Nataq
Emulator Xbox 360 gamepad
Mam odrobinę denerwujący problem z moim świeżo zakupionym Logitechem Chillstream PS3. Wiedziałem, że będę musiał użyć emulatora, żeby pograć z FIFĘ 12. Niestety po wrzuceniu xinputa nie wszystko poszło tak jak powinno...
Lewy grzybek jest zamieniony miejscami z D-padem. Skutkuje to tym, że zamiast 360 stopni na gałce mam 4 kierunki... Czy edytując xbox360cemu da radę zamienić to w taki sposób, aby działało jak pan Bóg przykazał?
[PAD1]
Index=0				#controller index in game controllers list; 0 is first; -1 to ignore this pad
Left Analog X=1			#axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Left Analog Y=-2		#axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Right Analog X=3		#axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Right Analog Y=-6		#axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Left Analog X Linear=0		#-100 to +100  raise this number to increase sensitivity near center
Left Analog Y Linear=0		#-100 to +100  raise this number to increase sensitivity near center
Right Analog X Linear=0		#-100 to +100  raise this number to increase sensitivity near center
Right Analog Y Linear=0		#-100 to +100  raise this number to increase sensitivity near center
Left Analog X+ Button=0		#button id; 0 to disable
Left Analog X- Button=0		#button id; 0 to disable
Left Analog Y+ Button=0		#button id; 0 to disable
Left Analog Y- Button=0		#button id; 0 to disable
Right Analog X+ Button=0	#button id; 0 to disable
Right Analog X- Button=0	#button id; 0 to disable
Right Analog Y+ Button=0	#button id; 0 to disable
Right Analog Y- Button=0	#button id; 0 to disable
D-pad POV=1			#POV index; 0 to disable
D-pad Up=0			#button id; 0 to disable
D-pad Down=0			#button id; 0 to disable
D-pad Left=0			#button id; 0 to disable
D-pad Right=0			#button id; 0 to disable
A=2				#button id; 0 to disable
B=3				#button id; 0 to disable
X=1				#button id; 0 to disable
Y=4				#button id; 0 to disable
Left Shoulder=5			#button id; 0 to disable
Right Shoulder=6		#button id; 0 to disable
Back=9				#button id; 0 to disable
Start=10			#button id; 0 to disable
Left Thumb=11			#button id; 0 to disable
Right Thumb=12			#button id; 0 to disable
Left Trigger=7			#button id; precede with 'a' for an axis; eg; a-6; for a slider precede with 's' eg; s-1
Right Trigger=8			#button id; precede with 'a' for an axis; eg; a-6; for a slider precede with 's' eg; s-1
UseForceFeedback=0		#use 0 to 1; default 0
ForceLargeGain=10000		#use 0 to 10000; default 10000; effect intensity
ForceLargePeriod=120000		#use 0 to 200000; default 120000; effect frequency;
Witam!!
Posiadam pada hama black force, XBOX360 Controller Emulator v3.0 mi nie działa poprawnie, gry nie chcą się uruchamiać i przy uruchamianiu XInputTest pojawia się błąd. VIBMOD 3.1.0.4 działa poprawnie ale nie działają 2 triggery, wie ktoś może co trzeba zmienić w x360ce.ini aby one zaczęły działać?
Witajcie mam pytanie co do pada SPEED-LINK SL-6555-SBK. korzystam z emulatora Xbox360 i bez problemu udało mi się przypisać wszystkie klawisze zawet LT i RT działają prawidłowo jednak mam problem z grą Resident Evil 5. Otóż niektóre momenty w grze wymagaja aby wcisnąć naraz LT i RT i tu pojawia się problem gdyż Triggery znajdują się na jednej osi i wciśnienie obu naraz wywołuje brak reakcji (coś jak by jeden znosił drugi). czy jest możliwość ustawienia tego w pliku xbox360cemu, aby oba Triggery można było wcisnąć naraz?
oto mój plik xbox360cemu:
[Options]
UseAutoPad=0 #use 0 to 1; automatically make other PAD to PAD1 after detecting movement
UseInitBeep=1 #use 0 to 1; default 1; beep on init
#Logitech Cordless Rumblepad 2 / Generic Rumble Controller
[PAD1]
Right Analog X=6 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Right Analog Y=-3 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
A=1 #button id; 0 to disable
B=2 #button id; 0 to disable
X=3 #button id; 0 to disable
Back=7 #button id; 0 to disable
Start=8 #button id; 0 to disable
Left Thumb=9 #button id; 0 to disable
Right Thumb=10 #button id; 0 to disable
Left Trigger=k1 #button id; precede with 'a' for an axis; eg; a-6; for a slider precede with 's' eg; s-1
Right Trigger=k1 #button id; precede with 'a' for an axis; eg; a-6; for a slider precede with 's' eg; s-1
ForceLargePeriod=120000 #use 0 to 200000; default 120000; effect frequency; wheel only
ForceLargeFadeTime=10 #use 0 to 100; default 10
ForceLargeFadeIn=0 #use 0 to 1; default 1
ForceLargeFadeOut=0 #use 0 to 1; default 1
ForceLargeStartMag=0 #use 0 to 10000; default 2000; effect will begin with this value
ForceSmallGain=10000 #use 0 to 10000; default 10000; effect intensity
ForceSmallPeriod=30000 #use 0 to 200000; default 30000; effect frequency; wheel only
ForceSmallFadeTime=10 #use 0 to 100 default 10
ForceSmallFadeIn=0 #use 0 to 1; default 1
ForceSmallFadeOut=0 #use 0 to 1; default 1
ForceSmallStartMag=0 #use 0 to 10000; default 2000; effect will begin with this value
WheelInertiaGain=2500 #use 0 to 10000; default 2500; effect intensity; wheel only
WheelSpringGain=5000 #use 0 to 10000; default 5000; effect intensity; wheel only
SteeringWheel=0 #use 0 to 1; enable for all wheel effects
#Logitech G25 Racing Wheel / Generic Wheel
[PAD2]
Index=-1 #controller index in game controllers list; 0 is first; -1 to ignore this pad
Left Analog Y=7 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Right Analog X=7 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Right Analog Y=7 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Left Analog X Linear=30 #-100 to +100 raise this number to increase sensitivity near center
A=18 #button id; 0 to disable
B=19 #button id; 0 to disable
X=17 #button id; 0 to disable
Y=16 #button id; 0 to disable
Left Shoulder=6 #button id; 0 to disable
Right Shoulder=5 #button id; 0 to disable
Back=8 #button id; 0 to disable
Start=7 #button id; 0 to disable
Left Thumb=3 #button id; 0 to disable
Right Thumb=4 #button id; 0 to disable
Left Trigger=a-6 #button id; precede with 'a' for an axis; eg; a-6; precede with 's' for a slider eg; s-1
Right Trigger=a-2 #button id; precede with 'a' for an axis; eg; a-6; precede with 's' for a slider eg; s-1
UseForceFeedback=1 #use 0 to 1; default 0
ForceLargeGain=8000 #use 0 to 10000; default 10000; effect intensity
ForceLargeFadeOut=1 #use 0 to 1; default 1
ForceLargeStartMag=1000 #use 0 to 10000; default 2000; effect will begin with this value and end with 10000
ForceSmallGain=8000 #use 0 to 10000; default 10000; effect intensity
ForceSmallFadeTime=10 #use 0 to 100; default 10
ForceSmallFadeOut=1 #use 0 to 1; default 1
ForceSmallStartMag=1000 #use 0 to 10000; default 2000; effect will begin with this value and end with 10000
SteeringWheel=1 #use 0 to 1; enable for all wheel effects
Witam mam problem chodzi o to że mam pada SPEED-LINK SL-6555-SBK i mam 2 problemy po pierwsze w resident evil 5 nie mogę nacisnąć jednocześnie left trigger i right trigger a po drugie w gta 4 nie mam władzy nad przyciskami left trigger i right trigger a dokładniej chodzi o to że on się same wciskają i cały czas strzelam w gta 4 . Nie wiem o co chodzi . A tu konfiguracja mojego emulatora .
[Options]
[PAD1]
Aha i dodam jeszcze że w XInputTest.exe nie wciskają się cały czas te przyciski ale w grze już tak.
