skwiatek
ECS K7S5A
Elo
Na sprzedaż mam w/w płytę...
CPU
Socket 462 for AMD Athlon™ XP/ Athlon™/ Duron™ processor
FSB 266/200 MHz
CHIPSET
SiS® 735 single chip
North Bridge & South Bridge:SiS® 735
MEMORY
2 x 184-pin DDR DIMM socket , support DDR266/200 DDR SDRAM
2 x 168-pin SDRAM DIMM socket support PC133/100 3.3V SDRAM
Maximum: 1GB
EXPANSION SLOT
1 x AGP 4X slot
5 x PCI slots
1 x AMR slot
STORAGE
Support by SiS® 735
4 x Ultra DMA100/66 devices
AUDIO
C-Media CMI9738 4-channel audio CODEC
Compliant with AC'97 2.2 specification
LAN
SiS900 10/100 Mbps Fast Ethernet Controller
REAR PANEL I/O
1 x PS/2 keyboard & PS/2 mouse connectors
2 x USB 1.1 ports
1 x RJ45 LAN connector
1 x Parallel port (LPT)
1 x Serial port (COM1)
1 x Game port
1 x Audio port (Line-in, Line-out, Mic-in)
INTERNAL I/O CONNECTORS & HEADERS
1 x 20-pin ATX Power Supply Connector
1 x FDD connector supports two 360K~2.88MB FDDs
2 x IDE connectors
1 x IrDA for SIR header
1 x Speaker header
1 x USB 1.1 header support additional 2 USB ports
1 x Front panel switch/LED header
1 x Front panel audio header
CD in1/CD in2 header
CPUFAN/SYSFAN connectors
WOL connector
SYSTEM BIOS
Award BIOS with 2Mb Flash ROM
Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
Supports ACPI revision 1.0 specification
FORM FACTOR
ATX Size, 305mm*244mm
Sprawna, tylko do dźwięku sterowniki ciężko znaleźć.... A;e daje raade ;]
Sprzedam za doładowanie do Plusa za 30zł ;]
