Barton
ATI Catalyst 4.11
:exclam: Już są :exclam:
Fixed in this driver:
Breed: Playing the game with the display device set to 1024x768 32bpp and AA set to 6x along with AF set to 8x and texture preference set to high performance no longer results in the game failing to respond
HALO: Attempting to launch the game under Windows XP with an ATI RADEON X800 PCI-E series installed no longer results in the game failing to load.
Joint Operation Typhoon Rising: An error message is no longer displayed when exiting the game under Windows XP with an ATI RADEON™ X700 installed. This issue occurs when the game option for Quality Performance is set to 1600x1200.
Postal 2: The staircase now displays spots of red instead of becoming entirely red when a protester is killed using a machine gun
Roller Coaster Tycoon 3: Playing the game under Windows XP with an ATI RADEON™ 7500 series installed no longer results in the building looking bright and appearing to flash
Serious Sam: Playing the game under Windows XP with either an ATI RADEON™ 9000, 9200, or 9250 installed no longer results in Truform not being applied to OpenGL models
Star Wars: Knights of the Old Republic. The Windows XP operating system no longer randomly fails to respond when loading multiple levels
Will Rock: Display corruption and missing textures are no longer noticed in the game
CATALYST 4.11 includes a memory allocation bug fix for all AGP RADEON™ products with 256 of MB of memory that significantly improves performance for applications that make intensive us of graphics memory
Importing files that have been captured using Pinnacle Media Center into Windows Movie Maker 2 no longer results in the Windows XP operating system failing to respond when an ATI RADEON™ X300 or X600 is installed
Display corruption is no longer seen when preview the 3D Pipes screen saver when the display device is set to 2048x1536 16bpp
Using Windows Movie Maker 2 under Windows XP with an ATI RADEON™ X300 or X600 installed no longer results in corrupt colors being displayed in the preview window
CATALYST™ CONTROL CENTER: The profile manager is now functioning properly when attempting to launch games such as Doom 3 and Quake 3
CATALYST™ CONTROL CENTER: Using the option "Restore factory defaults" no longer modifies the previously saved Custom view
CATALYST™ CONTROL CENTER: Changing the position of the gamma slider for display adapter 1 no longer changes the position of the gamma slider for display adapter 2
EDIT: Zapomniałem o jednym szczególe. Zapraszam na srtonę ATI :P
[Edytowane: 13.11.2004 przez Barton]
Dajcie spokój. Naprawdę jest ktoś na tyle sktuknięty żeby co miesiąc instalować nowe stery :E
Takich osob sa cale tony:) Ale biorac pod uwage jak dupne sa sterowniki od ATi nie dziwie sie tym ludziom :)
Jakby co, to mogę dorzucić jeszcze 4.12 Beta :E
a podaj co jest dupne
A ja mam takie pytanko - ile dają takie nowe stery ?? Jak narazie jadę na 4.8 :P i nie wiem co mi da zmiana (chociaż nowe gry zaczynają mi trochę scinać (ale to jest tez trochę wina dojechanej już mocno windy) Mam też pytanie - jaki macie najlepszy według was sposób na instalację Catalist ???
a do 9200 sie nada? bo ja mam jakies dziwne stery, chyba 04.4 pisze jesli dobrze sprawdzam. Gdzie to pisze tak dokladnie?
Jak nie wiesz co da ci zamiana to nie instaluj...
A to sa jakies? (sposoby, nie catalisty)
Chodzi mi o to jak je instalować ?? Czy nainstalować na poprzednie czy Driver Cleaner'em usunąć stare i potem instalować ?? Po prostu - jak instalować jak juz się ma poprzednią ver. - teraz juz wiesz Gospodarz'u ?? :P
To autor tego driver cleaner'a napisal ten program sobie tak dla jajec?
No raczej nie - czyli tak - odinstalować Catalisty w Dodaj/Usuń Programy, potem Driver Celaner'em resztki plików i instalować Catalisty 4.11 - tak ?? :>
A co niemasz czasami ochoty napisać czegoś dla jajec bo czasu masz za dużo :E
A jak "myslisz"?
A jak "myslisz"?
A jak "nie" myślę ?? :P
To masz taki problem jak przypuszczalem.
