfnorxx.hlx, 2/22/2006 02:05:00, 24229 bytes
Driver: C:\WINDOWS\system32\atfplkxx.hlx, 2/22/2006 02:05:00, 26138 bytes
Driver: C:\WINDOWS\system32\atfptbxx.hlx, 2/22/2006 02:05:00, 24712 bytes
Driver: C:\WINDOWS\system32\atfrusxx.hlx, 2/22/2006 02:05:00, 25327 bytes
Driver: C:\WINDOWS\system32\atfsvexx.hlx, 2/22/2006 02:05:00, 23980 bytes
Driver: C:\WINDOWS\system32\atfthaxx.hlx, 2/22/2006 02:05:00, 24873 bytes
Driver: C:\WINDOWS\system32\atftrkxx.hlx, 2/22/2006 02:05:00, 48174 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dll, 6.14.0010.3045 (English), 2/22/2006 09:15:00, 380928 bytes
Driver: C:\WINDOWS\system32\atiicdxx.sys, 6.13.0010.1005 (English), 2/22/2006 09:13:56, 6144 bytes
Driver: C:\WINDOWS\system32\atiicdxx.vxd, 4/15/2003 08:07:14, 7849 bytes
Driver: C:\WINDOWS\system32\Atiiprxx.exe, 2/22/2006 02:05:00, 36864 bytes
Driver: C:\WINDOWS\system32\atipdsxx.dll, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 274432 bytes
Driver: C:\WINDOWS\system32\atiphexx.exe, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 61440 bytes
Driver: C:\WINDOWS\system32\atippaxx.dll, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 114688 bytes
Driver: C:\WINDOWS\system32\atiprbxx.exe, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 139264 bytes
Driver: C:\WINDOWS\system32\atiptaxx.exe, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 344064 bytes
Driver: C:\WINDOWS\system32\atipuixx.dll, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 2060288 bytes
Driver: C:\WINDOWS\system32\atmaraxx.cnt, 2/22/2006 02:05:00, 2220 bytes
Driver: C:\WINDOWS\system32\atmaraxx.hlx, 2/22/2006 02:05:00, 155364 bytes
Driver: C:\WINDOWS\system32\atmchsxx.cnt, 2/22/2006 02:05:00, 2047 bytes
Driver: C:\WINDOWS\system32\atmchsxx.hlx, 2/22/2006 02:05:00, 189356 bytes
Driver: C:\WINDOWS\system32\atmchtxx.cnt, 2/22/2006 02:05:00, 2070 bytes
Driver: C:\WINDOWS\system32\atmchtxx.hlx, 2/22/2006 02:05:00, 145421 bytes
Driver: C:\WINDOWS\system32\atmcsyxx.cnt, 2/22/2006 02:05:00, 2615 bytes
Driver: C:\WINDOWS\system32\atmcsyxx.hlx, 2/22/2006 02:05:00, 145641 bytes
Driver: C:\WINDOWS\system32\atmdanxx.cnt, 2/22/2006 02:05:00, 2704 bytes
Driver: C:\WINDOWS\system32\atmdanxx.hlx, 2/22/2006 02:05:00, 142359 bytes
Driver: C:\WINDOWS\system32\atmdeuxx.cnt, 2/22/2006 02:05:00, 2849 bytes
Driver: C:\WINDOWS\system32\atmdeuxx.hlx, 2/22/2006 02:05:00, 147444 bytes
Driver: C:\WINDOWS\system32\atmellxx.cnt, 2/22/2006 02:05:00, 2759 bytes
Driver: C:\WINDOWS\system32\atmellxx.hlx, 2/22/2006 02:05:00, 148083 bytes
Driver: C:\WINDOWS\system32\atmenuxx.cnt, 2/22/2006 02:05:00, 2610 bytes
Driver: C:\WINDOWS\system32\atmenuxx.hlx, 2/22/2006 02:05:00, 136272 bytes
Driver: C:\WINDOWS\system32\atmespxx.cnt, 2/22/2006 02:05:00, 2887 bytes
Driver: C:\WINDOWS\system32\atmespxx.hlx, 2/22/2006 02:05:00, 140040 bytes
Driver: C:\WINDOWS\system32\atmfinxx.cnt, 2/22/2006 02:05:00, 2822 bytes
Driver: C:\WINDOWS\system32\atmfinxx.hlx, 2/22/2006 02:05:00, 144213 bytes
Driver: C:\WINDOWS\system32\atmfraxx.cnt, 2/22/2006 02:05:00, 2917 bytes
Driver: C:\WINDOWS\system32\atmfraxx.hlx, 2/22/2006 02:05:00, 145090 bytes
Driver: C:\WINDOWS\system32\atmhebxx.cnt, 2/22/2006 02:05:00, 2411 bytes
Driver: C:\WINDOWS\system32\atmhebxx.hlx, 2/22/2006 02:05:00, 144323 bytes
Driver: C:\WINDOWS\system32\atmhunxx.cnt, 2/22/2006 02:05:00, 2729 bytes
Driver: C:\WINDOWS\system32\atmhunxx.hlx, 2/22/2006 02:05:00, 148616 bytes
Driver: C:\WINDOWS\system32\atmitaxx.cnt, 2/22/2006 02:05:00, 2884 bytes
Driver: C:\WINDOWS\system32\atmitaxx.hlx, 2/22/2006 02:05:00, 140646 bytes
Driver: C:\WINDOWS\system32\atmjpnxx.cnt, 2/22/2006 02:05:00, 2453 bytes
Driver: C:\WINDOWS\system32\atmjpnxx.hlx, 2/22/2006 02:05:00, 399936 bytes
Driver: C:\WINDOWS\system32\atmkorxx.cnt, 2/22/2006 02:05:00, 2633 bytes
