stugal
Vista homre premium x64, wiesza sie
Witam od pewnego czasu mam dziwny problem kiedys juz go tu opisywalem w tym temacie http://forum.pclab.pl/t467529.html, od tamtego momentu wszystko bylo ok zadnych zwisow az do wczoraj znowu sie zaczelo, poczatkow raz dziennie teraz czesciej nie mam zielonego pojecia co to jest i jak temu zaradzic podczas jednego zwisu system stworzyl plik minidump, przeczytalem tutaj na forum poradnik jak go otworzyc i odczytac natomiast wyskakuje jakis problem podczas odczytu pliku, cos takiego
Microsoft ? Windows Debugger Version 6.11.0001.404 X86
Copyright ? Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\Mini061109-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Machine Name:
Kernel base = 0xfffff800`01a0c000 PsLoadedModuleList = 0xfffff800`01bd1db0
Debug session time: Thu Jun 11 01:00:08.993 2009 (GMT+2)
System Uptime: 0 days 16:37:25.961
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1E, {ffffffffc0000005, fffff80001ab4d8a, 0, ffffffffffffffff}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+a8d8a )
Followup: MachineOwner
bardzo prosze o jakies rady i pomoc
jeszcze zauwazylem jedna rzecz bo znowu musialem resetowac, po kazdym resecie kasuja sie ustawienia niektorych programow np gg, musze na nowo tworzyc profil badz zmieniac inne ustawienia nie wiem cyz to ma znaczenie...
chyba coś ze sprzętu zdycha. ramy, pisałeś wcześniej, przechodzą testy.
ale teraz tak: otwórz kompa i sprawdź dwie rzeczy - kondensatory na karcie graficznej i kondensatory na płycie głównej w sąsiedztwie procesora - dotykasz paluchem od góry. jak są któreś wypukłe to sprzęt się wysypał
EDIT - a i pisałeś że znikają ci jakies konfigi to może dysk ???
No witam mam podobny problem tez mam zawiechy tyle ze ja wiem co je powoduje a mianowicie programy p2p i nie bradzo moge sobie z tym poradzic. tzn. tak wnioskuje ze to one zawieszaja mi system a co do znikajacych ustawien po resecie mam to samo gg sie wysypuje ustawienia np. w dodaj usun programy po kazdym resecie inaczej wyswietla ikony i tez nie mam pojecia dlaczego tak sie dzieje:(
