qjin
Wiedźmin 3: Dziki Gon
Hej
Panowie, zaczalem grac w wieska od dzisiaj, nie dawno wskoczyl mi 2-gi lvl, mam do rozdania jeden punkt, gre zainstalowalem po angielsku i nie wiem jak rozdac ten punkt, czy ktos moze pomoc? Dzieki :)
Grasz w polską grę po angielsku ??? :lol2:
Szukaj zakładki "character". Tam rozdajesz punkty i instalujesz umiejętności w slotach.
Wlasnie nie moge rozdac tego punktu ;/
Tak gram po angielsku, robie tak jak jest napisane ale nie wychodzi :P
Mam problem z wiedzminem, postać skacze jak szalona mimo, że nic nie wciskam, non stop podskakuje :E
Heniek... 1.237 volt ?
To se ne da :P
1.212 V :thumbup:
No przeskok z różnych trybów 1.193V - 1.212 - 1.237 - 1.25 - 1.262 - 1.275 - Na 1.212 to max 1450MHz.
Patch 1.08
PERFORMANCE:
Overall improvements to performance, including some issues that may have been caused by 1.07.
UI:
[Japanese Only][PS4 Only] Fixes an issue where the background text of certain books would flicker.
Fixes an issue where part of the Kaer Morhen map would not display properly.
GAMEPLAY:
Fixes a rare issue where items would disappear from the stash.
Fixes a very rare issue which would cause Geralt to get stuck when trying to run.
The interaction pop-up will no longer appear on lootable objects that are empty.
Fixes an occasional glitch in one of the dwarf combat animations.
Heads chopped off during finishers will no longer disappear.
"Players can perform a roll just before landing to significantly reduce the damage caused by falling.
We've added a tutorial pop-up window explaining this to make it clearer."
In patch 1.07, the level requirements for certain items were scaled up, leaving some players stuck with only unusable gear. With patch 1.08, we are introducing the Wolven Hour potion. This potion will be available in everyone's inventory once they install the patch. It will reduce level requirements on all gear for a period of one hour. This will give players time to level up or find alternative equipment using the gear that was available to them in patch 1.05 but became unusable after patch 1.07. After one hour, the potion's effects will cease and the requirements for all gear will revert to their original, pre-potion values.
Fixes an issue where players were unable to compare their items with ones sold by merchants.
ACHIEVEMENTS:
Players will now be able to complete the Card Collector achievement.
Achievements are now working properly again and will be unlocked if players meet their requirements after installing this patch (PC version).
GRAPHICS:
Fixes an issue where interiors would sometimes not display properly on the minimap.
Fixes an issue where certain world elements would sometimes be missing and noticeable visual glitches would be present while in Novigrad.
QUEST:
Fixes an issue where players were unable to finish the "It Takes Three to Tango" quest, even though they had obtained wine at the Kingfisher.
Fixes an issue where Geralt would sometimes die after traveling to Velen in the quest "Something Ends, Something Begins."
The entrance to the area where the Sunstone is obtained will no longer be blocked off if the player exits it prematurely during "The Sunstone" quest.
Fixes an issue where players were unable to complete the "Get Junior" quest on certain occasions.
Fixes an issue where players were unable to finish the "Scavenger Hunt: Viper School Gear" quest due to a closed gate.
Fixes an issue where some players were unable to investigate rooms during the "Family Matters" quest, effectively blocking their progression.
Fixes an issue where players were unable to finish the "Hey, You Wanna Look at my Stuff?" quest.
Fixes an issue where players were unable to talk to Roche during the "An Eye for an Eye" quest.
Fixes an issue where Roche would stay at his camp instead of going to the Oxenfurt Bridge in the "Get Junior" quest.
Fixes an issue where, under certain circumstances, Yennefer would not appear in Oxenfurt during the "The Great Escape" quest.
Drowners will have a harder time killing Nidas during the "Black Pearl" quest.
Fixes an issue which led to an infinite loading screen during the "To Bait a Forktail..." quest under certain circumstances.
