luke130
kompilacja sterowników karty dźwiękowej
Rrrrrwa MAĆ!!
Że tak zacytuję feldmarszałka Dudę.
Płytka główna Asus M2N-SLI ze zintegrowanym układem dżwiękowym c-media CM6501. Asus dostarcza do karty sterowniki również pod linuksa (a jakże). pliczek się zwie "NFORCE-Linux-x86-1[1].0-0311-pkg1.run"
konsloka, roocik, sh N[TAB] i tak dalej, kompilacja prawie jak w przypadku kart graficznej i później błąd:
nforce-installer log file '/var/log/nvidia-nforce-installer.log'
creation time: Thu Jul 10 13:39:15 2008
option status:
 license pre-accepted	  : false
 expert					: false
 uninstall				 : false
 driver info			   : false
 no precompiled interface  : false
 no ncurses color		  : false
 no questions			  : false
 silent					: false
 Installer install prefix  : /usr
 kernel source path		: (not specified)
 net kernel install path   : (not specified)
 audio kernel install path : (not specified)
 proc mount point		  : /proc
 ui						: (not specified)
 tmpdir					: /root/tmp
Using: nvidia-installer ncurses user interface
-> Found package NVIDIA network driver for Linux-x86
-> Found package NVIDIA audio driver for Linux-x86
-> Please select packages for installation:
  Selections:
  NVIDIA network driver for Linux-x86 (1.0-13)
  NVIDIA audio driver for Linux-x86 (1.0-8)
-> Starting install of NVIDIA network driver for Linux-x86
-> Checking for loaded module nvnet
-> Checking for loaded module forcedeth
-> Trying to remove loaded module forcedeth
-> License accepted.
-> Skipping check for conflicting rpms.
-> /proc/version is Linux version 2.6.24.5-desktop-2mnb
  (qateam@titan.mandriva.com) (gcc version 4.2.3 (4.2.3-6mnb1)) #1 SMP Thu Jun
  12 14:37:30 EDT 2008
-> No precompiled kernel interface was found to match your kernel; this means
  that the installer will need to compile a new kernel interface.
-> Kernel source path: '/lib/modules/2.6.24.5-desktop-2mnb/source'
-> Kernel output path: '/lib/modules/2.6.24.5-desktop-2mnb/build'
-> Performing cc_version_check with CC="cc".
-> running command /bin/grep "^PATCHLEVEL ="
  /lib/modules/2.6.24.5-desktop-2mnb/source/Makefile | /bin/cut -d " " -f 3
-> Kernel module filename is nvnet.ko
  Cleaning kernel module build directory.
  executing: 'cd ./nvnet; make clean'...
  rm -f *.ko *mod.* *.cmd nvenet.o nvenetif.o nvnet.o *~ core
-> Building kernel module:
  executing: 'cd ./nvnet; make module SYSSRC=/lib/modules/2.6.24.5-desktop-2mn
  b/source SYSOUT=/lib/modules/2.6.24.5-desktop-2mnb/build'...
  make -C /lib/modules/2.6.24.5-desktop-2mnb/build \
  	KBUILD_SRC=/usr/src/linux-2.6.24.5-desktop-2mnb \
  	KBUILD_EXTMOD="/root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvnet"
  -f /usr/src/linux-2.6.24.5-desktop-2mnb/Makefile \
  	modules
  test -e include/linux/autoconf.h -a -e include/config/auto.conf || (		\
  	echo;								\
  	echo "  ERROR: Kernel configuration is invalid.";		\
  	echo "		 include/linux/autoconf.h or include/config/auto.conf are mis
  sing.";	\
  	echo "		 Run 'make oldconfig && make prepare' on kernel src to fix it
  	echo;								\
  	/bin/false)
  mkdir -p /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvnet/.tmp_ver
  sions; rm -f /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvnet/.tm
  p_versions/*
  make -f /usr/src/linux-2.6.24.5-desktop-2mnb/scripts/Makefile.build obj=/roo
  /usr/src/linux-2.6.24.5-desktop-2mnb/scripts/Makefile.build:46: *** CFLAGS w
  as changed in "/root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvnet/Ma
  kefile". Fix it to use EXTRA_CFLAGS. Stop.
  make[3]: *** [_module_/root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/n
  vnet] Błąd 2
  make[2]: *** [sub-make] Błąd 2
-> Error.
ERROR: The NVIDIA kernel module was not created.
ERROR: Installation of the network driver has failed.  Please see the file
   '/var/log/nvidia-nforce-installer.log' for details.  You may find
   suggestions on  fixing installation problems in the README available on
   the Linux driver download page at www.nvidia.com.
-> Starting install of NVIDIA audio driver for Linux-x86
-> Checking for loaded module nvsound
-> Checking for loaded module nvaudio
-> Using the kernel source path '/lib/modules/2.6.24.5-desktop-2mnb/source' as
  specified by the '--kernel-source-path' commandline option.