Ja tam wole MotioninJoy do DS3. Wszystko działa poprawnie w PES, gałki itp. Wibracje też są, jeśli gra obsługuje. Emulator xboxowego też jest :P
Witam mam pewien problem z grą Prototype 2. Mam pada Apollo gp-3100 steel force i gdy skopiowałem ten emulator do folderu z grą to pad zaczoł działać ale prawy drążek wariował prawo to góra lewo to dół a góra to prawo, dół to lewo i to naprawiłem zmieniając z:
Na:
Right Analog X=-3 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Right Analog Y=6 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable
Teraz wszystko jest ok poza jednym , Gdy używam lewego drążka on automatycznie biegnie sprintem a ja nic nie trzymam nic oprócz analoga
Tak zmieniłem i jest już dobrze zostawiam wszystkim którzy mają ten sam problem
[Options]
Log=0 #use 0 to 1; creates a log file in folder 'x360ce logs'
UseAutoReInit=0 #use 0 to 1; default 0; Reinit if Rumble fails (DIERR_NOTEXCLUSIVEACQUIRED) use only for game like Need For Speed SHIFT
#Generic Rumble Controller
[PAD1]
Index=0 #controller index in system game controllers list; 0 is first; -1 to ignore this pad
Failsafe=0 #failsafe mode (DISCL_BACKGROUND) use only for games like Bionic Commando
A=3 #button id; 0 to disable
TriggerDeadzone=150 #use 0 to 256; default 0; add deadzone to trigger
Left Trigger=7 #button id; precede with 'a' for an axis; 's' for a slider;
Right Trigger=8 #button id; precede with 'a' for an axis; 's' for a slider;
SwapMotor=0 #use 0 to 1; default 0
ForcePercent=100 #use 0 to 100; default 100
#all other options currently has no effect
O jeszcze 1 mam problem z grą Mirror's edge ,otóż góra to lewo a prawo to dół itd a i lewy drążek działa inaczej bo jak chce do przodu to ide do tyłu. Sam bym sobie metodą prób i błędów poradził ale Emulator nie działa. Pad działa nawet i bez emulatora ale nie wiem jak mam ustawienia zmienić.Prosze o porade ;))
posiadam pada Speedlink xeox. Ściągnąłem do niego x360ce samo mi go wykryło i we wszystkich grach działa aż miło. :)
Jednak nie wiem jak zrobić aby lewy trigger był cyfrowy a prawy pozostał analogowy. Z góry dzięki. Pozdrawiam.
ProductName=SL-6555-SBK
InstanceGuid=739c8550-ec72-11e1-8001-444553540000
AxisToDPadDeadZone=256
AxisToDPadOffset=0
A=1
B=2
Back=7
Start=8
X=3
Y=4
D-pad POV=1
D-pad Down=DOWN
D-pad Left=LEFT
D-pad Right=RIGHT
D-pad Up=UP
UseForceFeedback=1
ForcePercent=100
SwapMotor=0
FFBType=1
ControllerType=1
LeftMotorPeriod=60
Left Shoulder=5
Left Analog X AntiDeadZone=0
Left Analog Y AntiDeadZone=0
Left Analog X=1
Left Analog Y=-2
Left Thumb=9
Left Analog X DeadZone=3277
Left Analog Y DeadZone=3277
Left Trigger=h-1
TriggerDeadzone=0
PassThrough=0
RightMotorPeriod=120
Right Shoulder=6
Right Analog X AntiDeadZone=0
Right Analog Y AntiDeadZone=0
Right Analog X=6
Right Analog Y=-3
Right Thumb=10
Right Analog X DeadZone=3277
Right Analog Y DeadZone=3277
Right Trigger=h1
RightTriggerDeadZone=0
ProductGuid=08021a34-0000-0000-0000-504944564944
AxisToDPad=0
witam, Panowie potrzebuję pomocy, otóż kupiłem pad do pc-shark sh814 i chciałbym pograć nim w London 2012.
mam emulator - jak srawdzam pada na testerze to wszystko jest ok. Skopiowałem pliki do folderu gry ale pad w grze nie odpowiada, tzn. mogę wejść do gry tylko z poziomu klawiatury. Proszę o wskazówki.