Fixes a rare issue where the basement was locked during the "King's Gambit" quest.
Fixes an issue where players were unable to free the merchant during the Person in Distress event in the Claywich area.
The trolls at the Circle of Elements will no longer attack Geralt if he opts for a peaceful resolution.
Fixes an issue where players were unable to talk to Roche during the "Brothers in Arms" quest.
Fixes an issue where Zoltan's card was unobtainable.
GENERAL:
Preparatory features paving the way for the introduction of New Game + in the future.
cos mnie dzisiaj wzielo na odkrywanie znakow zapytania . latam caly czas po mapie :E
Ja przechodzę drugi raz na szybko z przeciwnymi wyborami :D Zapisy z pierwszego przejścia zachowałem, gdzie zostały tylko ? na wodach Skellige ;p
Co zrobić żeby Baron się powiesił?
Edytowane przez RyszardGTS
Za pierwszym razem można nie wiedzieć jak użyć [spoiler]
palel47 - wiesz co to spoiler?
Tak w telegraficznym skrócie - musisz uwolnić tego ducha lasu z drzewa
Nie widze takiej opcji
Ok znalazłem:
Za pierwszym razem ducha uwolniłem, ale robiłem to zadanie po tym jak baron już wyjechał z tą babcią.
Za drugim razem zrobiłeś to celowo, brak [spoiler]
u mnie pomogło ponowne odpalenie gry
Ehh, a blad w Jaskini Snow wciaz nie naprawiony :(
Ja na 1.206V mam 1535Mhz :smokin:
Ja tam się cieszę z tego co mam... nie mam zamiaru kombinować żeby było lepiej bo nie ma najmniejszego sensu. Obecnie mam zamiar zmienić tylko procka na 2600K albo 3770.
Patch 1.08
można to znaleźć ładnie po polsku przetłumaczone
Proszę uprzejmie:
Aktualizcja 1.08 - Lista zmian
Łatka 1.08 jest w drodze, a poniżej możecie zapoznać się z listą zmian, jakie wprowadzi.
WYDAJNOŚĆ:
Poprawiono ogólną wydajność gry i usunięto problemy, które mogły pojawić się w aktualizacji 1.07.
INTERFEJS:
W japońskiej wersji gry na konsoli PS4 naprawiono problem, który powodował, że elementy w tle migały podczas czytania pewnej książki.
Naprawiono problem z wyświetlaniem się niektórych części mapy Kaer Morhen.
ROZGRYWKA:
Usunięto rzadki błąd powodujący, że przedmioty znikały ze skrzynki gracza.
Naprawiono rzadki błąd, który powodował, że czasami Geralt mógł się zablokować podczas próby biegu.
Okienko interakcji umożliwiające lootowanie nie będzie już pojawiać się na "pustych" obiektach.
Naprawiono błąd w jednej z animacji walki krasnoludów.
Głowy odcięte podczas ciosów kończących nie będą już znikać.
Gracze mogą wykonać przewrót w przód tuż przed lądowaniem po skoku niwelując tym samym znaczną część obrażeń wynikającą z upadku. Został dodana odpowiednia wzmianka w samouczku na ten temat.
W aktualizacji 1.07 wymagane poziomy do używania niektórych przedmiotów zostały podniesione, co spowodowało, że gracze zostali ze sprzętem, którego nie mogli używać. W łatce 1.08 zostaje wprowadzony eliksir Godziny Wilka. Eliksir ten pojawi się w ekwipunku każdego gracza, który zainstaluje łatkę. Obniży on poziom wymagany do użycia sprzętu na dokładnie godzinę. Pozwoli to graczom na zdobycie brakujących poziomów lub znalezienie zastępczego wyposażenia. Po upływie jednej godziny, efekt eliksiru przestanie działać i wymagania względem poziomów wrócą do stanu sprzed zażycia Godziny Wilka.
Naprawiono problem, który powodował, że gracze nie mogli porównywać swoich przedmiotów z tymi oferowanymi przez kupca.
