Sharpa
Log z WinDbg
Witam. Ostatnio podczas grania wyskakują mi bluescreeny. Dzieje sie to tylko podczas grania [Mafia 2, AVP] W innych grach tego nie zaobserwowałem.
Tutaj macie log z odczytem bsoda.
Microsoft ® Windows Debugger Version 6.11.0001.404 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini090210-02.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*f:\symbols\websymbols*http://msdl.microsoft.com/download/symbols.
Executable search path is:
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805634c0
Debug session time: Thu Sep 2 17:33:28.343 2010 (GMT+2)
System Uptime: 0 days 1:08:47.102
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, 80551ae2, b32e99e0, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for aswSP.SYS
*** ERROR: Module load completed but symbols could not be loaded for aswSP.SYS
*** WARNING: Unable to verify timestamp for VIDEOPRT.SYS
*** ERROR: Module load completed but symbols could not be loaded for VIDEOPRT.SYS
*** WARNING: Unable to verify timestamp for nv4_mini.sys
*** ERROR: Module load completed but symbols could not be loaded for nv4_mini.sys
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : aswSP.SYS ( aswSP+8c94 )
Followup: MachineOwner
Chyba widzisz, że przyczyną jest sterownik od Avasta.
Oczywiście należy sprawdzić kilka logów żeby ustalić, czy zawsze przyczyną jest ten sam sterownik.
Jeżeli masz najnowszą wersję Avast 5 to zainstaluj inny program antywirusowy.