Driver: C:\WINDOWS\system32\atmkorxx.hlx, 2/22/2006 02:05:00, 473475 bytes
Driver: C:\WINDOWS\system32\atmnldxx.cnt, 2/22/2006 02:05:00, 2767 bytes
Driver: C:\WINDOWS\system32\atmnldxx.hlx, 2/22/2006 02:05:00, 139835 bytes
Driver: C:\WINDOWS\system32\atmnorxx.cnt, 2/22/2006 02:05:00, 2545 bytes
Driver: C:\WINDOWS\system32\atmnorxx.hlx, 2/22/2006 02:05:00, 139810 bytes
Driver: C:\WINDOWS\system32\atmplkxx.cnt, 2/22/2006 02:05:00, 2763 bytes
Driver: C:\WINDOWS\system32\atmplkxx.hlx, 2/22/2006 02:05:00, 148498 bytes
Driver: C:\WINDOWS\system32\atmptbxx.cnt, 2/22/2006 02:05:00, 2776 bytes
Driver: C:\WINDOWS\system32\atmptbxx.hlx, 2/22/2006 02:05:00, 140307 bytes
Driver: C:\WINDOWS\system32\atmrusxx.cnt, 2/22/2006 02:05:00, 2560 bytes
Driver: C:\WINDOWS\system32\atmrusxx.hlx, 2/22/2006 02:05:00, 353829 bytes
Driver: C:\WINDOWS\system32\atmsvexx.cnt, 2/22/2006 02:05:00, 2577 bytes
Driver: C:\WINDOWS\system32\atmsvexx.hlx, 2/22/2006 02:05:00, 141746 bytes
Driver: C:\WINDOWS\system32\atmthaxx.cnt, 2/22/2006 02:05:00, 2430 bytes
Driver: C:\WINDOWS\system32\atmthaxx.hlx, 2/22/2006 02:05:00, 370049 bytes
Driver: C:\WINDOWS\system32\atmtrkxx.cnt, 2/22/2006 02:05:00, 2653 bytes
Driver: C:\WINDOWS\system32\atmtrkxx.hlx, 2/22/2006 02:05:00, 356937 bytes
Driver: C:\WINDOWS\system32\atricdxx.dft, 6.14.0010.2046 (English), 2/22/2006 09:13:28, 73728 bytes
Driver: C:\WINDOWS\system32\atricdxx.enu, 6.14.0010.2046 (English), 2/22/2006 09:13:30, 73728 bytes
Driver: C:\WINDOWS\system32\atrpuixx.ara, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 147456 bytes
Driver: C:\WINDOWS\system32\atrpuixx.chs, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 106496 bytes
Driver: C:\WINDOWS\system32\atrpuixx.cht, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 106496 bytes
Driver: C:\WINDOWS\system32\atrpuixx.csy, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 151552 bytes
Driver: C:\WINDOWS\system32\atrpuixx.dan, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 151552 bytes
Driver: C:\WINDOWS\system32\atrpuixx.deu, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 159744 bytes
Driver: C:\WINDOWS\system32\atrpuixx.ell, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 163840 bytes
Driver: C:\WINDOWS\system32\atrpuixx.enu, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 147456 bytes
Driver: C:\WINDOWS\system32\atrpuixx.esp, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 159744 bytes
Driver: C:\WINDOWS\system32\atrpuixx.fin, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 151552 bytes
Driver: C:\WINDOWS\system32\atrpuixx.fra, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 159744 bytes
Driver: C:\WINDOWS\system32\atrpuixx.heb, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 143360 bytes
Driver: C:\WINDOWS\system32\atrpuixx.hun, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 155648 bytes
Driver: C:\WINDOWS\system32\atrpuixx.ita, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 159744 bytes
Driver: C:\WINDOWS\system32\atrpuixx.jpn, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 118784 bytes
Driver: C:\WINDOWS\system32\atrpuixx.kor, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 114688 bytes
Driver: C:\WINDOWS\system32\atrpuixx.nld, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 155648 bytes
Driver: C:\WINDOWS\system32\atrpuixx.nor, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 151552 bytes
Driver: C:\WINDOWS\system32\atrpuixx.plk, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 155648 bytes
Driver: C:\WINDOWS\system32\atrpuixx.ptb, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 155648 bytes
Driver: C:\WINDOWS\system32\atrpuixx.rus, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 155648 bytes
Driver: C:\WINDOWS\system32\atrpuixx.sve, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 151552 bytes