OSIĄGNIĘCIA:
Gracze mogą ponownie zdobywać osiągnięcie "Kolekcjoner Kart".
Osiągnięcia w wersji PC znów działają poprawnie i są odblokowywane wraz z postępem gracza.
GRAFIKA:
Naprawiono błąd, który powodował, że wnętrza budynków nie zawsze wyświetlały się poprawnie na mapie.
Usunięto problem powodujący, że niektóre elementy świata nie doczytywały się wcale, a część powodowała widoczne błędy graficzne w Novigradzie.
ZADANIA:
Naprawiono problem w zadaniu "Serce nie sługa", który uniemożliwiał jego zakończenie nawet w przypadku gdy gracz kupił wino w karczmie Zimorodek.
Naprawiono problem, przez który Geralt czasem ginął po podróży do Velen w zadaniu "Coś się kończy, coś się zaczyna".
Wejście do miejsca, w którym można znaleźć Kamień Słoneczny nie będzie już zablokowane jeśli gracz przedwcześnie opuści teren w zadaniu "Kamień Słoneczny".
Naprawiono problem, który czasem uniemożliwiał ukończenie zadania "Dorwać Juniora".
Naprawiono problem, który uniemożliwiał graczom ukończenie zadania "Poszukiwania: Rynsztunek Żmii" z powodu zamkniętej bramy.
Usunięto problem, który sprawiał, że gracze nie mogli zbadać pokoi w zadaniu "Sprawy Rodzinne" i tym samym uniemożliwiał dalszy postęp gry.
Naprawiono błąd powodujący, że gracze nie mogli ukończyć zadania "Tajemniczy Handlarz".
Naprawiono błąd, który sprawiał, że gracze nie mogli porozmawiać z Vernonem Roche podczas zadania "Oko za oko"
Naprawiono błąd powodujący, że Roche zostawał w swoim obozie zamiast iść na Most Oxenfurcki w zadaniu "Dorwać Juniora".
Usunięto problem, który sprawiał, że czasami Yennefer nie pojawiała się w Oxenfurcie podczas zadania "Wielka ucieczka".
Utopce nie będą teraz tak szybko zabijać Nidasa w zadaniu "Czarna perła".
Usunięto występujący czasami niekończący się ekran ładowania podczas zadania "Ażeby widłogona zwabić...".
Naprawiono rzadki błąd powodujący, że piwnica była zamknięta w zadaniu "Królewski Gambit".
Naprawiono problem sprawiający, że gracze nie mogli uwolnić kupca podczas wydarzenia "Ludzie w opałach" w okolicach Wsi Glińsk.
Trolle w Kręgu Żywiołów nie będą już atakować Geralta jeśli wybierze pokojowe rozwiązanie.
Naprawiono problem powodujący, że gracze nie byli w stanie porozmawiać z Vernonem Roche w zadaniu "Towarzysze broni".
Usunięto problem uniemożliwiający zdobycie karty Zoltana.
OGÓLNE:
Wprowadzono szereg funkcjonalności przygotowujących grę na wprowadzenie nowego trybu - Nowej Gry Plus - w niedalekiej przyszłości.
Wy też macie problemy z achievami na Steam? Mnie nie naliczyło zdaje się kilku a spełniłem wymagania :/
Ale po co, przecie 2550k wszędzie daje radę :>
Heh, a jednak zrobią z tym porządek, to miło NG+ czeka :thumbup:
Na pewno taki 2550k wykręcony na 4,6 lepiej wypada niż zablokowany i5-4440. Zresztą w tej grze to GPU gra główne skrzypce, 980 Ti na 2500k 4,8 MHz chodzi jak marzenie w 1440p na uber ustawieniach z włosami.
Edytowane przez hennepin
wczoraj mialem smiesznego buga . zabilem biesa a jego cialo nagle zaczelo sie przemieszczac , chyba z 50m . tak jakby go cos ciagnelo po ziemi ....
Nie wiem jak ci to powiedzieć, ale jednak go nie zabiłeś, tak się trupy nie zachowują :E
