Nimothan
Problem z mikrofonem.
Zainstalowałem grę i mikrofon kupiłem(nowy). I wszystko ładnie chodziło aż sie popsuło:(
po włączeniu gry pisze mi coś takiego w konsoli:
maxplayers set to 32
Heap: 256.00 Mb
Parsed 359 text messages
Couldn't find custom font file 'resource/HL2EP2.ttf'
Couldn't find custom font file 'materials/vgui/fonts/buttons_32.vbf'
execing config.cfg
Can't use cheat cvar cam_command in multiplayer, unless the server has sv_cheats set to 1.
Unknown command "joy_wingmanwarrier_centerhack"
Unknown command "joy_wingmanwarrier_turnhack"
Can't use cheat cvar cl_upspeed in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cl_forwardspeed in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cl_backspeed in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar dsp_dist_max in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar dsp_dist_min in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar r_aspectratio in multiplayer, unless the server has sv_cheats set to 1.
Unknown command "cl_cmdbackup"
1 CPU, Frequency: 1.8 Ghz, Features: AuthenticAMD SSE SSE2 MMX 3DNow RDTSC CMOV FCMOV
execing valve.rc
execing autoexec.cfg
execing userconfig.cfg
Can't use cheat cvar developer in multiplayer, unless the server has sv_cheats set to 1.
Resize parent (panel(Cancel) -> parent(OptionsSubMultiplayer)) not sized yet!!!
Resize parent (panel(listpanel_keybindlist) -> parent()) not sized yet!!!
Resize parent (panel(ReverseMouse) -> parent()) not sized yet!!!
Resize parent (panel(SFXSlider) -> parent()) not sized yet!!!
Resize parent (panel(GammaButton) -> parent()) not sized yet!!!
Resize parent (panel(MicMeter) -> parent()) not sized yet!!!
co to jest - wcześniej tego nie miałem ?
Problem z mikrofonem polega na tym że w windowsie wszędzie go widzi i głośnośc jest ok(nagrywa dźwięk) a w Counter Strike Source nie słychac mnie jak wciskam klawisz K i chce mówić do ludzi.
Nie wiem co jest grane reinstalacja gry nie pomogła :( w sieci nie znalażłem rozwiązania nigdzie moze wywiecie jak naprawić ten błąd?
Bardzo proszę o pomoc albo tu albo na gg 6930810
PPM - > Właściwości -> Zakładka Pliki Lokalne -> Sprawdź integralność cache gry.
no ale w co mam kliknąć Prawym przyciskiem myszy ?? bo jak w pulpit to nie mam zadnej zakładki pliki lokalne za bardzo nie wiem gdzie mam kliknąć ? mozesz dokładniej ??
