Zdziwiony
Czarny ekran, po zalogowaniu do Windows... Proszę o pomoc
Dzięki za radę, ale ja zawsze instaluje najnowsze wersje sterów więc to nie to, aktualnie mam wszystkie najnowsze stery :(
EDIT: używałem nawet takiego programu: slimdrivers i on uważa również że wszystko jest aktualne ;)
Dziwna sprawa...
EDIT: Nie wiem czy to ma jakiś związek (chyba nie bo wcześniej też ten problem występował, a wszystko działało) no ale cóż może go opiszę:
A mianowicie po każdym formacie i ponownym wgraniu windows-a 7 w centrum akcji widnieje coś takiego:
Solve a problem with Away Mode System
This problem was caused by a compatibility issue between your computer's Away Mode System and your 64-bit version of Windows. The Away Mode System is only compatible with 32-bit versions of Windows.
This problem is not critical, but you can prevent it from occurring again by disabling the Away Mode System in your computer's BIOS. Refer to the instructions that came with your computer that explain how to access the BIOS and turn off Away Mode System support.
Note
Changing BIOS settings requires moderate to advanced computer skills. If you are not experienced at changing BIOS settings, consider asking someone with more advanced skills to help you.
What do 32-bit and 64-bit mean?
The terms 32-bit and 64-bit refer to the way your computer's central processing unit (CPU) handles information. The 32-bit and 64-bit versions of Windows are designed for use in computers with 32-bit or 64-bit processors, respectively.
For more info, see this Help topic on the Windows website:
32-bit and 64-bit Windows: frequently asked questions
What is the BIOS?
The basic input/output system (BIOS) is software built into a computer that is run when the computer is first turned on. Among other things, this software starts the operating system and supports the transfer of information between hardware devices (such as the keyboard and the monitor).
Słabo znam angielski więc średnio ten komunikat rozumiem :E
Nie...e Po prostu Windows w centrum akcji wyświetlił mi, że wykryto problem i że jego rozwiązanie nie jest dostępne w moim języku (czyli polskim). Jak na to kliknąłem to wyświetliła się lista języków min. niemiecki, angielski, chiński itd :(
Przekopiuj sobie to do tlumacza w Google i powoli ze zrozumieniem czytaj ;) Moze nie tlumaczy idealnie, ale podejrzewam, ze zlapiesz o co chodzi ;)
Już tego próbowałem i dlatego średnio zrozumiałem :E chodzi tu o coś z systemem zarządzania energią czy coś ?! i że coś nie jest zgodne z 64-bit systemem ;/
Nie. Po prostu wyświetla się po zainstalowaniu wszystkich sterów na czystym systemie i to dopiero po kilku ponownych uruchomieniach...
Właśnie robię testy sprzętu programem BurnIn test, zobaczymy czy wykryje jakieś błędy...
EDIT: włączyłem wszystkie możliwe testy że aż komp muli :E ale na razie nie wykrył żadnych errorów :D
EDIT: heh testy się zakończyły, przetestował chyba wszystkie podzespoły :E, ale nie wykrył ani jednego errora :( czyli skąd ten czarny ekran ?!?!?!?!?
A jak instalujesz stery to pokazdym steru robisz reset czy odznaczasz nie i hurtowo?? :P
Nie! Nie wiem kto tak robi :E ale ja nie, po każdym zainstalowanym sterowniku uruchamiam ponownie kompa!
heh. To żeś mnie pocieszył :E:(
Ale może ktoś inny na coś wpadnie przecież coś musi być nie tak skoro wcześniej było ok a tera przestało być ok i to na tym samym sprzęcie!!!
Mi też już pomysłów brakuje... heh :(
Może dać jakieś logi, jak ktoś się na tym zna może to pomoże w diagnozie :P?