Na pewno nie kupujemy padów firm Manta, Dragonplus, Warez, Esperanza,E5 i wszelkich innych do 30zł a szczególnie kopii dualshocków czy logitechów.
za dużo mi nie pomogłeś. Skoro firmy sprzedają takie urządzenia to dlaczego mają nie działać?
Próbowałem drugim sposobem skopiować pliki z emulatora do "system32" ale system wyświetla że nie mam uprawnień-mimo że jestem administratorem(nie wiem co jest nie tak)
Pad nie działa? Z tego co wyczytałem to twój pad działa tylko emulator go nie widzi i raczej nie będzie widział.
Spróbuj jeszcze ściągnąć x360ce stąd: http://code.google.com/p/x360ce/ i włącz w programiku automatyczne wykrywanie pada przy pomocy internetu.
Ale emulator go widzi-nawet jest przecież w nim tester który sprawdza przyciski i u mnie wszystko jest ok. Jedynie w grze nie mogę go używać, a po to go kupiłem.
Czy za pomocą tego emulatora moge zagrac na padzie od ps2 podlaczonym przez przejsciowke na usb w gre mx vs atv reflex konwertowaną z x360 ? moj problem polega na tym, że prawy analog widziany jest przesuniety o 45stopni i np. wciskajac w prawo reaguje górą R1 zamienilo się miejscem z R2 i to samo jest na L-kach... itd.
@up
Ponawiam pytanie, tylko o fife 13 i nfsy Hp i Mw2012. Bedzie z nimi oryginalny dualshock2 kompatybilny przez emu?
@Mietekkk
Zamień miejscami wartości które masz przy opcjach
Right Analog X=
Right Analog Y=
np jak masz u siebie
Right Analog X=6
Right Analog Y=-3
to zamień na
Right Analog X=-3
Right Analog Y=6
jeżeli wystąpią problemy z odwrotnością osi to usuń lub dodaj "-" w zależności od potrzeby
To samo zrób dla R1 (Right Thumb) i R2 (Right Trigger)
@Virtuoso
No po tylu latach od pojawienia się tego pada powinny współdziałać. Ale najlepiej jak odwiedzisz fora tych gier lub wpiszesz w google nazwę pada i nazwę gry
Witam serdecznie - kto mi pomoże w tym wątku (przelewam od ręki pieniądze na duże piwo), mianowicie :
Posiadam 2 pady - jeden oryginalny od Xboxa z microsoftu, drugi esperanza eg102 za pare zł ....
Otóż problem - wrzucając pliki z emulatorem od pada xboxowego do gier, chodzi tylko ten pad za pare zł (tj esperanza) a oryginalny pad nie działa w ogóle, wyrzucając zaś pliki z emulatorem pada od xboxa - chodzi poprawnie tylko oryginalny pad na fabrycznej konfiguracji a esperanza ma wszystko pomieszane.
Pytanie "Co zrobić by móc grać na obu padach z ustawieniami pada od xboxa 360"
Obiecane piwo czeka dla pomocnika.
@up
Z tego co wiem, to nie ma takiej możliwości, przynajmniej u mnie.
Tak samo nie działają 2 takie same pady od xboxa.
@up
Nie załamuj mnie. Byłem święcie przekonany że dwa pady od x'a będą chodziły. Czyli pozostaje logitech f710 + pad z microsoftu, innej opcji niema, a czy te oba pady aby będą współpracowały razem ??
Kurde musi być jakieś obejście tego .........
I tu też cię załamię. F710, przynajmniej u mnie jest wykrywany jako pad od xboxa
Moim zdaniem (nie mam na czym sprawdzić) teoretycznie jest możliwość współpracy obu padów. Trzeba po prostu zrobić 2 osobne profile dla każdego z nich. Sprawdź czy w graficznym panelu emulatora nie masz opcji przełączenia się na drugi pad. Jeżeli jest przełącz się na ten xboxowy i kombinuj z konfiguracją tak aby zadziałał. Już w poprzednich wersjach można było umieścić kilka profili dla kilku różnych padów więc i tutaj powinno się to dać zrobić.
Druga możliwość to wywalenie emulatora i próba ręcznego skonfigurowania wszystkich przycisków w samej grze dla tej esperanzy. Skoro wszystko jest tylko pomieszane może da się to po prostu poustawiać na miejsce.
