VG1
System Volume Information?
Jak dostac sie do zawartosci tego katalogu? Gdzie to się ustawia?
Windows XP Professional Using the NTFS File System on a Domain
In Windows Explorer click [Tools] [Folder Options]
Click the [View] tab, click [show Hidden Files and Folders]
Clear [Hide protected operating system files (Recommended)] check box.
Click [Yes] on the change confirmation box and click [OK] to exit.
Right-click the System Volume Information folder in the root folder.
Click [Properties] and select the [security] tab. Click [Add]
Enter the name of the user you are allowing access to the folder and select the account location.
Click [OK], and then click [OK].
Double-click the System Volume Information folder to open.
Using CACLS with Windows XP Home Edition Using the NTFS File System
In Windows XP Home Edition with the NTFS file system, it's necessary to take a different approach since Simple File Sharing does not allow modifying the Access Control Lists (ACL's). The result is the same, but you use the Cacls command-line tool to modify file or folder access control lists (ACL's).
Click [start] [Run] type cmd and click [OK].
Navigate to the root folder of the partition where the System Volume Information folder you want to access is located.
Type cacls ":System Volume Information" /E /G :F and press ENTER
Note: In this instance, make sure you type the quotation marks as shown in the line above.
To remove permissions, type cacls ":System Volume Information" /E /R at the command prompt to remove all permissions for the user.
źródło: http://www.theeldergeek.com/system_volume_...ion_folder1.htm
