skwiatek
Sprzedam procka, ram i płyte.
Na sprzedaż mam:
Płyte: MSI 915PL Neo-V
Specyfikacja
CPU
• Supports Intel® Pentium 4 / Celeron D processors in LGA775 package.
• Supports up to Pentium 4 5xx, 6xx(EM64T) and Celeron D 3xx sequence processor.
• Support Intel 04B and 04A processors.
• Supports Intel Hyper-Threading Technology.
• Supports Intel new technology "EIST".
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® 915PL Chipset
- Supports FSB 533/800MHz.
- Supports PCI Express x16 / x1 interface.
- Supports DDR 333/400 memory interface.
• Intel® ICH6 Chipset
- Hi-Speed USB (USB2.0) controller, 480Mb/sec, up to 8 ports.
- 4 Serial ATA ports with transfer rate up to 1.5Gb/s.
- 1 channel Ultra ATA 100 bus Master IDE controller.
- PCI Master v2.3, I/O APIC.
- Supports both ACPI and legacy APM power management.
Main Memory
• Supports two unbuffered DIMM of DDR SDRAM.
• Supports up to 2GB memory size without ECC.
• Supports dual channel DDR333/ DDR400 MHz.
Slots
• One PCI Express x16 slot (supports PCI Express Bus specification v1.0a compliant).
• One PCI Express x1 slots (supports PCI Express Bus specification v1.0a compliant).
• One AGR (Advance Graphics Riser) slot for compatible AGP VGA cards.
• Two 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
The AGR slot is a special design that only supports compatible AGP VGA cards. For more detailed information on compatible AGP VGA cards, please refer here
On-Board IDE / SATA
• One Ultra DMA 66/100 IDE controllers integrated in ICH6.
- Supports PIO, Bus Master operation modes.
- Can connect up to two Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH6.
- Up to 150MB/sec transfer speeds.
- Can connect up to four Serial ATA devices.
Audio
• AC97 link controller integrated in Intel® ICH6 chipset.
• 6-channel audio codec ADI AD1888.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN
• Broadcom BCM4401KFB
- Integrated Fast Ethernet MAC and PHY in one chip.
- Supports 10Mb/s and 100Mb/s.
- Compliance with PCI 2.2.
- Supports ACPI power management.
Internal I/O Connectors
- ATX 24-Pin power connector
- 4-pin ATX 12V power connector
- CD-in connector
- Clear CMOS jumper
- CPU FAN x1 / System FAN x1
- 1 x floppy disk drive connector
- 1 x ATA 100 IDE drive connectors
- 4 x SATA drive connectors
- 2 x USB 2.0 connector support additional 4 ports
- Front panel connector
- Front panel audio connector
MSI Reminds You...
• The floppy disk cable will be optional.
Back Panel I/O Ports
- 1 x Parallel
- 1 x PS/2 Keyboard
- 1 x PS/2 Mouse
- 2 x Serial port
- 1 x Audio I/O (Line-in/Line-out/MIC)
- 4 x USB 2.0
- 1 x RJ45 LAN Jack
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and
expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your
mainboard specifications.
Dimension
• 30.5 cm(L) x 17.5 cm(W) ATX Form Factor
Procek: Celeron 346 3,06Ghz...
RAM: 2x256MB DDR400 jakieś no name'y raczej...
Wszystko ładnie śmiga...
Za całość chciałbym 150zł + kw
Mozliwa mała negocjacja ;)
Oferty na PW