Trzecia możliwość to wyłączenie w grze obsługi któregoś z padów i jeżeli to możliwe włączenie na to miejsce klawiatury. Wtedy możesz użyć np. Xpaddera i przypisać przyciskom wyłączonego pada klawisze z klawiatury i myszki. Nie jest to zbyt wygodne ale przynajmniej jakoś to będzie chodzić. Wszystko zależy od samej gry i jej specyfiki sterowania.
AD2
Do standardowego odbiornika można podłączyć max 4 pady naraz więc nie powinno być problemów z ich wykrywaniem 2 padów .
AD3
710 ma dwa tryby , w jednym z nich jest wykrywany jako xboxowy w drugim jako dinput.
Dobrze prawisz, z tym, ze dinput nie zawsze dziala z nowszymi grami
Virtuoso musi się to jakoś dać obejść... w sumie to logitech jak i microsoft działa na tym samym xinpucie w nowszych gierach i tu może być właśnie hak :/..., mimo wszystko nie ma rzeczy niemożliwych.
doman18 - Już ci chciałem przelewać pieniądze na browara, gdyby nie to że siedze już 3h na emulatorze i nic nie umię wykombinować bo jest zdecydowanie za dużo kombinacji... a jest to do zrealizowania na 100%, problem w tym że wszystko jest pomieszane jakbyś wrzucił do miksera i włączył 3 bieg. A więc tak : Są profile w emulatorze. Pad 1 jest skonfigurowany idealnie, tj esperanza. Pad 2 widzi jako pada od xboxa tego oryginalnego. Pozostały 2 gałki do skonfigurowania (Stick Axis) i dwa klawisze na palec wskazujący (Tigger), z tym jest poprostu masakra ...................
Pad 1 - esperanza, działa poprawnie, skonfigurowany w 100%
Pad 2 - Microsoft (pozostają chore gałki analogowe i Tigery)
http://www.fotosik.pl/pokaz_obrazek/48815b08159fd4bf.html
http://www.fotosik.pl/pokaz_obrazek/390e490d1d9733ee.html
Plik konfiguracyjny :
http://www.sendspace.pl/file/48588db0139d114561befa0
http://www.fotosik.pl/pokaz_obrazek/f22bae3736bd1a7c.html ---> To trzeba skonfigurować, nawet wciśnięte gałki działają poprawnie jako Stick button ...
Napewno się znajdzie jakiś szpec ...... Duży browar nadal aktualny.
A spróbój podlaczyc esperanze przez emulator, a F710 w trybie dinput. Esperanze ustaw normalnie, a F710 zmien na xinput juz w grze, np w fifie podczas wyboru stron.
Wieczorem postaram się znaleźć swojego pada co łatwe nie będzie bo mieszkam trochę na walizkach (remont). Przełączę się na windowsa, sprawdzę co tam w tym nowym emulatorze porobili i spróbuję skonfigurować. Ty za ten czas możesz spróbować załadować predefiniowane ustawienia. Nie wiem jak jest w tym emu ale w dołączonym do XBCD w oknie które pokazałeś na ostatnim screenie jest rozwijalna lista (obok przycisków LOAD, RESET, SAVE). Zobacz czy są tam jakieś profile. Powinny być dwa dla kontrolera xboxowego, jeden ze spustami jako przyciski, a drugi normalny z osiami w spustach.
Jest jeszcze sposób ze sterownikami XBCD żeby po prostu przełączyć pada w tryb dinput i później ustawić go identycznie jak pada esperanzy. Wtedy emulator oba pady by rozpoznał jako jednakowe. Ale to ostateczność, najpierw spróbuj pobawić się profilami.
Virtuoso, ja nie posiadam F710, tylko xbox360 od microsoftu. W zasadzie to jeszcze posiadam F710, jakbyś chciał na części :Phttp://allegro.pl/bezprzewodowy-logitech-f710-na-czesci-bcm-i2897730840.html
doman18
Jest taka lista ...
http://www.fotosik.pl/pokaz_obrazek/2f7c1d2ae279aec1.html
http://www.fotosik.pl/pokaz_obrazek/7146f421aa468933.html
Dla ułatwienia łap cały emulator :
http://www.sendspace.pl/file/92ca78df4869e23477455cf
