m4jq
Shorewall i exim
od jakiegoś czasu nie potrafię skonfigurować shorewall'a do prawidłowej współpracy z eximem. przy włączonym firewallu mam bardzo często komunikat SMTP timeout while connected to nivette.pl [85.128.175.246] after sending data block (614214 bytes written): Connection timed out. przy wyłączonym firewallu jak i przy przepuszczonym całym ruchu maile wychodzą bez problemu. prawdopodobnie coś blokuje ale nie wiem co... konfiguracja jest standardowa + dodane reguły. co może być nie tak ustawione?
#ACTION         SOURCE          DEST            PROTO   DEST    SOURCE          ORIGINAL        RATE            USER/   MARK
#                                                       PORT    PORT(S)         DEST            LIMIT           GROUP
# Drop Ping from the "bad" net zone.. and prevent your log from being flooded..
Ping/DROP       net             $FW
# Permit all ICMP traffic FROM the firewall TO the net zone
ACCEPT          $FW             net             icmp
ACCEPT          net             $FW             icmp
# Server access
SSH/ACCEPT      net             $FW
SMTP/ACCEPT     net             $FW
SMTPS/ACCEPT    net             $FW
HTTP/ACCEPT     net             $FW
HTTPS/ACCEPT    net             $FW
ACCEPT          net:192.168.0.50        $FW             tcp     4949
iptables --list
Chain INPUT (policy DROP)
target     prot opt source               destination
ACCEPT     all  --  anywhere             anywhere
eth0_in    all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere            state RELATED,ESTABLISHED
Reject     all  --  anywhere             anywhere
LOG        all  --  anywhere             anywhere            LOG level info prefix `Shorewall:INPUT:REJECT:'
reject     all  --  anywhere             anywhere
Chain FORWARD (policy DROP)
eth0_fwd   all  --  anywhere             anywhere
LOG        all  --  anywhere             anywhere            LOG level info prefix `Shorewall:FORWARD:REJECT:'
Chain OUTPUT (policy DROP)
eth0_out   all  --  anywhere             anywhere
LOG        all  --  anywhere             anywhere            LOG level info prefix `Shorewall:OUTPUT:REJECT:'
Chain Drop (1 references)
reject     tcp  --  anywhere             anywhere            tcp dpt:auth
dropBcast  all  --  anywhere             anywhere
ACCEPT     icmp --  anywhere             anywhere            icmp fragmentation-needed
ACCEPT     icmp --  anywhere             anywhere            icmp time-exceeded
dropInvalid  all  --  anywhere             anywhere
DROP       udp  --  anywhere             anywhere            multiport dports loc-srv,microsoft-ds
DROP       udp  --  anywhere             anywhere            udp dpts:netbios-ns:netbios-ssn
DROP       udp  --  anywhere             anywhere            udp spt:netbios-ns dpts:1024:65535
DROP       tcp  --  anywhere             anywhere            multiport dports loc-srv,netbios-ssn,microsoft-ds
DROP       udp  --  anywhere             anywhere            udp dpt:1900
dropNotSyn  tcp  --  anywhere             anywhere
DROP       udp  --  anywhere             anywhere            udp spt:domain
Chain Reject (5 references)
reject     udp  --  anywhere             anywhere            multiport dports loc-srv,microsoft-ds
reject     udp  --  anywhere             anywhere            udp dpts:netbios-ns:netbios-ssn
reject     udp  --  anywhere             anywhere            udp spt:netbios-ns dpts:1024:65535
reject     tcp  --  anywhere             anywhere            multiport dports loc-srv,netbios-ssn,microsoft-ds
Chain all2all (0 references)
LOG        all  --  anywhere             anywhere            LOG level info prefix `Shorewall:all2all:REJECT:'
Chain dropBcast (2 references)
DROP       all  --  anywhere             anywhere            PKTTYPE = broadcast
DROP       all  --  anywhere             anywhere            PKTTYPE = multicast
Chain dropInvalid (2 references)
DROP       all  --  anywhere             anywhere            state INVALID
Chain dropNotSyn (2 references)
DROP       tcp  --  anywhere             anywhere            tcp flags:!FIN,SYN,RST,ACK/SYN
Chain dynamic (2 references)
Chain eth0_fwd (1 references)
dynamic    all  --  anywhere             anywhere            state INVALID,NEW
smurfs     all  --  anywhere             anywhere            state INVALID,NEW
tcpflags   tcp  --  anywhere             anywhere
Chain eth0_in (1 references)
ACCEPT     udp  --  anywhere             anywhere            udp dpts:bootps:bootpc
net2fw     all  --  anywhere             anywhere
Chain eth0_out (1 references)
fw2net     all  --  anywhere             anywhere
Chain fw2net (1 references)
Chain logdrop (0 references)
LOG        all  --  anywhere             anywhere            LOG level info prefix `Shorewall:logdrop:DROP:'
Chain logflags (5 references)
LOG        all  --  anywhere             anywhere            LOG level info prefix `Shorewall:logflags:DROP:'
Chain logreject (0 references)
LOG        all  --  anywhere             anywhere            LOG level info prefix `Shorewall:logreject:REJECT:'
Chain net2all (0 references)
Drop       all  --  anywhere             anywhere
LOG        all  --  anywhere             anywhere            LOG level info prefix `Shorewall:net2all:DROP:'
Chain net2fw (1 references)
DROP       icmp --  anywhere             anywhere            icmp echo-request
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:ssh
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:smtp
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:ssmtp
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:www
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:https
ACCEPT     tcp  --  192.168.0.50         anywhere            tcp dpt:munin
LOG        all  --  anywhere             anywhere            LOG level info prefix `Shorewall:net2fw:REJECT:'
Chain reject (12 references)
DROP       all  --  255.255.255.255      anywhere
DROP       all  --  BASE-ADDRESS.MCAST.NET/4  anywhere
DROP       igmp --  anywhere             anywhere
REJECT     tcp  --  anywhere             anywhere            reject-with tcp-reset
REJECT     udp  --  anywhere             anywhere            reject-with icmp-port-unreachable
REJECT     icmp --  anywhere             anywhere            reject-with icmp-host-unreachable
REJECT     all  --  anywhere             anywhere            reject-with icmp-host-prohibited
Chain shorewall (0 references)
Chain smurfs (2 references)
LOG        all  --  192.168.0.255        anywhere            LOG level info prefix `Shorewall:smurfs:DROP:'
DROP       all  --  192.168.0.255        anywhere
LOG        all  --  255.255.255.255      anywhere            LOG level info prefix `Shorewall:smurfs:DROP:'
LOG        all  --  BASE-ADDRESS.MCAST.NET/4  anywhere            LOG level info prefix `Shorewall:smurfs:DROP:'
Chain tcpflags (2 references)
logflags   tcp  --  anywhere             anywhere            tcp flags:FIN,SYN,RST,PSH,ACK,URG/FIN,PSH,URG
logflags   tcp  --  anywhere             anywhere            tcp flags:FIN,SYN,RST,PSH,ACK,URG/NONE
logflags   tcp  --  anywhere             anywhere            tcp flags:SYN,RST/SYN,RST
logflags   tcp  --  anywhere             anywhere            tcp flags:FIN,SYN/FIN,SYN
logflags   tcp  --  anywhere             anywhere            tcp spt:0 flags:FIN,SYN,RST,ACK/SYN