Driver: C:\WINDOWS\system32\atrpuixx.tha, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 151552 bytes
Driver: C:\WINDOWS\system32\atrpuixx.trk, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 151552 bytes
Driver: C:\WINDOWS\system32\attaraxx.hlx, 2/22/2006 02:05:00, 43070 bytes
Driver: C:\WINDOWS\system32\attchsxx.hlx, 2/22/2006 02:05:00, 45991 bytes
Driver: C:\WINDOWS\system32\attchtxx.hlx, 2/22/2006 02:05:00, 44635 bytes
Driver: C:\WINDOWS\system32\attcsyxx.hlx, 2/22/2006 02:05:00, 44514 bytes
Driver: C:\WINDOWS\system32\attdanxx.hlx, 2/22/2006 02:05:00, 44687 bytes
Driver: C:\WINDOWS\system32\attdeuxx.hlx, 2/22/2006 02:05:00, 44814 bytes
Driver: C:\WINDOWS\system32\attellxx.hlx, 2/22/2006 02:05:00, 45762 bytes
Driver: C:\WINDOWS\system32\attenuxx.hlx, 2/22/2006 02:05:00, 40651 bytes
Driver: C:\WINDOWS\system32\attespxx.hlx, 2/22/2006 02:05:00, 44980 bytes
Driver: C:\WINDOWS\system32\attfinxx.hlx, 2/22/2006 02:05:00, 43310 bytes
Driver: C:\WINDOWS\system32\attfraxx.hlx, 2/22/2006 02:05:00, 45411 bytes
Driver: C:\WINDOWS\system32\atthebxx.hlx, 2/22/2006 02:05:00, 45632 bytes
Driver: C:\WINDOWS\system32\atthunxx.hlx, 2/22/2006 02:05:00, 45716 bytes
Driver: C:\WINDOWS\system32\attitaxx.hlx, 2/22/2006 02:05:00, 44109 bytes
Driver: C:\WINDOWS\system32\attjpnxx.hlx, 2/22/2006 02:05:00, 124376 bytes
Driver: C:\WINDOWS\system32\attkorxx.hlx, 2/22/2006 02:05:00, 141754 bytes
Driver: C:\WINDOWS\system32\attnldxx.hlx, 2/22/2006 02:05:00, 43526 bytes
Driver: C:\WINDOWS\system32\attnorxx.hlx, 2/22/2006 02:05:00, 43288 bytes
Driver: C:\WINDOWS\system32\attplkxx.hlx, 2/22/2006 02:05:00, 44430 bytes
Driver: C:\WINDOWS\system32\attptbxx.hlx, 2/22/2006 02:05:00, 45352 bytes
Driver: C:\WINDOWS\system32\attrusxx.hlx, 2/22/2006 02:05:00, 45580 bytes
Driver: C:\WINDOWS\system32\attsvexx.hlx, 2/22/2006 02:05:00, 41265 bytes
Driver: C:\WINDOWS\system32\attthaxx.hlx, 2/22/2006 02:05:00, 41943 bytes
Driver: C:\WINDOWS\system32\atttrkxx.hlx, 2/22/2006 02:05:00, 120302 bytes
Driver: C:\WINDOWS\system32\atiiprxx.exe, 2/22/2006 02:05:00, 36864 bytes
Driver: C:\WINDOWS\system32\atiicdxx.ini, 2/6/2000 00:02:16, 11 bytes
Driver: C:\WINDOWS\system32\ATI_CUBE.ICO, 2/22/2006 02:05:00, 20254 bytes
Driver: C:\WINDOWS\system32\omega_drivers.ico, 9/22/2003 00:41:40, 318 bytes
Driver: C:\WINDOWS\system32\omega_drivers.bmp, 9/15/2004 04:42:10, 34920 bytes
Driver: C:\WINDOWS\system32\SmartGart.lnk, 4/26/2004 23:40:38, 1439 bytes
Driver: C:\WINDOWS\system32\atiadaxx.exe, 6.14.0010.5183 (English), 2/22/2006 02:05:00, 1830912 bytes
Driver: C:\WINDOWS\system32\aticds10.dll, 6.14.0010.2087 (English), 2/22/2006 09:13:48, 348160 bytes
Driver: C:\WINDOWS\system32\atiicdxx.msi, 2/14/2006 02:29:26, 43008 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.6067 (English), 8/23/2006 03:24:58, 5140480 bytes
Driver: C:\WINDOWS\system32\atioglx1.dll, 6.14.0010.1091 (English), 8/23/2006 03:27:08, 6684672 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 8/23/2006 04:11:46, 307200 bytes
Name: RADEON 9600 Series (Omega 3.8.291)
Device ID: PCI\VEN_1002&DEV_4152&SUBSYS_0200174B&REV_00\4&1C526AC9&0&0008
Name: D347PRT SCSI Controller
Device ID: PCI\D347PRT\0000
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/17/2001 22:53:20 10496 bytes
d3d8.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:27:36 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 34816 bytes
dplay.dll: 5.00.2134.0001 Polish Final Retail 10/26/2001 18:29:28 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 229888 bytes
dpmodemx.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 10/26/2001 18:29:28 42768 bytes
dpwsockx.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 57856 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:44:20 30208 bytes
