bartbaszt
[FAQ] Jak zmienić częstotliwość próbkowania myszki
Skopiowane z: http://www.ngohq.com/news/15043-how-to-inc...-vista-7-a.html
Paczka plików: http://wyslijto.pl/plik/49eugx8ifm
Metoda nie moja, kopiuję ją tutaj bo kilka osób nie mogło tego znaleźć, metodę sprawdzałem, jeśli byłyby problemy z opisem mogę przetłumaczyć, chyba warto by przykleić.
The default 125Hz USB sample rate in Windows Vista and Windows 7 is not enough for today`s gamers and end-users. There are many USB sample rate patches out there, but none of them support Windows Vista and Windows 7, due to a new restricted driver signature enforcement feature. Now it is possible to use these patches - thanks to the latest version of our own Driver Signature Enforcement Overrider (DSEO) and SweetLow. These patches and our tool have been well tested, but I am not taking responsibility for any damages! Use it at your own risk.
The author of HIDUSBF (SweetLow) has released a new beta build of HIDUSBF’s 64-bit adding support for Windows 7 64-bit RC build. Therefore, I`ve updated the HIDUSBF package in this page and included the beta file. If you are using Windows 7 64-bit, make sure to download the updated version of HIDUSBF from the link below, the MD5 is: 403e0a3d0df0bee053fd197f503ada04.
1. Download Driver Signature Enforcement Overrider (attached below as dseo13b.exe).
2. Download HIDUSBF (attached below as hidusbf.zip).
3. Run Driver Signature Enforcement Overrider and choose Enable Test Mode.
4. Extract HIDUSBF to some folder, right click on HIDUSBF.inf and choose Install.
5. Run Setup.exe from HIDUSBF’s folder, check the Filter on Device box and select your desired sample rate.
6. Run Driver Signature Enforcement Overrider again, choose Sign a System file and insert full path to the installed HIDUSBF.sys file (For example: C:\Windows\System32\Drivers\HIDUSBF.sys).
7. Restart your computer and enjoy.
8. Verify by using Mouse Rate or DirectInput Mouse Rate (attached below as mouserate.exe and dimr.exe)
9. If you would like to remove the test mode watermark, run Driver Signature Enforcement Overrider and choose Watermark removal.
That should do the trick. Remember! Use it at your own risk! Don't blame me if your motherboard explodes. But... I already tested it myself - with a lot of success, so you don't have any reason to worry about . If you would like to uninstall it, just right click on HIDUSBFU.inf, choose Install and disable test mode from Driver Signature Enforcement Overrider.