-> Using the kernel output path '/lib/modules/2.6.24.5-desktop-2mnb/build' as
  specified by the '--kernel-output-path' commandline option.
-> Kernel module filename is nvsound.ko
  executing: 'cd ./nvsound/main; make clean'...
  rm -f *.ko *mod.* *.cmd nv*.o *~ core
  executing: 'cd ./nvsound/main; make module SYSSRC=/lib/modules/2.6.24.5-desk
  top-2mnb/source SYSOUT=/lib/modules/2.6.24.5-desktop-2mnb/build'...
  	KBUILD_EXTMOD="/root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvsound
  /main" -f /usr/src/linux-2.6.24.5-desktop-2mnb/Makefile \
  	modules
  	echo;								\
  sing.";	\
  	echo;								\
  	/bin/false)
  mkdir -p /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvsound/main/.
  tmp_versions; rm -f /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nv
  sound/main/.tmp_versions/*
 cc -Wp,-MD,/root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvsound/ma
  in/.nvalinux.o.d  -nostdinc -isystem /usr/lib/gcc/i586-manbo-linux-gnu/4.2.3
  /include -D__KERNEL__ -Iinclude -Iinclude2 -I/usr/src/linux-2.6.24.5-desktop
  -2mnb/include -include include/linux/autoconf.h  -I/root/tmp/selfgz15444/NFO
  RCE-Linux-x86-1.0-0311-pkg1/nvsound/main -Wall -Wundef -Wstrict-prototypes -
  Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-dec
  laration -O2 -pipe -msoft-float -mregparm=3 -freg-struct-return -mpreferred-
  stack-boundary=2 -march=i686 -ffreestanding -maccumulate-outgoing-args -DCON
  FIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -I/usr/src/linux-2.6.24.5-deskto
  p-2mnb/include/asm-x86/mach-default -Iinclude/asm-x86/mach-default -fno-omit
  -frame-pointer -fno-optimize-sibling-calls -fno-stack-protector -Wdeclaratio
  n-after-statement -Wno-pointer-sign  -I/root/tmp/selfgz15444/NFORCE-Linux-x8
  6-1.0-0311-pkg1/nvsound/main -Wall -Wimplicit -Wreturn-type -Wswitch -Wforma
  t -Wchar-subscripts -Wparentheses -Wpointer-arith -Wno-multichar -Werror -O
  -MD -Wno-cast-qual -Wno-error -DNV_CHANGE_PAGE_ATTR_PRESENT -DMODULE -D"KBUI
  LD_STR
  (s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nvalinux)"  -D"KBUILD_MODNAME=KBUILD_S
  TR(nvsound)" -c -o /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvso
  und/main/nvalinux.o /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvs
  ound/main/nvalinux.c
  In file included from include/linux/list.h:8,
				from include/linux/module.h:9,
				from /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/n
  vsound/main/nvalinux.c:19:
  include/linux/prefetch.h: In function ?prefetch_range?:
  include/linux/prefetch.h:57: warning: pointer of type ?void *? used in a
  rithmetic
  In file included from include/asm/dma-mapping_32.h:5,
				from include/asm/dma-mapping.h:2,
				from include/linux/dma-mapping.h:52,
				from include/asm-generic/pci-dma-compat.h:7,
				from include/asm/pci.h:88,
				from include/linux/pci.h:796,
  vsound/main/nvalinux.c:29:
  include/linux/scatterlist.h: In function ?sg_virt?:
  include/linux/scatterlist.h:293: warning: pointer of type ?void *? used
  in arithmetic
  In file included from /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/n
  vsound/main/nvalinux.c:49:
  /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvsound/main/nvalinux.h
  : At top level:
  :46: error: conflicting types for ?uintptr_t?
  include/linux/types.h:40: error: previous declaration of ?uintptr_t? was
  here
  /root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvsound/main/nvalinux.c
  : In function ?AosFpuSave?:
  :181: error: ?struct task_struct? has no member named ?thread_info?
  :191: error: ?struct task_struct? has no member named ?thread_info?
  :214: error: ?struct task_struct? has no member named ?thread_info?
  : In function ?AosFpuRestore?:
  :234: error: ?struct task_struct? has no member named ?thread_info?
  :235: error: ?struct task_struct? has no member named ?thread_info?
  make[4]: *** [/root/tmp/selfgz15444/NFORCE-Linux-x86-1.0-0311-pkg1/nvsound/m
  ain/nvalinux.o] Błąd 1
  vsound/main] Błąd 2
-> Error.
ERROR: Installation of the audio driver has failed.  Please see the file
ktoś ma jakiegoś pomysła co może być nie halo?
PS. źródełka są. pare dni temu płodziłem drivera do grafy nvidii i działało.
w katalogu ze zrodlami kernela:
make oldconfig
make prepare
i zobacz czy cos sie zmieni
make oldconfig
make prepare
to samo czyli nic.