Ups. Sorki na innym forum jak pisałem w szybkiej odpowiedzi to trochę inaczej to działało, ba nawet mogłem usunąc swojego posta, jak mi się napisał niechcący post pod postem. Sorki za post pod postem :kwasny: (wiem że zdanie trochę dziwnie brzmi :E)
Wracając do tematu pliss niech ktoś pomoże, bo ten problem zaczyna coraz bardziej mnie denerować :(
Błagam niech ktoś mi pomoże :(
EDIT: Ups. No to mam kolejnego, bana :( Zapomniałem że na tym forum szybka odpowiedź generuje nowego posta którego nie można usunąć :kwasny:
Sorki... :(
wyłącz w biosie ten away mode - podczas startu away mode jest wykrywany przez usługę plug and play, i system próbuje dla niego zainstalować sterowniki - na 32 znajdzie i zainstaluje, ale dla 64 nie ma sterowników dla tego trybu uśpienia away mode, stąd ten komunikat - ale trudno powiedzieć, czy to właśnie ten problem, że zapraszamy wisi tak długo, itp, trochę pózno na instalację sterowników - ale możliwe; na 64 można wyłączyć to tylko w biosie, opcja może się różnie nazywać, ale powinna być w zarządzaniu energią (power management) - na dell nazywa się np Quick resume, na asusie podobno amd live, itd - na niektórych podobno w ogóle nie ma tej opcji w biosie
ewentualnie właśnie process monitorem możesz sprawdzić, czy to ten problem - jak pisałem dla sprawdzania plików sys
(a ten sterownik jest pewno sys) mam gotową procedurę
ale z tego co czytałem o tym komunikacie z away mode - nikt nie skarzy się na jakieś wielkie opóznienie w ładowaniu, więc może nie mieć związku
ps - fantazyjna nazwa away mode znaczy chyba system pozornie nieobecny (od to be away - być nieobecnym) - wygląda, jakby system spał, ale w tle dokonuje normalnych operacji, np zapisuje film z karty telewizyjnej, albo dokonuje wymiany plików współdzielonych, itp - normalnie trzeba go wybudzić ze snu, żeby to robił, stąd trzeba było wymyślić nową nazwę dla tego pozornego uśpienia
ps2 - away mode jest obsługiwany przez procesor, więc jeśli masz amd to ustawienie będzie w cpu settings (amd live), nie energy czy power
ps3 - prawie trafiłem - away mode = user not present
Dzięki za odpowiedź, ale chyba ten away mode nie powoduje mojego problemu, bo wcześniej również występował on w centrum akcji, a ja to ignorowałem, i wszystko chodziło OK, ale jak myślisz czy ten "optymalizujący windowsa" program: mógł coś zrypać ze sprzętem ? Bo pamiętam że pisało tam coś że przyspieszy dysk twardy czy coś. Co do tego Away mode w biosie to postaram się to wyłączyć. Z resztą wydaje mi się, że ten problem ma coś wspulnego z hibernacją systemu, bo nie mogę go uśpić tzn. usypiam go na jakieś 30 sek, a później system sam się od nowa uruchamia (stery od zarządzania energią są zainstalowane)
Spróbuj jeszcze innej drogi po zainstalowaniu systemu i wrzuceniu sterowników wyłącz wszystkie aktualizacje systemu bo może system po zaaktualizowaniu przez jakąś łatkę daje taki błąd, miałem podobny problem tylko że już nie mogłem wogóle zalogować się tylko tryb awaryjny po przywróceniu systemu sprzed kilku dni wyłączeniu aktualizacji i stworzeniu nowego konta użytkownika (na stare nie można był się zalogować) problem zniknął.
heh. Właśnie o to chodzi, że czarny ekran występuje również bez aktualizacji. Jak go zobaczyłem, to użyłem klawiszy ctrl+alt+delete i się ponownie zalogowałem. Zainstalowałem wszystkie aktualizacje dla systemu i... nic to nie zmieniło... Dalej czarny ekran czyli to nie to heh...
Chyba kiedyś wywalę tego kompa przez okno :E
EDIT: System uruchamia się normalnie w trybie awaryjnym.
To normalnie czy w awaryjnym?? :D
Więc zaloguj się w trybie awaryjnym potem w panelu sterowania dodaj nowe konto administracyjne i wznów komputer, potem już w trybie normalnym spróbuj się zalogować do systemu na nowo założonym koncie i daj znać czy poszło
Nie łap mnie za słówka no :P
Ale przecież ja teraz pisze z trybu normalnego, i jest ok, tylko, że gdy pojawił mi się czarny ekran to wcisnąłem Ctrl+alt+delete i wylogowałem się i ponownie się zalogowałem. Wtedy mogę już normalnie na kompie pracować, grać itd. Tyle że to strasznie denerwujące ;/ Do tego napis zapraszamy mieli przez 2 min.
PS: Jeżeli zostawię ten czarny ekran na 10 min to po tym czasie ekran sam się pojawia, dziś zauważyłem... Dziwne.
Jak tak dalej pójdzie to na prawdę w końcu kompa wywalę przez okno xD :E:P
Dlatego ci kazałem stworzyć nowe konto i tam sprawdzić czy te obiawy też występują bo może masz coś uwalone w swoim profilu, a może być to problem całego systemu
innym sposobem jest zainstalowanie sobie np. ccleanera i poodznaczanie uruchamiających się niepotrzebnych aplikacji podczas startu systemu gdybyś niewiedział jakie można wyłączyć to wspomóż się google
