yta
Windows 7 czy Xp ?
Windows 7 czy XP
152 użytkowników zagłosowało
  1. 1. Który windows lepszy
obsługa pamięci powyżej 4GB
- czyli zachwalasz w7 w wersji 64 bit .... a co z w7.32? ergo jest kiepska?
Nie rozumiem. Wytlumacz. XP nie ma mozliwosci wsparcia powyzej 4 GB. 64bitowa wersje Xp mozna pontraktowac jako ciekawostke.
Wspominane setki razy nie ma czegoś takiego jak Windows XP 64bit ...
chodziło mi o to, że chwalisz 7 za obsługę ponad 4GB, czyli piszesz o wersji 64 bit, natomiast co w takim razie uważasz o 7 w wersji 32 bit? kiepska?
.... jak to nie było XP 64 bit? serio? ... znowu wikipedia mnie okłamała?
Two different 64-bit editions were made available, one designed specifically for Itanium-based workstations, which was introduced in 2001 around the same time as the Home and Professional editions, but was discontinued a few years later when vendors of Itanium hardware stopped selling workstation-class machines due to low sales. The other, called Windows XP Professional x64 Edition, supports the x86-64 extension. x86-64 was implemented first by AMD[38] as "AMD64", found in AMD's Opteron and Athlon 64 chips, and later implemented by Intel as "Intel 64" (formerly known as IA-32e and EM64T), found in Intel's Pentium 4 and later chips.
http://en.wikipedia.org/wiki/Windows_XP
w temacie:
And it infects 64-bit Windows, too
What makes it all worse is that 64-bit Windows has all the same limits even though 64-bit Windows can't run 16-bit applications at all. When operating in 64-bit mode, x86-64 processors can't switch to 16-bit compatible mode. They can switch to 32-bit compatible mode, enabling the use of 32-bit software in a 64-bit operating system, and obviously they can use a 64-bit mode, but there's no 16-bit mode. This means that 64-bit Windows can't run DOS or 16-bit Windows software. If this is something that you really must do, you will have to use a virtual machine.
And yet, all those same limitations remain present, even for 64-bit native applications. Just as 32-bit Windows was designed to be similar to 16-bit Windows to aid porting, so 64-bit Windows was made into a carbon copy of 32-bit Windows. God forbid that application developers should ever have to fix their broken apps to get them to run on 64-bit Windows. No, far better to make things worse for everyone just so they can hit "compile" and be done with it.
http://arstechnica.com/microsoft/guides/2010/10/the-21st-century-guide-to-platform-trolling-windows-sucks.ars/2
The 21st century guide to platform trolling: Windows edition
artykuł niby "trolling", ale tak naprawdę to po prostu wytyka parę niedoskonałości systemów, których niektórzy starają się nie dostrzegać LOL
To za karę a będę żałował: XP jest w stanie obsłużyć o wiele więcej niż jest nam wpajane. ;-)
Szukasz dziury w calym. Nikt tutaj nie pisal, ze nie bylo XP 64 - to wynalazek Microsoftu, ktory sie nie przejal. Masa problemow hardwarowych jak i softwarowych (trzeba bylo podmieniac pliki co nie bylo do konca legalne). Juz nie wspominam o dostepnosci takiego produktu.
Ja nie mowie, ze W7 x86 jest kiepski od W7 x86-64, po prostu ta druga wersja wspiera pamiec powyzej 4 GB ramu co jest bardzo istotne przy wymagajacym sofcie... XP juz nie daje takiej mozliwosci dlatego tez stawiany jest jako ten "gorszy". Gdyby pojawila sie "pelnoprawna" (taka jak w przypadku W7) wersja XP 64 to co innego ...
To najwidoczniej Cię okłamała..
Windows XP 64-bit Edition for Itanium Systems, Version 2002 – system bazujący na kodzie Windows XP, dostępny do roku 2001.
Windows XP 64-bit Edition, Version 2003 – system bazujący na kodzie Microsoft Windows Server 2003, obsługujący dodatkowo procesory Itanium 2, dostępny od 28 marca 2003.
źródło:
http://pl.wikipedia.org/wiki/Microsoft_Windows_XP_64-bit_Edition
Nie pojawiła się i już się nie pojawi nikt nie będzie modernizował starego softu na rzecz w ogólnej liczbie mniejszości userów którzy zostali na Xp..
sam mam pamięciożerny sposób pracy, więc dlatego skusiłem się na W7.64, jednakże fala łatek związanych z funkcjonowaniem mojego sprzętu wywołuje u mnie bsod co drugi boot...
...a wyżej linkowany problem z priorytetami - zrób eksperyment czy u Ciebie też tak będzie muliło.... :E
o tym że nie było XP 64 był post tu:
@down
do gier to rzeczywiście w7.64 jest OK :thumbup: <jak niżej>
Edytowane przez mekk
Jak zainstaluje Windows to sprawdze. :E Ostatnio uzywalem go do Wiedzmina 2 w tej kwestii sprawdza sie znakomicie. :E
Poszukaj postów użytkownika T_G, który używa tego "bubla" (XP 64-bit) do profesjonalnego montażu wideo, przy użyciu platformy serwerowej (para 6-rdzeniowych Opteronów "Shanghai", 128GB RAM, sprzętowy RAID etc.) i bardzo go sobie chwali, gdyż sprawdza się lepiej niż Seven.