dpnsvr.exe: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:44:20 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:42:44 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:42:44 3584 bytes
dpvoice.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 212992 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/3/2004 23:44:20 83456 bytes
dpvvox.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 116736 bytes
dpvacm.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 60928 bytes
dpserial.dll: 5.00.2134.0001 Polish Final Retail 10/26/2001 18:29:28 54032 bytes
dinput.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 163328 bytes
dinput8.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 185856 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 10/26/2001 18:29:28 44032 bytes
diactfrm.dll: 5.01.2600.0000 Polish Final Retail 10/26/2001 18:29:28 394752 bytes
joy.cpl: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:44:30 69120 bytes
gcdef.dll: 5.01.2600.0000 Polish Final Retail 10/26/2001 18:29:30 77312 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:54:52 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:08:22 10624 bytes
dsound.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:58 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:58 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 72704 bytes
dmusic.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:56 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:56 82432 bytes
system.dll: 1.01.4322.2032 English Final Retail 12/8/2006 13:20:06 1224704 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 12/12/2006 21:24:06 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 12/12/2006 21:23:58 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 12/12/2006 21:24:00 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 12/12/2006 21:24:00 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 12/12/2006 21:24:00 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 12/12/2006 21:24:02 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 12/12/2006 21:24:02 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 12/12/2006 21:24:02 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 12/12/2006 21:24:04 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 12/12/2006 21:24:04 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 12/12/2006 21:24:06 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 12/12/2006 21:24:06 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 12/12/2006 21:24:06 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 12/12/2006 21:24:08 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 12/12/2006 21:24:08 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 12/12/2006 21:24:06 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 12/12/2006 21:24:06 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 12/12/2006 21:24:06 223232 bytes
dx7vb.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:58 619008 bytes
dx8vb.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:58 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:43:58 2113536 bytes
directx.cpl: 5.04.0000.3900 English Final Retail 9/30/2004 17:17:14 135168 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 10/26/2001 18:29:34 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/3/2004 23:44:02 1028096 bytes
wsock32.dll: 5.01.2600.2180 Polish Final Retail 8/3/2004 23:44:16 24064 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:43:54 70656 bytes
devenum.dll: 6.05.2600.2180 Polish Final Retail 8/3/2004 23:43:56 59904 bytes
dxmasf.dll: 6.04.0009.1125 Polish Final Retail 8/3/2004 23:43:58 499229 bytes
mciqtz.drv: 4.00.0096.0729 English Final Retail 8/17/1998 10:21:54 11776 bytes
