cervandes
Simlocki z BB5 za darmo
Stało się... dejan wypuscił za darmo solucję na BB5 z odpowiednim softem
Nokia BB5 Loger & Calculator (11.391 bytes)
Nokia BB5 loger & calculator can SP unlock 6630,6680,6681,n70,n90,...
with RAP3G v2,11 to v2,20 Nokia phones.
http://users.net.yu/~dejan/download/bb5.zip
Karwos twierdzi iż działa (tylko telefony z rap2.x)
Tutorial:
"ONLY
6630
6680
6681
N70
N71
N90
Can be unlocked only" czyli te starsze. Z 6280 np. nie działa.
warto sledzić wątek na gsmhostingu
http://www.gsmhosting.com/vbb/showthread.p...nload%2Fbb5.zip
Manual /juz dostepny in english/
My instructions:
1. Connect DKU-5 or normal COM cable to computer
2. Set proper COM cable (must be, between 1 and 9)
3. Download unlocker, run `install.bat`
4. Open file c:/bb5_unlocker/logs/bb5_unlocker.cfg and write here proper COM port (1-9)
5. Run c:/bb5 unlocker/BB5logunlocker.exe
6. Click READ PHONE
7. Click MAKE LOG, log will be created
8. Enter codes to phone (in /psw/ dir), or
9. Click SP UNLOCK to enter codes via FBUS
i
******* CONECTION ******
For this program you need Fbus cable like DK5, CA43 or similar conected to ports from COM1 to COM9.
First unpack zip fiole and strat install.bat
In file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" with any text editor change your COM port setings!
******* USING ********
Program can be started successfully only if is COM port in file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" adjusted properly.
READ PHONE:
Reading info data from phone and making BACKUP file for that phone( Field 308,1).
IMPORTANT DO NOT delete or modify that file because can save your *** if something goes wrong.
WR BACKUP:
With that function can write backup file with Field 308,1 if exist in BACKUP folder.
MAKE LOG:
Function for making log file . With that log file BB5_calc.exe calculating codes for unlock.
Working with BB5 phones with RAP3G v.2.x (6630,6680,6681,6682,n70,n90).
IMPORTANT phone must be without Sim card.
SP UNLOCK:
Making unlock with codes calculated by BB5_calc.exe.
SP UNLOCK PROCEDURE
Connect cable to PC and be shure com port is adjusted properly
Start BB5logunlocker.exe
Connect phone and switch on without Sim card.
press button READ PHONE and wait until get the message DONE.
If is everything correct you will see info from phone on screen.
Pres button make log and wait until get mesage done.
Log file is in folder LOGS.
Start BB5_calc.exe to make for you PSW file in folder PSW
Press button SP UNLOCK and unlock your phone.
That is all folks
If you got unlock codes from your provider and you used all yours 3 attempts
to enter code via keypad then do the following:
into dir "c:\bb5_unlocker\psw" create a file "aaaaaaaaaaaaaaa_BB5.psw" where is "aaaaaaaaaaaaaaa" enter your phones imei
then in that created file enter in the files start "#pw+bbbbbbbbbbbbbbb+c#" where is "bbbbbbbbbbbbbbb"
enter your unlock code and where is "c" enter your logs level number (1-7).
save the file and use "SP UNLOCK" function
Informacja od wielkiego autorytetu jeśli chodzi o sprawy gsm - Bakx'a.
Sprawdzał to ktoś? Zastanawiam się czy by mojej 6680 nie zoperować... :hmm:
Mam kabel DKU-2. Czy to zatrybi?
DKU-2 nie działa. Przynajmneij u mnie. Trzeba kupić DKU-5.
Jak ktoś sprawdzi to pędzę po 6630 na Allegro z Sim-Lockiem na "inną sieć" :P
działają wszystkie przewpdy z POPPORTEM, opróćz CA-53 (fabryczny z wielu modeli) z racji tego, że on nie emuluje portu com a to jest niezbędne. Sposób sprawdzony na DKU 2, działa.
co złamałeś ??
ma ktos ten plik na innym serwerze? Na ten chyba sie caly swiat rzucil i juz nie dziala:p
/edit
juz dziala, firefox cos grymasil :P
Już chciałem ze 2 dni temu kupować, ale niestety kasy brak. :E
Udało mi się zdjąć sima, myślałem że już nie działa ale poszło.
co złamałeś ??
SIMLOCKA ;)
N70 z Orange PL.
ja mam na góra 2 ale nie chcę wysłuchiwać od pewnej Pani co myśli o kupowaniu co chwila innego telefonu....i marnotrawieniu pieniędzy kiedy np podobno nowa pralka by się przydała... :E
No to suuuper. Wreszcie nie będzie trzeba zwracać uwagi na to czy jest Smok czy nie. :D
Skąd ja to znam, nie ma to jak radość z kupna pralki.
Wolisz mieć super fona, czy czyste ubrania?
to zalezy :E
ciekawe czy te mloty z allegro o tym wiedzą :D
no to wkoncu ile jest potwierdzonych przypdkow zdjecia solocka z bb5??
a ja z 2 tyg temu sprzedalem nokie 6630 z simlockiem na orange uk, a tak teraz bym mial fajny telefonik :(
nie mogles tego przewidziec :( wspolczucie...
panowie to pomozcie mi wybrac telefon... n70, 6680 cz 6630? :D
edit:
tylko mi aukcji nie podbijac zawistni ludzie
Mam nadzieję, że to nie działa :P
Co by ceny tych telefonów nie spadły :Up_to_s:
Po roku użytkowania mogłem sprzedać 6630 po takiej samej cenie (nowy-używany), a teraz jak zaczną ściągać z anglii to sprzedam za 20% tego co za niego dałem (wszyscy tak będą mieli, także się nie cieszcie zbytnio).
Dochodzi jeszcze wymówka, jak nie chcę pożyczać telefonu :D
czy kabel marki krzak bedzie dzialal rownie dobrze co oryginalny? bo to ponad 80zl roznicy
ja mam dku5 noki tylko że na usb a program potrzebuje com jak to przerobić prosze o porady ?? jaki program z jakiej stronki??
Kabel usb emuluje port com, sprawdź w menedżerze urządzeń.
Sprawa jest prosta
Padłącz kabel dku-5 do portu USB i poczekaj chwilkę
Natsępnie jeśli Windows poprosi Cię o sterownik do kabla to go zainstaluj
Po zainstalowaniu sterów wchodzisz do panelu sterowania i sprawdzasz na jakim porcie com pracuje Twój kabel
Następnie ten numer portu wpisujesz do pliku bb5_unlocker.cfg
potem powinieneś uruchomić magiczny pragramik a on powinien zacząć dzialać :D
Sprawa jest prosta
Ja mam natomiast inny problem
Ściągnąłem simlocka z N70 ORANGE PL bez problemu natomiast przy ściąganiu simlocka z 6680 także ORANGE PL coś poszło nie tak.
Podczas tworzenia logu (MAKE LOG) oczom moim ukazało się to co widać na obrazku a telefo zablokował się simlockiem i teraz ani nie da się go zdjąc ani nie można łożyć żadnej karty sim nawet orange pl ponieważ każda jest pokazywana jako nieważna.
Jeżeli ktoś mi może pomóc to bardzo proszę o wszelkie pomysły na to jak sobie z tym problemem poradzić
efekt jak przy rap innym niż wymagany:
a w wawie w serwisach nadal chca 150 za locka z bb5 :lol2: dzis mi koleszka w komisie powiedzial w czasie rozmowy ze jak mam wiedze jak sciagac simlocki z bb5 np z n70 w orange to da mi 50 telefonow i za kazdy zaplaci po 50 pln jak mu je odblokuje... :hmm: oczywiscie mowil to szyderczo drwiac ze mnie i bedac pewnym ze tego zrobic sie nie da...
