Pulpit
[C] GTK, wyskakujace okienko
Jeżeli mam kod
main.c
#include "funkcje.c"
int main (int argc, char *argv[])
   int i= 0, j = 0, z = 0;
   GtkWidget *kolumny;
   gtk_init(&argc, &argv);
   ZerujTablice();
   window = gtk_window_new(GTK_WINDOW_TOPLEVEL);
   gtk_window_set_title(GTK_WINDOW(window), "Kolko i krzyzyk");
   gtk_window_set_default_size(GTK_WINDOW(window), 150, 150);
   gtk_window_set_position(GTK_WINDOW(window), GTK_WIN_POS_CENTER);
   frame = gtk_fixed_new();
   gtk_container_add(GTK_CONTAINER(window), frame);
   kolumny = gtk_label_new("A");
   gtk_widget_set_size_request(kolumny, 50, 15);
   gtk_fixed_put(GTK_FIXED(frame), kolumny, 020, 0);
   kolumny = gtk_label_new("B");
   gtk_fixed_put(GTK_FIXED(frame), kolumny, 70, 0);
   kolumny = gtk_label_new("C");
   gtk_fixed_put(GTK_FIXED(frame), kolumny, 120, 0);
   kolumny = gtk_label_new("1");
   gtk_widget_set_size_request(kolumny, 20, 50);
   gtk_fixed_put(GTK_FIXED(frame), kolumny, 0, 15);
   kolumny = gtk_label_new("2");
   gtk_fixed_put(GTK_FIXED(frame), kolumny, 0, 65);
   kolumny = gtk_label_new("3");
   gtk_fixed_put(GTK_FIXED(frame), kolumny, 0, 115);
   // Rysowanie pola
   for (i=0;i<F_SIZE*F_SIZE;i++)
	// Namalowanie kwadratow
       field_[i] = gtk_button_new_with_label("");
       gtk_widget_set_size_request(field_[i], 50, 50);
	gtk_fixed_put(GTK_FIXED(frame), field_[i], 20+50*z, 15+50*j);
	// Wypelnienie ich domyslnie...niczym
	field_label[i] = gtk_label_new("");
	gtk_fixed_put(GTK_FIXED(frame), field_label[i], 40+(50*z), 35+(50*j));
	if ((i+1)%3 == 0)
		j++;
	if (z == 2) z = 0;
	else z++;
   gtk_widget_show_all(window);
   g_signal_connect_swapped(G_OBJECT(window), "destroy", G_CALLBACK(gtk_main_quit), NULL);
   // Pobieranie ruchów od gracza
   for(i=0;i<F_SIZE*F_SIZE;i++)
       g_signal_connect(field_[i], "clicked", G_CALLBACK(RysujPole), field_label[i]);
       g_signal_connect(field_[i], "clicked", G_CALLBACK(WykonajRuch), (gpointer) i);
   gtk_main();
   return 0;
funkcje.h
#include <gtk/gtk.h>
#define F_SIZE 3
GtkWidget *field_label[F_SIZE*F_SIZE];
GtkWidget *field_[F_SIZE*F_SIZE];
GtkWidget *frame;
GtkWidget *window;
int pole[F_SIZE*F_SIZE];
int ruchy = 0;
int ruch = 1, poprzedni = 2;
void ZerujTablice();
void WykonajRuch(GtkWidget *widget, gpointer label);
void RysujPole(GtkWidget *widget, gpointer label);
int CzyPoprawny(int id);
int CzyWygral();
void Komunikat();
funkcje.c
#include "funkcje.h"
// Zerowanie tablicy na wszelki wypadek
void ZerujTablice()
   int i = 0;
   for (i = 0;i<F_SIZE*F_SIZE;i++)
       pole[i] = 0;
// Funkcja blokujaca nadpisywanie ruchow
if(pole[id] != 0)
	return 0;
pole[id] = ruch;
return 1;
void Komunikat(GtkWidget *widget, gpointer window)
 GtkWidget *dialog;
 dialog = gtk_message_dialog_new(window,
           GTK_DIALOG_DESTROY_WITH_PARENT,
           GTK_MESSAGE_INFO,
           GTK_BUTTONS_OK,
           "Download Completed", "title");
 gtk_window_set_title(GTK_WINDOW(dialog), "Information");
 gtk_dialog_run(GTK_DIALOG(dialog));
 gtk_widget_destroy(dialog);
// Funkcja wpisujaca ruch do tablicy i uruchamiajaca sprawdzanie wygranej
int id = (int) label;
int wynik = 0;
   printf("Gracz %d wykonuje ruch na pole %d\n", ruch, id);
   if (CzyPoprawny(id) == 1)
       wynik = CzyWygral();
       if (wynik)
           printf("Stan: ");
           switch (wynik)
               case 1:
                   printf("Wygral X");
                   gtk_signal_connect(GTK_OBJECT(field_[id]), "clicked", G_CALLBACK(Komunikat), (gpointer) window);
                   //gtk_main_quit();
                   break;
               case 2:
                   printf("Wygral O");
                   //gtk_main_quit();
                   break;
               default:
                   printf("Gra w toku...");
                   break;
           printf("\n");
	ruchy++;
	poprzedni = ruch;
	ruch = (ruch==1 ? 2 : 1);
else
	return;
// Funkcja wpisująca X lub O w dane pole
if (ruchy < F_SIZE*F_SIZE)
	gtk_label_set_text( (GtkLabel*) label, (ruch == 1? "X":"O") );
// Funkcja sprawdzajaca czy gracz wygral
int CzyWygral()
   int i = 0, j = 0, suma = 0, z = 0;
   //Sprawdzanie przekatnych
   if (pole[0])
       suma = 0;
       // Lewa przekatna
       for(i = 0;i<F_SIZE*F_SIZE;i++)
		if (i%4 == 0)
			if(pole[i] != pole[0])
				break;
			else
				suma++;
           if (suma == F_SIZE)
               return pole[0];
   if (pole[F_SIZE-1])
       suma = 0;
       // Prawa przekatna
       for (i = F_SIZE-1;i<=F_SIZE*2;i++)
		if (i%2 == 0)
			if(pole[i] != pole[F_SIZE-1])
				break;
			else
				suma++;
           if (suma == F_SIZE)
              return pole[F_SIZE-1];
   // Sprawdzanie linii poziomych
   for (i = 0;i<F_SIZE;i++)
       suma = 0;
       for (j = 0;j<F_SIZE;j++)
		if (pole[(F_SIZE*i)])
			if (pole[j+(3*i)] != pole[(F_SIZE*i)])
				break;
			else
				suma++;
		if (suma == F_SIZE)
			 return pole[j+(3*i)];
   // Sprawdzanie linii pionowych
	suma = 0;
		if (pole[j])
			z = j + (F_SIZE*i);
			if (pole[z] != pole[j])
				break;
			else
				suma++;
			if (suma == F_SIZE)
				return pole[j];
   return 0;
To dlaczego nie chce mi wyskoczyć okienko po wygraniu? :hmm:
test:
z Komunikat wywal linijkę gtk_widget_destroy(dialog);
Już wpadłem na to po kilku minutach od napisania postu :E Po prostu przeczytałem to co kod robi, a co ja potrzebuję :E Program oczekiwał kliknięcia jakiegoś dziwnego żeby wywołać wyświetlenie okienka, a ja potrzebowałem samego wywołania funkcji, a nie jakiegoś "inicjalizatora":P