mciqtz32.dll: 6.05.2600.2180 Polish Final Retail 8/3/2004 23:44:02 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:44:30 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:44:04 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:43:58 20480 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 13:44:28 221184 bytes
qcap.dll: 6.05.2600.2180 Polish Final Retail 8/3/2004 23:44:10 192512 bytes
qdv.dll: 6.05.2600.2180 Polish Final Retail 8/3/2004 23:44:10 279040 bytes
qdvd.dll: 6.05.2600.2180 Polish Final Retail 8/3/2004 23:44:10 386048 bytes
qedit.dll: 6.05.2600.2180 Polish Final Retail 8/3/2004 23:44:10 563200 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/3/2004 23:43:16 733696 bytes
quartz.dll: 6.05.2600.2749 Polish Final Retail 8/30/2005 04:56:14 1290752 bytes
quartz.vxd: Final Retail 8/17/1998 10:21:56 5672 bytes
strmdll.dll: 4.01.0000.3928 Polish Final Retail 8/3/2004 23:44:14 246302 bytes
vidx16.dll: 0.00.0000.0000 English Final Retail 8/17/1998 10:21:56 10240 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/3/2004 23:44:30 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/3/2004 23:44:30 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/3/2004 23:44:02 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/3/2004 23:44:02 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/3/2004 23:44:02 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/3/2004 23:44:02 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/3/2004 23:44:02 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/3/2004 23:44:30 154624 bytes
mswebdvd.dll: 6.05.2600.2180 Polish Final Retail 8/3/2004 23:44:06 204288 bytes
ks.sys: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:44:30 130048 bytes
ksuser.dll: 5.03.2600.2180 Polish Final Retail 8/4/2004 00:44:02 4096 bytes
stream.sys: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 Polish Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 Polish Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 Polish Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:54:52 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/3/2004 23:44:30 118272 bytes
msvidctl.dll: 6.05.2600.2180 Polish Final Retail 8/3/2004 23:44:06 1431552 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:44:30 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:54:52 17408 bytes
wstdecod.dll: 5.03.2600.2180 Polish Final Retail 8/3/2004 23:44:16 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.01.0000.0959
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
PP MPEG-1 Splitter,0x00805000,1,2,ppM1Splter.ax,2.02.0000.1919
ffdshow MPEG-4 Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0000.0001
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0000.0001
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0028
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0000.0001
CyberLink Editing Service (Source),0x00200000,0,2,CLEdtKrn.dll,2.00.0000.1311
PP Video Regulator,0x00200000,1,1,ppResample.ax,2.05.0000.1818
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0028
PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
PP MPEG Video Decoder,0x005fff00,2,3,CLMVD.ax,5.00.0000.0929
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3802
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo
Wątpie żeby komuś to chciało się czytać
Blur z Carbona wymaga shaderów 3.0.
Taki los :(.
:lol2:
po kiego grzyba to dałeś? poprostu karte podałeś i tyle wystarczyło żeby stwierdzić to że blura nie włączysz bo nie masz sm3.0
na drugi raz poszukaj tematu o danej gierce zamiast zasmiecac forum takimi tematami, w topicu o carbonie co 2 post byl "nie moge wlaczyc motion blura bo nie mam SM 3.0, ale i tak MB jest do dupy".
a jest blur w MW?
jesli tak to gdzie sie go włącza?
a jest blur w MW?
najlepiej w opcjach... boze co za glupi temat [raport]