Obsługa powyżej 4GB RAM jest istotna tylko dla wąskiej grypy użytkowników, którzy potrzebują większej ilości pamięci. Moim zdaniem o wiele ważniejsze jest to, że aplikacje 64-bitowe mogą być o wiele szybsze i wydajniejsze od wersji 32-bitowych, ale z tym to ciągle loteria.
I tak 7mka jest o wiele lepsza , ma więcej nowości usprawnień niżeli XP.
I nie ma czegoś takiego jak XP 64-BIT.Ktoś napisał gdzieś jakiegoś głupoty a reszta ludzi nie myślących powtarza to a co gorsza jeszcze wierzy w te opinie ...
http://windows.microsoft.com/pl-PL/windows-xp/setup/windows-xp-professional-x64-edition-overview
robi się smutno
A czy to prawda że w dalszym ciągu sterowniki Nvidi pod Win7 z 2 rdzeniowym procesorem są że tak powiem gó... wartę?
Tak samo jest problem na AMD
Ja mam procesor AMD i nie mam problemów ze sterownikami na W7.
Tu chodziło mi o karte :P
Nie wiem czy wiesz ale skoro jest mowa o NVidii to wiadome że chodzi o karty
A ATI to teraz nazywa sie akurat AMD
Ja Posiadam Windows XP i jestem z niego zadowolony. Fakt teraz większość osób ma windows 7, jednak ja chyba zawszę zostanę przy windows xp. Może i za bardzo mi się nie podoba windows 7 dlatego, że nie jestem jego posiadaczem, a zarazem mam słaby sprzęt i nawet jakbym chciał mieć windows 7 to mógłbym sobie pomarzyć. Mój brat ma w laptopie windows 7 i jak nieraz miałem mu coś zrobić, np. wyłączyć aktualizację to nie mogłem się połapać w tym co i jak.. Nie będę tutaj porównywać co jest lepsze, ponieważnigdy nie posiadałem więc nie mogę oceniać.
na 7 możesz ustawić interfrejs XP.
Podaj specyfikację komputera.
Ale już pisałem w7 jest i dla starych kompów.Okrojony ale jest.I na min 512Mb ramu ze z mułem ruszy a na 1Gb ramu działa pięknie :D
Poszukaj postów użytkownika T_G, który używa tego "bubla" (XP 64-bit) do profesjonalnego montażu wideo, przy użyciu platformy serwerowej (para 6-rdzeniowych Opteronów "Shanghai", 128GB RAM, sprzętowy RAID etc.) i bardzo go sobie chwali, gdyż sprawdza się lepiej niż Seven."
potwierdzam bo uzywam obu wind do pracy jednak argumentowanie w tym temacie uwazam za bezcelowe ... bo przeciez samolot zostal obezwladniony na 15 metrach :)
źródło:
Co ty chrzanisz? Za wikipedią:
"Windows XP jest dostępny w wersjach na platformy sprzętowe x86, ia64 i AMD64." Wiki Wystarczy zajrzeć do informacji o platformie sprzętowej. Jak byk stoi x86-64.
@down
A co kogo obchodzą brednie użytkownika sakuwbarakushow?
Edytowane przez gregory003
Może i by mi ruszył w7, ale nie mam zamiaru go instalować, ponieważ po 1. wolę zostać przy xp, a po 2. mam słabego kompa i w7 tylko by mi go bardziej obmulał. Tyle co mam do powiedzenia;]
Zainstaluj sobie 7 na VirtualBoxie i sam się przekonaj że nie będzie Ci muliła.Ustaw w nim parametry swojego komputera (najważniejsze jeżeli chodzi o RAM) i przetestuj.
Naczytałeś się głupot na necie a później tak myślisz i wielu innych także wciąż się zachwalą XP JAKI TO ZAJEBISTY SYSTEM. .
Ale po co ma kupować Win 7 i go instalować skoro ma już XP ?
Nowy system nic mu nie da w poprawie wydajności a za cene systemu ma wiele możliwości w kupnie lepszych części do PC i to mu da lepszy efekt niż kolejny system
Przecież może zainstalowac 30dniową wersję próbną albo odpalić z płyty kolegi czy z neta bez wpisywania klucza.Przecież ma prawo przetestować to co się kupuje.
I W7 wiele zmieni niż ten zacofany XP.
Ale co mu zmieni ?
Piekniejsze okienka ?
Lepszą stabilność ? ( gdzie XP z SP3 jest dalej stabilny )
Nic mu nie poprawi w wydajności jak ma słaby sprzęt
Dajmy na to ze ma np jakiegoś słabszego Core2Duo + GF8600 GT + 1 gb ram
I co myślisz ze jak wgra na Win 7 to mu cos sie polepszy za tą cene systemu ?
Zmarnuje tylko 400zł a za tą cene może mieć Nową karte i więcej ram i po podkreceniu proca komputerek odżywa na nowo i bardziej to będzie widać niż te niby " efekty " po zmianie systemu :Up_to_s:
