rzepak
Prince of Persia:Sands of Time
Pomozci emi przejsc etap Broken Bridge, To jest rowno polowa gry. A sie zaciolem. Tam jest most zawalony :D jak wskazuje nazwa etapu :D itrzeb azejsc na dol ale podloga sie zapada a ja nie wiem gdzie mam isc :(
Idz za głosem serca :E
albo rzuc pare screnow bo nie pamietam co bylo w polowie gry;)
Poczytaj sobie któryś z przewodników (FAQ/Walkthrough):
http://www.gamefaqs.com/computer/doswin/ga...game/36068.html
There's a Fountain around the right of the scaffolding if you need it, and a
SAND CLOUD around to the left.  Climb down the part of the bridge that just
broke off and lower yourself to a pipe.  Shimmy to the right and leap off to
the column behind you.  Jump to the next column, then to the lower ledge.
Shimmy all the way around the far side of the ledge.  Now, you have to get
down, and to do so safely, you need to wall jump down the walls.
Don't relax once you reach the bottom, because it's crumbling away as we
speak.  Quickly run to the left, wall-climb up the wooden wall and jump off
onto the pole.  Flip up to the ledge on your left.  Farah will shout things
at you, and you can drop down the other side of this wooden tower to a ledge.
Shimmy around and push off to the column behind you.  Grab the SAND CLOUD.
Now, grab the other column here, climb up, and jump off the ledge to the left
of Farah.  Shimmy around, and drop off to the lower ledge.  Farah will
mention that she's moving on ahead, and to meet back up at the baths.  After
she leaves, the Prince goes into a quick tirade about her and women in
general.  All you have to do is carefully use the Control Stick to manuever
across the thin wall.  Once on the other side, move along the ledge to the
right.  There's a Fountain here, if you need it.  Don't worry about the Birds
in this area, just wall-run the wall to camera left, then jump off and grab
the pole.  Flip across the series of poles to the Vortex.
[Edytowane: 13/8/2004 przez Richard]
juz to proponowalem, ale to przeciez po angielsku, a w dzisiejszych czasach malo kto umie ten jezyk :P
Dziwne, nie widzę twojego poprzedniego przed tym posta. :hmm:
A co do angola to racja :lol2:
tutaj nie, ale byly chyba juz dwa tematy tego samego pana na tepan PoP:SoT
LOL i dalej nie chce korzystać z FAQ/Walkthrough zamiast się pytać?
Nie jestem pewny czy dobrze pamietam.. ale przy broken bridge to sie chyba idzie w ktorys bok i skacze dosyc po roznych wystajacych z murow flagach czy cos... ojej... ta gra jest tak banalna, jak nie wiesz co zrobic to obejrzyj wizje!! Masz w tych wizjach totalnie wszystko pokazane!!! Gra sama w sobie prosta ale super fajna.
    • Ciekawy filozoficzny post, ja to odbieram inaczej - 9800X3D potrafi być 30% szybszy od 7800X3D i to przyrost w 18 miesięcy. Jeżeli upgrade dokonujesz w tej samych "widełkach" wydajnościowych zmieniajac starsze i5 na nowsze i5 to przyrost potrafi być przez 2 lata mniejszy niż nawet 5% za to energetycznie bywa że jest 30% lepiej, ostatecznie jest to jakaś ewolucja - pamiętaj że rozwój technologii jest iteratywny i polega na małych przyrostach które ostatecznie składają się na coś wielkiego ale ostatecznie masz rację - i7-2600 do dzisiaj może stanowić podstawę użytecznego komputera biurowego, skylake posłuszy pewnie i do 2030 w takich celach. Rasteryzacja w kartach graficznych faktycznie stoi nieco w miejscu, nVidia próbuje zrewolucjonizować rynek vendorlockowymi technikami jak swoje DLSSy, ostatecznie doprowadzi to do stagnacji gdzie bez zamydlonego ekranu nie pogramy w 4K, silniki graficzne też nie rozwijają się w oczekiwanym tempie - unity rozpadło się przez kiepski zarząd, unreal engine 5 to król mikroopóźnień, od zakończenia akceleracji sprzętowej dźwięku w windows vista (okolice 2007) nie było w audio żadnej rewolucji a wręcz ewolucji - id Tech to do dzisiaj jedyny engine który potrafi wyrysować łuk a nie koła z nakładanych trójkątów... Także sygnałów że branża kuleje nigdy nie brakowało - grunt to realizować swoje cele i jak tak jak ja od lat 2000 celujesz w średnią półkę cenową - szukać takich upgrade które faktycznie coś dają no i mieć świadomość że rtx 5090 to będzie 600w potwór z gddr7 i ceną na poziomie 12000 pln, takiej wydajności w kartach do 2000zł nie zobaczymy do 2030r. Pamiętam WOW jakie zrobił na mnie Teoria Chaosu splinter cella (mądrze zaprogramowana gra działająca również na konsolach) Far Cry 1 (był nieziemski na premierę) Crysis wyrywał z butów (8800gtx ledwo dawał radę), wszystko potem to sidegrade z momentami które pokazywały że 200 mln usd budżetu może dać jakościowy tytuł jak Red Dead 2, przez ostatnie 20 lat dobrych gier pctowych nie brakowało ale większość to ciągły sidegrade niepotrzebujący najmocniejszych sprzętów, dobieranie timingów pamięci to zawsze była nieco sztuka dla sztuki
